Author Topic: any one remember the Defender  (Read 3065 times)
Thenasty
  • Trade Count: (+17)
  • Last login:March 19, 2026, 01:43:07 pm
« on: October 04, 2002, 08:22:00 am »
Anyone here remember how to change the source setup (hack) Defender controls so it thurst when push LEFT and go left, and when you push RIGHT, it REverses and thrust and goes right etc...? or did I just mis-read that.
Free VGA Breakout Cable
Lilwolf
Re:any one remember the Defender
« Reply #1 on: October 05, 2002, 06:19:00 pm »
the default does that with left and right buttons
Thenasty
« Reply #2 on: October 05, 2002, 07:14:38 pm »
I mean the THRUST and REVERSE is done witht the joystick.
I thought there a talk about  this before on how to make the joystick so when you facing right and push right, it will fly right, then if you push the joystick to go left, it will reverse and fly left. Its like you elimated 2 buttons, but the switching from left to right, it also reverses, so insead of pushing the reverse button, this is done for you when you change direction.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: October 06, 2002, 05:05:26 am »
I dunno, I just use one of the P1 buttons for reverse, and the rest of the buttons are on the P2 side.  You could always just make reverse into LEFT OR RIGHT, so you use those directions on the joystick as your reverse button...
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #4 on: October 06, 2002, 10:59:49 pm »
Whoa, I just tried playing defender with a bat stick and one of the P1 buttons as reverse.  It's IMPOSSIBLE!  Likewise, using left and right for reverse gets confusing fast.  You really do need an auto-reverse!  Please post if you discover the hack!
My other job...
Thenasty
« Reply #5 on: October 11, 2002, 05:11:33 pm »
so far, looks like everyone is BLANK in the HEAD :)...Maybe bringing this post up on top, we will get more readers...
rgardjr
  • Last login:December 05, 2002, 06:03:32 pm
« Reply #6 on: October 14, 2002, 03:11:00 pm »
Seems like I remember that this was accomplished via a cheat.  I just ran it via advmame and enable cheat and now it does what you're saying-i.e. thrust and reverse via that joystick or in my case the keyboard arrows.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #7 on: October 14, 2002, 05:13:13 pm »
Ahh, like the speed cheat in Pac-Man...nice...
My other job...
Thenasty
« Reply #8 on: October 16, 2002, 01:20:09 pm »
yeap thats the one. Only one thing when using cheat is that you r score won't save (Unless src is changed). How did someone mange this ? Is there a possible way to Buteforce the ROM to do it with the cheat parameter ? Any takers?
Thenasty
« Reply #9 on: October 16, 2002, 01:42:11 pm »
How about making TRON auto fire ?
Thenasty
« Reply #10 on: October 21, 2002, 08:21:48 am »
ok, i got the info on how to do it in the src without the cheat parameter. If you  interested LMK. Its very easy. Thanks Stephh
