Author Topic: Some rom help plzzzzz!  (Read 2497 times)
chuggy_20
  • Last login:June 24, 2004, 04:23:55 pm
« on: June 24, 2004, 04:26:39 pm »
I am assuming we dont talk too much about roms because i cant find much for past posts, i figured i try anyway.
My question is simple enough though, why is it that some roms work and some just dont. Street fighter 2, and nba jam are two examples of roms that dont seem to work. Others just work like a dream. any suggestions would be great.
Thenasty
  • Last login:Yesterday at 11:34:20 am
Re:Some rom help plzzzzz!
« Reply #1 on: June 24, 2004, 04:30:44 pm »
there are alot of reason why it don't work.
Questions are:
1. What version are you using ?
2. Did you update your ROMS if using a newer version ?
To make sure your ROMS are ok to the version of MAME your running is to use clrmame pro.
Remember that when uprading to a newer version of MAME, some ROMS will get updated hence that ROM(s) will not work with Newer version untill you get the updated ROMS (or fix it w/clrmame pro).
So my conclusion is, your running a new version of MAME w/older set of ROMS (thats why it worked w/older version of MAME).
Free VGA Breakout Cable
chuggy_20
« Reply #2 on: June 24, 2004, 05:14:12 pm »
ok so i just got the newest version of mame v .83.
So if i have the newest set of roms they should work without a hitch right? So i guess the next question is where do i get the updated roms?
I thought i had a firm grasp on this whole mame thing until i tried to update my files, and mame.dk was shut down.
mozzer
  • Last login:March 02, 2019, 10:38:25 pm
  • How Soon Is Now?
« Reply #3 on: June 24, 2004, 05:54:08 pm »
No one will tell you where to get roms on this board....
Read the rules...
The web is flooded with info about roms...
You shouldn't have too much trouble.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #4 on: June 24, 2004, 09:19:02 pm »
98% of the time, the ROMs themselves don't change, but the names do.  This happens when they update the names of the ROMs more accurately with what they actually are in the game itself.
The other 2% is usually when a ROM is redumped for a better copy, or if the ROM never existed before (some color PROMs are just guessed at)
You would want to use a ROM manager, such as ClrMAME to note and make these changes to sets.
chuggy_20
« Reply #5 on: June 24, 2004, 11:01:37 pm »
so i dont need to update the file, just the name? I'll look into clrmame, thanks for all your help!
chuggy_20
« Reply #6 on: June 25, 2004, 12:15:03 am »
OK so i understand now, but it still is not working. Im running v .83 with the newest version of game launcher. when i try opening certain games the screen just turns black. I changed to debug mode, and found that GL was closing the games before they are opening. I am positive im using the newest rom and newest mame, what else could it be? I hope someone knows, cuz i dont! lol
Thenasty
« Reply #7 on: June 25, 2004, 12:18:07 am »
try running the game in the command line so you can see the exact error MAME gives you.
MAME GAMENAME
or you can check the roms if its good by
MAME GAMENAME -verifyroms
chuggy_20
« Reply #8 on: June 25, 2004, 12:42:43 am »
well apparently it s a game launcher problem. Should have guessed, i'll try a new front end and see if that helps.
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
« Reply #9 on: June 25, 2004, 01:23:05 am »
I'm a huge fan of NoNameMame, it runs in windows.  Try that
http://noname.kitsunet.org/
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: June 25, 2004, 07:31:19 am »
Not the problem!!!!
Don't get me wrong - NoNAME is great - My personal favorite build - but it ADDS a bunch of complexity to MAME.
If Vanilla MAME won't run his games, NoNAME will only make things worse . . .
OTOH, once you get Vanilla MAME set-up and running and understand it, then I highly recommend checking out NoNAME.
MnMCaputo
« Reply #11 on: June 25, 2004, 02:05:12 pm »
Gotcha  ;D   I was tired last night when I wrote that, I'm seeing more clearly now   lol
