Author Topic: P-360's powered by Opti-pac  (Read 1062 times)
warreng
  • Last login:January 03, 2006, 05:20:57 pm
    • Rombotron.net
« on: December 14, 2004, 11:20:44 am »
Hey Guys,
I am using both an I-pac and Opti-pac for my CP. I am powering my two p-360's from the 5v lug on the opti-pac per Andy's recommendation. The one question I still have is where should I connect my grounds? Do they also get connected to the Opti-pac as a separate run or should they be included in the chain with all of the other controls? Does it even matter?
Thanks in advance for any help you can offer,
WarrenG
Cabinets in Progress - Rombotron & Old Skool
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 11:02:57 am
Re: P-360's powered by Opti-pac
« Reply #1 on: December 14, 2004, 01:24:58 pm »
any ground on the Ipac/optic-pac is a Ground, no matter which one you use. If you take continuity on any of the Grounds, its all connected as one ground, this goes in any circuit.
Free VGA Breakout Cable
warreng
    • Rombotron.net
« Reply #2 on: December 14, 2004, 02:09:29 pm »
Thanks, that's what I thought, but I figured I would ask to be sure. Better safe than sorry.
-warreng
