Author Topic: degausing ??? can you use  (Read 1451 times)
Thenasty
  • Last login:Yesterday at 11:40:37 am
« on: August 26, 2004, 01:08:29 pm »
I had a broken Arcade Monitor and I have it thrown away. But before I threw it out, I took out the degausing unit around the monitor. Can you make something so you can use it as your degausing tool ? What power does it require ?
« Last Edit: August 26, 2004, 01:09:08 pm by Thenasty »
Free VGA Breakout Cable
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
Re:degausing ??? can you use
« Reply #1 on: August 26, 2004, 01:25:05 pm »
Well, for a professional grade degausing coil I think you'd be better of just buying one.  Considering I doubt you want to get into TV repair, I think you are better off shielding your CRTs or buying new ones than trying to mess around with degausers IMO.
Still in the collecting parts and ideas phase of cabinet building.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: August 26, 2004, 02:19:08 pm »
whammoed
  • Last login:Yesterday at 12:20:55 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: August 26, 2004, 02:20:37 pm »
Oscars site has all the info you should need:
http://www.oscarcontrols.com/degauss/index.shtml
MonitorGuru
  • Last login:October 05, 2005, 11:29:43 pm
« Reply #4 on: August 26, 2004, 02:40:11 pm »
Check the monitor forum (where this post should be/will likely be moved to) for info. I just posted a long reply about how to use a beefy soldering gun or bulk tape eraser to do the same thing.
Duty cycles on monitors/tv's are typically one use (not second) per every 20 minutes. However each manufacturer may be different.  The typical on time is about 3-4 seconds, not 1 second.
Oscar's hacked degaussing wand (and those that you buy professionally) incorporate a power limiting device, in the case of Oscar's, a small wattage light bulb.
You get degaussing effects by creating a large alternating magnetic field by coiling wire. It has nothing to do with running 15 amp or 1/2 an amp through it.
As you all know if you take a wire and short an AC outlet, the wire will burn up instantly if smaller than the wires leading to the outlet/fuse/circuit breaker, or will blow your fuse/circuit breaker if it is larger than that.  By placing a light bulb in the middle you prevent the coil from buring up instantly, though the effects of the AC power running through it still perform the task necessary--alternate a magnetic field to remove magnetism from metal parts including the shadow mask of the monitor.
Bgnome
  • Who's da gnome?
« Reply #5 on: August 26, 2004, 02:45:30 pm »
i remember sticking wires into ac sockets when i was younger..  usually got a big flash and a pop then all the lights would go out..
Thenasty
« Reply #6 on: August 26, 2004, 07:31:18 pm »
thanks fo the link guys. Gonna build one and give it a try.
