Author Topic: Happ Perfect 360s and SlikStik sticks  (Read 1483 times)
alex627
  • Last login:March 04, 2005, 07:50:28 pm
« on: January 27, 2005, 12:14:01 am »
Am I the only person who is having trouble with these new SlikStik sticks? I can't hit diagonals. When I put the stocks sticks in the base they work OK. What is bad the bases or the sticks?
Of course SlikStik told me I had defective bases and convinced me to order new ones from him. Same problem. New Pear-Tops come with split washers and on the back of the business card is hand written "Put washer on before e-ring on Pear-Top sticks" I find that a bit questionable.
crashwg
Re: Happ Perfect 360s and SlikStik sticks
« Reply #1 on: January 27, 2005, 09:14:00 am »
Are you maybe putting the actuator on upside down?
From Happs site:
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
alex627
« Reply #2 on: January 27, 2005, 09:58:49 am »
Thanks for the reply. No the small diameter is toward the e-ring. Again I have no problems really with the stock sticks.
I don't recommend the Opitcals for 8-way though. I am not sure why they are so expensive and recommended so highly. I wish I had gone with microswitch sticks.
rdagger
« Reply #3 on: January 27, 2005, 11:50:03 am »
The SS sticks maybe putting the actuator at a slightly different height which could explain your problem.
Also, I have found that scratched actuators can affect the P360's.   I have several P360's and they work great in 8 way but suck for 4 way.
Thenasty
  • Last login:November 13, 2025, 10:25:52 pm
« Reply #4 on: January 27, 2005, 11:57:58 am »
I have the 360 and plays 8-way games perfectly and also plays Q-bert Style Games perfectly (via simple mod) is like having 2 joysticks in one. You can make the mod to be 4-way, the Q-bert was setup Diagonally.
Free VGA Breakout Cable
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #5 on: January 27, 2005, 05:09:22 pm »
I had a similar problem with one of mine.  It worked OK, but it was very hard to find the diagonals on one side.  I took it apart, cleaned it all off, and reassembled and it is working better.
For some reason the diagonals are still not as good as the other P360 I have (which works perfectly).  I suspect that there may be a slight misalignment of the optics on one of the sensor-led pairs, so I'm leaning towards dissassembling it again to check alignment.  It was not the actuator - as I already replaced that with no effect.
Still overally I prefer the 360's to my old conventional joysticks - they are much quicker and more responsive.
Cheers!
Doc -
alex627
« Reply #6 on: January 27, 2005, 06:16:03 pm »
Thanks for the replies.
I am talking to Christian at SlikStik and he is being very cooperative and helpful. Everything I have heard about SlikStik is positive so I don't understand the difficulty with my particular install. I am going to test them again. If I figure out what the problem is I will post the results.
I will try cleaning the actuators as suggested above...
