Author Topic: Spinners - reverse direction in Mame?  (Read 1644 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: February 18, 2005, 03:38:38 pm »
Using command-line Mame and Mame32, is there a global setting to reverse the mouse direction?
Have a home-grown spinner (thanks to TheNasty!), and it works great, but I had to go in and manually change the analog controls for it to work properly.  I don't play many spinner games (Arkanoid, and a few racing games, maybe I'll try Tron and Commando...), so it's not that big of a deal to go into each one.
Thanks.
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Spinners - reverse direction in Mame?
« Reply #1 on: February 18, 2005, 06:49:42 pm »
I'd swap some wires around.
« Last Edit: February 18, 2005, 06:58:09 pm by JODY »
Thenasty
  • Trade Count: (+17)
  • Last login:January 29, 2026, 11:38:03 am
« Reply #2 on: February 18, 2005, 07:34:01 pm »
Free VGA Breakout Cable
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #3 on: February 18, 2005, 09:13:48 pm »
The way to fix that would be to put the board upside-down.  Right now, it sees right as left, so if you flip it, it will see right as right.  If worst comes to worst, desolder the detector and wire them to a small piece of wood if you do not have enough room to flip the whole board.
