Author Topic: WTB: Robotron centering grommets  (Read 2049 times)
DaveStall
  • Last login:February 19, 2021, 05:56:25 am
« on: October 15, 2004, 07:11:56 am »
I'm looking for a pair of centering grommets for my Robotron machine (Wico joysticks).  I know these are getting hard to find and this is probably a common request, but if anybody has some of these available please let me know.
Thanks,
Dave
Thenasty
  • Last login:Today at 10:41:12 am
Re:WTB: Robotron centering grommets
« Reply #1 on: October 15, 2004, 08:40:15 am »
are they the same size a the Pacs ? if so maybe this is it.
http://www.centsibleamusements.com/index.asp?PageAction=VIEWPROD&ProdID=386
Free VGA Breakout Cable
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #2 on: October 15, 2004, 09:52:17 am »
They are definately NOT the same size as pacs.  You need an old wico centering grommet. They are rather expensive when they show up on ebay.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
DaveStall
« Reply #3 on: October 15, 2004, 09:53:05 am »
From the looks of that picture, the Pacman grommet probably has a smaller center diameter than those used on my Robotron.  If somebody found a way to make these things, they would make a fortune.
Dave
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« Reply #4 on: October 15, 2004, 04:46:28 pm »
Dave
I have two NOS Wico centering grommets that are exactly what you are looking for.   Would be willing to part with them for $30 shipped.  Let me know.
Thanks,
Todd
Thenasty
« Reply #5 on: October 15, 2004, 04:47:52 pm »
if its only the diameter of the HOLE for the shaft to go in, can't you BORE/DRILL some to make the hole bigger so the ROBOTRON sticks fits in ?
DaveStall
« Reply #6 on: October 15, 2004, 07:13:06 pm »
Dave
Thanks,
Todd
That sounds fantastic to me.  I will PM you so we can set something up.  Thanks!
Dave
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: October 15, 2004, 09:08:52 pm »
I've mentioned this before... I'm pretty sure the grommets used in those old Home controllers Wico made are the same. I have opened up "Command Control" joysticks (the red and black kind) and they appear to be exactly the same, though I have not done a swap. (Maybe I could this weekend just to confirm).
You can find these controllers in thrift stores for a buck or two. On Ebay, as low as maybe $5. I think it's worth doing this because home joysticks didn't see nearly as much abuse as arcade joys, so chances are the grommets are in excellent condition. Add to that the fact that they are in side a closed plastic casing, they are not exposed to dust and other factors that could cause them to dry and crack.
NO MORE!!
DaveStall
« Reply #8 on: October 15, 2004, 09:27:13 pm »
Ray,
I am pretty sure you are correct that the grommets in the command control sticks would work.  But, I think that idea has started to catch on, as I have been seeing these sticks go for around $10 each on Ebay recently (unless there are lots of retro computer gamers in need of new sticks).  If I can get N.O.S. grommets for a little more it's worth it to me.  I am still hoping to get my hands on a command control stick so I can see for sure if the grommets are the same (you can never have too many spare parts  ;D ).  It is a great suggestion, and if I do get a stick for a low price I will be sure to mention what I find here.
As far as boring out a Pacman grommet, I think the real problem is that the grommets (both Pacman and the Williams style) have a metal bushing in the center that sort of forms a convex shape where the joystick enters.  Trying to get the grommet drilled out to the exact size to put a different bushing in while creating the correct shape might be difficult, but it is an interesting idea.
Thanks again for everyone's help!
Dave
« Last Edit: October 15, 2004, 09:27:59 pm by DaveStall »
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #9 on: October 16, 2004, 08:58:20 am »
RayB,
I can confirm this because I just swapped one and tried it. They are the *exact* same grommets down to a tee ! The Wico Command Control stick that I pulled the grommet from was the bat style handle with a white fire button on top. I don't have any with the ball top handle but I would bet that they're the same as well.
Good find RayB ! :)
"Sinistar has bad breath"
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #10 on: October 16, 2004, 10:46:56 am »
i think I have a bunch of busted wicos in a box. might be good for the gromets.. lemme check
I had to repl;ace them in my robotron, but i had new wicos in there boxes ;)
« Last Edit: October 16, 2004, 10:47:38 am by delta88 »
