Author Topic: Point me in the right direction for DOS stuff!  (Read 1334 times)
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
« on: February 23, 2005, 10:29:09 pm »
Hey guys I'm running a 533 in my custom built cocktail cab and its a little slow and prone to crashing with windows XP on it.  I really want to run DOS on it but I dont even know where to start.  If somebody could point me in the right direction it would be much appreciated.
I realize that I will have to customize it with my own drivers for my sound and video card. I'm not expecting somebody to hold my hand through the process but I think the last time I heavilly used dos was about 10-12 years ago.
Thanks for any help
Slicer_D
P.S. I'm also using game launcher as my front end
slicer_d
  • Yay n' stuff
Re: Point me in the right direction for DOS stuff!
« Reply #1 on: February 24, 2005, 12:01:19 am »
To answer my own post I found this and I should give me most off the info I need.
http://www.mameworld.net/dosmame/
If anybody has any suggestions about running MAME in DOS I would still like to hear them.
Matt
Thenasty
  • Last login:January 29, 2026, 11:38:03 am
« Reply #2 on: February 24, 2005, 07:39:44 am »
I run MAME in pure DOS and no regrets, specially the Advance Mame w/Arcade monitors.
First off, you need to get you soundcard going, configure that first, well Partitioning and formating your HD and installing DOS OS is actually first, then the soundcard is next. Once those 2 are done, move onto the next step----deciding/configuring the software and FE.
Free VGA Breakout Cable
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: February 24, 2005, 09:31:48 am »
-First install our OS  using a PC Screen (not the arcade one if you have one)
- 2) configure the soundcard. If you have a modern soundcard you can have diffulties to find a Dos drivers. May be it doesn't exists. If you have a Real Sound Blaster card you can find it easly.
-3) choose you front end and MAME version  . My opinion :
    if you have an arcade screen
       - if you have an ArcadeVGA -> DMAME
       - if you another VGA card -> ADVMAME
    if you don't have an arcade Screen what you want.
    Front end :
      -Advmenu  (even if you don't use ADVMAME)  or
      -Arcade OS
-4) set up your mame and front end
-5) If you have an arcade screen and NOT a ArcadeVGA
  -Install the ARCMON.SYS dos driver.
-6) Plug your PC on the arcade screen.
-7) adjust your settings
slicer_d
  • Yay n' stuff
« Reply #4 on: February 24, 2005, 09:01:37 pm »
Thanks for the replies guys I think I should be able to figure most of it out now.
I was reading through the page I had poseted above and it talks about an I686 dos optimized version of mame.
Thenasty
« Reply #5 on: February 25, 2005, 07:19:15 am »
no one will have the DOS of 92 cause its not released yet. You have to wait until its HATCH ! !
Chris
    • Chris's MAME Cabinet
« Reply #6 on: February 25, 2005, 09:21:13 am »
--Chris
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #7 on: February 25, 2005, 01:11:01 pm »
I run mame just fine on my PIII 500 with XP.
slicer_d
  • Yay n' stuff
« Reply #8 on: February 25, 2005, 05:28:49 pm »
Since I have no idea when they will release the .92 version.  Does anybody have MAME .90 or .91 DOS I686 version.
Sir Poonga most games run alright in XP some are slow but thats to be expected with a 550. When I swtich between games it takes a while and games slow down after running a few.  I'm hoping to help those problems and also it has been crashing on me a lot and I would rather try a new dos install then just reinstalling XP again.  XP seems like a bit of overkill to.
