Author Topic: Can you use a SVGA/VGA monitor on a Jamma cabinet with CGA output.  (Read 1736 times)
TheRCGuy
  • Last login:March 20, 2005, 07:24:45 pm
Is there anyway to use a SVGA/VGA monitor on a Jamma CGA cabinet? If so what would I need to convert the signal?
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:47:34 am
Re: Can you use a SVGA/VGA monitor on a Jamma cabinet with CGA output.
« Reply #1 on: January 28, 2005, 09:05:36 am »
I just read something like this in here, the answer is there is , but it more expensive than buying a NEW CGA monitor and more expensive than this
http://www.jrok.com/hardware/RGB.html
what I have said before.
Free VGA Breakout Cable
TheRCGuy
« Reply #2 on: January 28, 2005, 09:58:24 am »
Thanks Again!! One Day I will have a Project to contribute to this site!! :)
Right now I am a newbie with limited funds trying to make sure that I get the result that I want without wasting alot of money learning, figured it is much cheaper to ask a bunch of questions & read post, then ask more questions that arises as I read other post.
Thanks!!
StephenH
« Reply #3 on: February 11, 2005, 01:33:24 pm »
Yes, but you will need a scan converter.
This might do the job:
http://www.extron.com/product/product.asp?id=in1401&subtype=42&view=feat
