Author Topic: Monitor Wont turn on :(  (Read 1832 times)
raventy
  • Last login:February 01, 2016, 05:55:47 pm
« on: January 06, 2005, 04:39:01 pm »
ok guys heres what happend:
I got a monitor to replace my old dead on in my soul calibur machine. The old was a Wells Gardner k7000 and the new was a NeoTec 2515C. I hooked the new one up and at first it had some white lines going horizonataly across it with a messed up image.. so after adjusting the focas and screen controls I got it to go away and the image to appear. For the most part the image looked good except for REDS werent showing! So i adjusted the RED control on the top part of the neckboard... nothing seemed to happen so i then adjusted the RED saturation knob on the lower part of the neckboard and now the majority of the screen was red! Like u could barely see the old colors behind all the red... so i adjusted the knobs a little and then the reds became perfect but the BLUES dominated the screen now.. so I went to get a drink, i come back, and the monitor is off! I look and the fuse is blown.. so I go out, buy a new fuse and replace it but it still wont turn on... anyone have any idea whats wrong? Thanks!
Thenasty
  • Last login:Yesterday at 04:30:09 pm
Re: Monitor Wont turn on :(
« Reply #1 on: January 06, 2005, 06:51:15 pm »
you and me again.  :o
First, if its NEW, the RED/GREEN/BLUE wouldn't need any adjusting. It should be good at default. Second are you using an ISO for the Neotec ? I dunno if it needs one or not.
Free VGA Breakout Cable
raventy
« Reply #2 on: January 06, 2005, 07:29:27 pm »
haha hi again!!
« Last Edit: January 06, 2005, 07:31:18 pm by raventy »
Thenasty
« Reply #3 on: January 06, 2005, 07:38:07 pm »
this is out of my league now.. but maybe the FLYBACK is BAD. Wait  for Ken Layton to give you some advice. Good luck.....
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 07, 2005, 12:47:22 am »
I've worked on the older Neotecs (like 10 years old). Those had several caps that would dry out causing inoperative monitors. They also would burn up a resistor, but generally just a cap kit and replace a resistor got 'em going again. Never had any flybacks go bad though. You can contact the manufacturer at www.neotecgraphic.com
raventy
« Reply #5 on: January 07, 2005, 01:03:26 am »
hhmm its funny cuz this monitor just had a whole new cap kit put on it before it was sent to me.. could adjusting colro controls really mess someting up THIS bad? I mean now the monitor acts as if it gets no power and shows no sign of life by looking at it.. I also wonder why that fuse blew?
« Last Edit: January 07, 2005, 01:06:34 am by raventy »
Ken Layton
  • Guru
  • Technician
« Reply #6 on: January 07, 2005, 01:08:39 am »
I have not worked on a 2515. My experience on Neos were on the older models. Strongly recommend contacting the manufacturer's tech support dept.
raventy
« Reply #7 on: January 07, 2005, 01:20:49 am »
ah alright.. also a kinda more random note... in the previous monitor I had in there.. I think it was the tube that was the main cause of it note workin.. do u think its possible to put the old monitors WellsGardner k7000 board with the new ones neotec tube?
Ken Layton
  • Guru
  • Technician
« Reply #8 on: January 07, 2005, 01:24:34 am »
I would advise against putting a Wells chassis on a Neotec tube.
raventy
« Reply #9 on: January 07, 2005, 01:30:53 am »
alright thanks! I just wrote NeoTec an email and ill see what they have to say.
skiperman
  • Last login:June 16, 2005, 04:18:37 pm
« Reply #10 on: January 11, 2005, 11:20:49 am »
I repair Arcade Monitors in the Toronto/GTA area.
I'm located in thornhill.
resonable rates!
reply to : service.ierr@rogers.com
