Author Topic: Help me out  (Read 3572 times)
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
Help me out
« on: October 13, 2004, 12:32:26 pm »
I am going to make an arcade machine.
so i have decided to use Dmame(pure DOS).
i have got some problems..
q:1)Does it require windows installation support ?
q:2)I don't understand how to do these settings ?
a)Autoexec.bat tweaking.
b)config.sys editing.
b)Perfomence (RAM) tweaking.
c)CWSDPMI for Dmame.
Please write in your own words that what should
i do in the beggining ? STEP BY STEP.
after doing this i will also use a frontend.
This is the very first time i am trying to run
Dmame,Your guidence will be a pleasure.
Thanks in advance.. :)
BLUE BIRDS FLY WITH BLUE BIRDS
Grasshopper
Re:Help me out
« Reply #1 on: October 13, 2004, 01:57:23 pm »
It would take a book to explain how to configure msdos!
But my first question would be have you got hold of a set of msdos installation disks yet. Later versions of dos had quite a good installer that set up usable defaults for config.sys and autoexec.bat.
If you've got Windows 98 (or 98se) then an easy way to set up a working dos 7 installation (and still have access to windows if you need it) is to do the following:
Install win98 in the usual way.
There will be a file called msdos.sys in the root directory of c which will be hidden by default.
Unhide it and load it into notepad.
Edit the BootGUI line to say BootGUI=0 then save the file.
The machine will now boot to a pure dos 7 prompt.
You can still use windows by typing win followed by return.
This doesn't answer all your questions but it's a good starting point.
coldrain
  • Last login:October 29, 2004, 06:42:33 pm
  • INSERT COIN..!
Re:Help me out
« Reply #2 on: October 13, 2004, 03:08:17 pm »
I have a machine set up in the above way with the GUI disabled and a line on my autoexec.bat file to boot into arcadeOS frontend. My problem is geting my soundcard to work. I have a creative labs PCI128 (model CT4740) and all works fine if I run from within windows 98se (using arcadeOS and dmame) but I get an error message that reads " AUDIO INITALIZATION FAILED, UNABLE TO INITIALIZE SYSTEM" when arcadeOS trys to run mame stright from a dos boot.? I think I need to add a few lines to my AUTOEXEC.BAT file to tell mt machine what soundcard and where but I am unsure what..? Does anyone know.?
ries
  • Last login:April 29, 2006, 04:29:51 pm
  • MAME junkie for years
    • My personal website
Re:Help me out
« Reply #3 on: October 13, 2004, 04:02:15 pm »
my guess is that you forget to tell the dos apps what you soundcard settings are using the set blaster= command. Have a look at this website for a far better explaination;
http://www.mameworld.net/dosmame/setup.php
hope this helps!
coldrain
  • INSERT COIN..!
Re:Help me out
« Reply #4 on: October 13, 2004, 04:46:01 pm »
Thankyou, thankyou, thankyou.
It helped a lot. Problem solved.  :D
KHAN
Re:Help me out
« Reply #5 on: October 14, 2004, 08:11:17 am »
Same problem i have got.
but i have done some things for correct it..
now the error is going to be changed ...
"WARNING: Cannot open swapfile c:
LOAD ERROR : NO DPMI MEMORY
I think some thing to do with DPMI but don't know yet..
what is swap file ? i don't get it...
KHAN
Re:Help me out
« Reply #6 on: October 14, 2004, 08:14:24 am »
which version of CWSDPMI require? swap file ? ???
Chris
    • Chris's MAME Cabinet
Re:Help me out
« Reply #7 on: October 14, 2004, 11:05:25 am »
Drop a copy of CWSDPMI.EXE in your MAME directory and you should be set. MAME will find it and load it.
« Last Edit: October 14, 2004, 11:05:51 am by Chris »
--Chris
KHAN
Re:Help me out
« Reply #8 on: October 14, 2004, 01:48:52 pm »
I alredy put the cwsdpmi4.exe in the mame folder.
the error given below remains ...
does i need cwsdpmi5.exe
Chris
Re:Help me out
« Reply #9 on: October 14, 2004, 01:52:59 pm »
If it's called cwsdpmi4.exe, MAME won't find it.  Rename it to cwsdpmi.exe.
--Chris
--Chris
KHAN
Re:Help me out
« Reply #10 on: October 14, 2004, 02:03:56 pm »
it name as "cwsdpmi.exe" :P
I was just telling about the version.. :-\
because i know that the version 3 is use for 32mb or greater ram
and version 4 is use for 64 + ram. now version 5 should be 128 +.
so i have 128 mb DDR ram...
problem is problem....
waiting for Coldrain because he has solved his ...
KHAN
Re:Help me out
« Reply #11 on: October 15, 2004, 06:34:49 am »
I am unable to get rid of this errot...
I have same problem that sound in windows looks perfers but when it comes
to DOS...no sound...
another problem is the time of loading a game is slower than command line mame...and games also run slow ...as compared with dMAME in windows.
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:27:24 am
Re:Help me out
« Reply #12 on: October 15, 2004, 07:49:50 am »
as far as your cwsdpmi4.exe, maybe that file is ZIP Self-Extracting. Renaming to cwsdpmi.exe won't do it.
just use the latest version of cwsdpmi which is I think 5b. Make your it is UNZIP or if you get a self-extracting EXE, run it.
For DOS SOUND to work, you need to install your card DOS SOUND DRIVERS.
make sure you have in your autoexec.bat
SET BLASTER=A220 I5 D1 H7 P330 T6
SET SBPCI= WHERE-EVER IT IS INSTALLED (If your card is
                     a Soundblaster )
SBINIT         (If it is a soundblaster card, this should
                     automatically be there)
« Last Edit: October 15, 2004, 07:54:08 am by Thenasty »
Free VGA Breakout Cable
KHAN
Re:Help me out
« Reply #13 on: October 15, 2004, 03:37:21 pm »
you are absolutely correct .
cwsdpmi problem was due to the wrong version,but now it is solved.
thanks for it....
the sound problem is still remains...
i also download the (sbpci and sblive) audio drivers for dos.
but they are not effective here.....
I have  P4 (INTEL D84FGLAD)mother board with a builtin
(SIGMATEL C-Mejor Audio) SoundBlaster.
As you are saying that i have to need a dos driver of my sound card.
Does i require specific (Dos) sound drivers for it ?
I am not getting a correct path for an autoexec.bat file whether
it is already install in windows.
Thenasty
Re:Help me out
« Reply #14 on: October 15, 2004, 04:13:20 pm »
Save yourself the HEADACHE looking for drivers for it and get yourself a Sb16 PCI card, its only around $15.00.
Most onboard sound will not support DOS driver. If you got a 16 Bit/ISA slot, then get a Soundbalster 16 ISA, it works wonderfully w/MAME. To stinking bad that MOBO companies decided to drop ISA in new MOBO's. Why can't they get rid of the Hi-Riser MODE and replace it w/ISA ? No one uses it anyway.
KHAN
Re:Help me out
« Reply #15 on: October 15, 2004, 08:39:14 pm »
To buy a another is not any more problem. :-\
my PENTIUM 4 Board has not contain ISA slot.
It means that as far as the world is going towards
forward the Hardware  Compatiblity going backward.
