Author Topic: Old Atari B&W Monitor - Replacement Options?  (Read 3002 times)
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« on: January 23, 2005, 04:01:31 am »
Problem:
Re: Old Atari B&W Monitor - Replacement Options?
« Reply #1 on: January 23, 2005, 10:08:09 am »
Have you checked the power supply, solder joints on the board, the flyback transformer?  These are all things that could cause it to 'die' even if it's not necessarily dead.
Thenasty
  • Last login:February 10, 2026, 09:58:56 pm
« Reply #2 on: January 23, 2005, 12:27:11 pm »
I have an 1979 Atari ideo pinball w/ 21" B/W monitor. IMO, the monitor still works, it has the glow of life on the tube/neck.
However, I have a guy that suppose to pick it this weekend but cancleed due to weather, so I have to hold on till next week. If nothing happens w/this deal, would you be interested ?
Free VGA Breakout Cable
« Reply #3 on: January 23, 2005, 01:13:00 pm »
Where are you located?
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #4 on: January 23, 2005, 03:36:53 pm »
I wonder if you could use a color monitor as a replacement, if you tie the Red, Green, and Blue inputs together and connect it to the B&W output.  From additive color addition, RED + Green + Blue = White.
johnvv
« Reply #5 on: January 23, 2005, 03:41:59 pm »
I am located in N. California.
While the neck of the monitor used to glow when it worked, it now simply makes a zapping sound and flickers with a blue light.  A new cap kit was put on it previously, so those parts are fine.
« Reply #6 on: January 23, 2005, 04:51:51 pm »
Zap and blue light sounds like dead tube.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #7 on: January 23, 2005, 05:15:44 pm »
Almost sounds like you vented the neck.
johnvv
« Reply #8 on: January 23, 2005, 05:19:17 pm »
That's been my expectation - the tube is dead.
I'm willing buy a new monitor to replace it, cost is not the primary concern, but don't know if it can be replaced or, if it can, with what.
Any other suggestions on replacement?  Thanks for the advice so far.
SirPeale
« Reply #9 on: January 23, 2005, 05:26:55 pm »
Tubes generally vent only when you do something really bad to them, like jar them.
Ask on RGVAC if anyone has either a replacement tube or monitor.
Ken Layton
  • Guru
  • Technician
« Reply #10 on: January 24, 2005, 12:11:03 pm »
Sudden temperature changes can crack the tube and vent it also.
According to the service manual you have a 22VATP4 picture tube. You can order this from Video Display Corp (1-800-241-5005 or sales@cathoderaytubes.com), Richardson Electronics (www.rell.com), Hawk-eye Picture tubes (www.hawkeyepicturetube.com), Clarke Electronics (www.picturetubes.net/clark.htm), and Budget Tubes (www.budget-tubes.com) as well as the parts department of Wells-Gardner Electronics.
