Author Topic: "homebrewed" coin door  (Read 1104 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
« on: July 18, 2004, 06:45:44 pm »
call me cheap (and you're probably right   ;) ) but could you make your own coin door by drilling a straight line into the side of your cab and then putting a pushbutton behind it so that when a quarter/coin/token was inserted it would hit the button which would be wired to an ipac in the insert coin slot? i can't figure how to put a coin return slot in it (and why would you need one? if whoever's using it wants their moeny back, too bad!!  ;D (seriously, though, i'd just give them a quarter) you could put the button back far enough so that if someone put a dime/nickel/penny in it wouldn't register. you could put a bucket in underneath so that quarters wouldn't be falling all over the place. plus, when i was just alone, i could have a thin stick and no need for quarters!  :D does anyone know anyone who has tried this or have any ideas on this?
Thenasty
  • Last login:Yesterday at 04:03:57 pm
Re:"homebrewed" coin door
« Reply #1 on: July 18, 2004, 06:54:58 pm »
I think you gonna need a BRICK for a coin cause any coin won't push that button for you.
What you can do probably is just to get a ULTIMATE COIN MECH and hack it to attach the COIN SWITCH at the bottom and drill a slot for coins to drop in and triggers the switch. Here is the link for the COIN MECH.
http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=19200
this will accept any coins up to the dollar size. So drill a SLOT in the side/front of the cabinet and somehow attach the coin mech ( which I think is easy to do, just revese it the screw it in the wood, so the COIN will drop right in the COIN ENTRACE of the MECH) to the wood/cabinet. Heh !! hope you go the picture.
Maybe you don't even need the COIN MECH, just the switch or make/get an optical switch and install this next to the slot you gonna make, so when the coin drops, it trigers the switch and registers.
« Last Edit: July 18, 2004, 07:01:47 pm by Thenasty »
Free VGA Breakout Cable
