Author Topic: DOS Mame and Joystick support - help?  (Read 5302 times)
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
« on: September 11, 2002, 04:07:21 pm »
I'm setting up a machine running pure dos, dmame and ADVMenu.  I want to use a mouse and an old pc joystick for input.  I have the mouse working good, but I'm confused how to get mame to recognize the joystick. It is an old Gravis Gamepad 4 button model.  I've plugged it into my soundcard port, and I set ADVMenu to support joysticks and it works in the FE, but when I get to MAME I don't get any response when mapping buttons (using TAB).  I've tried running dmame from the command line with options like:
dmame -joygamepadpro centiped
-and-
dmame -joyauto centiped
but have had no luck.  Do I need some sort of DOS drivers for the gamepad?  The game I'm replacing only has a few inputs, so I'm hoping to avoid buying an interface or a keyboard hack.  I think a gamepad hack would be much simpler if I can get the joystick recognized.  Thanks for any and all help!!
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:DOS Mame and Joystick support - help?
« Reply #1 on: September 11, 2002, 04:46:05 pm »
-and-
it should be dmame centiped -joy auto   (the important thing is the space after -joy then the joystick name   )
Not sure if ADVmame is different but fwiw   dmame gamename -joy sidewinder works for me in vanilla dos without any gamepad drivers... I DID have to enable my soundcard in DOS though.. in may case load the SB emulation and set blaster commands in my autoexec.bat
Hope that helps... good luck!
rampy
JLR2000
    • WWW
« Reply #2 on: September 11, 2002, 04:51:50 pm »
Thanks!  I do have soundcard commands in my Autoexec.  Looks like I was just typing the parameters in the wrong order! (DOH  ::) )  I am using dos mame, not AdvanceMame.  (Just using the AdvMenu DOS mame frontend).  Thanks for your help. Can't wait to try it tonite!!
Thenasty
  • Last login:February 26, 2026, 10:04:40 pm
« Reply #3 on: September 11, 2002, 07:16:54 pm »
for your need..
Dmame -4button gamename
Free VGA Breakout Cable
JLR2000
    • WWW
« Reply #4 on: September 11, 2002, 07:53:17 pm »
Thanks everyone for your help.....here's what I needed to do:
dmame gamename -joy 4button
also found out I can't edit the mame.cfg file in dos with the "edit" command.  I just copied it to a floppy and changed it with notepad on another pc.  Eventually, I just wiped out the mame.cfg and reran dmame with all the parameters I wanted:
dmame gamename -soundcard 1 -joy 4button -mouse
and a new mame.cfg was created. One thing to note: the soundcard option somehow was set to "-1" instead of "1". I just edited with notepad and replaced it.  Now it's good to go.  Thanks again everyone.. ;D
