Author Topic: Need Dual Joystick Help!!  (Read 4149 times)
OzStick
  • Last login:February 27, 2019, 11:25:50 pm
  • I manufacture Arcade Controls!
    • OzStick Website
« on: May 17, 2002, 09:57:53 pm »
Hi All,
I should know better but I have been stuffing around for ages trying to get
dual joysticks working correctly on my DOS box.
I am running MAME 0.36b6 with ArcadeOS v2.42 in a little cocktail cabinet I
have put together. I have wired one joystick and 2 buttons into a controller
box on either side of the cab, but as soon as I specify that I am using
"Dual" joysticks under ArcadeOS and/or MAME it won't detect either sets of
controls! If I change the joystick option to either "2 Button" or "4 Button"
then I am able to get the Player 1 controls working correctly.
I'm pretty confused by this, as I have mananged to get 2 sticks working in a
similar fashion but running via Windows 9x rather than in true DOS mode.
There has to be simple solution, but I can't see the wood for the trees at
the moment!
Please help......
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Re: Need Dual Joystick Help!!
« Reply #1 on: May 20, 2002, 03:00:08 pm »
What kind of joysticks are you using?
Ghoul
  • Last login:September 15, 2004, 08:59:06 am
  • Karate Fish Master
« Reply #2 on: May 20, 2002, 03:40:30 pm »
I'm not sure I follow.
If you are just using two joysticks you don't need any special settings do you? Mame should run fine by mapping the joystick to the corresponding mame defaults.
I think dual joysticks are for games like robotron.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: May 20, 2002, 10:25:34 pm »
What is this controller box?  What joysticks?  If these are standard 8-way joysticks hooked up to a keyboard hack then telling Mame you are using 2 joysticks would fail.  Mame is thinking you mean analog joysticks hooked up to the analog port.
OzStick
    • OzStick Website
« Reply #4 on: May 20, 2002, 11:09:07 pm »
OK Guys, I'm glad I got a few replies but very sorry for creating some confusion!! I will clarify my problem.
I have built a cocktail cab with 1 joystick and 3 buttons on each side of it. The joystick and first 2 buttons on each side are wired to a joystick extension cable as joysticks 1 & 2, buttons 1,2,3 & 4, which is all plugged into the soundcard. The 3rd button on each side along with 3 function buttons are routed to a keyboard hack, which of course is working fine.
The cab runs DOS and MAME via ArcadeOS, and works OK if I configure it to run a 2 or 4 button joystick. Naturally because I've wired up 2 joysticks to the relevant inputs of the joystick cable (done it literally dozens of times before so wiring is not the problem) I would like to get both working.
The trouble is, when I select "Dual" under Joystick in ArcadeOS, neither of the joysticks work!
I have done some tinkering around in the past with this exact setup and managed to get it all working, but now I'm stuffed if I can remember what I did!
Does anyone know of a DOS utility that can test and calibrate joysticks, similar to what occurs in the Game Controllers applet in Windows? It needs to be able to detect 2 joysticks.
Any help would be well appreciated, as I'm at the stage where I need to 'rehack' the keyboard to include D,G,R & F for the 2nd stick.
Cheers,
ChrisW
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
« Reply #5 on: May 21, 2002, 08:17:47 am »
soundblaster cards (sb, sb16 and I think awe32) used to ship with a joystick calibration utility in their install directories.  if you have sb dos drivers loaded, go look for .exe's in the directory.
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
Thenasty
  • Last login:Today at 11:38:03 am
« Reply #6 on: May 22, 2002, 03:09:08 pm »
I had similar problems before detecting DUAL joystick (Gravis Gamepads) with MAME in pure DOS. I had a SB16 card using the the joystick port and a splitter. I can only get one Joystcik to work. Luckily, I have the Automatic Gamecard III  joystick card that has 2 josytcik port and I use that, and bingo, MAME recognizes DUAL joystick. Now that I have upgraded my system and the MOBO hasno ISA slot, I no longer need the Gamecards. I have 2 of them (Check the For Sale Forum).
Good luck....
Free VGA Breakout Cable
OzStick
    • OzStick Website
« Reply #7 on: May 22, 2002, 09:07:22 pm »
Thanks to everyone for your feedback - I will try Elkor's suggestion when I get a chance as I reckon that may be the key.
Cheers,
ChrisW
