Author Topic: How many buttons for a 4 way joystick panel?  (Read 5494 times)
Apollo
    • Eight Bells
« on: May 14, 2004, 02:52:34 am »
OK so I'm just about to drill my 4 way joystick panel. It has 2 MsPac/Galag 4 ways and will be used for all the classic 4 ways, PacMan, Donkey Kong etc and for 2 player Bomberman ( don't ask, my brother in law loves it ) and Karate Champ.
My question is how many buttons should I have for a 4 way stick and are there any other games that use 2 X 4 ways ( either 2 player or 1 player ).
Thanks.
JustMichael
  • Mmmmm!! Cheesecake!!
Re:How many buttons for a 4 way joystick panel?
« Reply #1 on: May 14, 2004, 06:42:49 am »
I would suggest 2 buttons per player in this case.  That should cover most "classics".
« Last Edit: May 14, 2004, 06:43:41 am by JustMichael »
Apollo
    • Eight Bells
« Reply #2 on: May 14, 2004, 06:46:04 am »
Then why do I see 4 way joys with 3 or even 4 butttons sometimes?
Thanks for your reply by the way.
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
« Reply #3 on: May 14, 2004, 08:05:57 am »
there's only a handful of 4-way games with 3 buttons:
check out this Sortinfo Search
And only five 4-way games with 4 buttons. Not including any clones.
ericball
  • Last login:March 13, 2025, 11:01:47 am
« Reply #4 on: May 14, 2004, 11:37:36 am »
Unfortunately, MAME's listinfo is not as accurate as it might be.  There are a bunch of joy8way games which were actually 4way, 2way or even button only.
For my control panel I'm going with 3 buttons in an inverted triangle.  Not because there are a lot of 3 button games out there but then I can use the bottom button for games which only use one button.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #5 on: May 14, 2004, 12:34:43 pm »
I would put three on there as well.
AmericanDemon
  • The Reason the short bus was invented... 100% Slacker Guaranteed, 4:20 yet?
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
« Reply #6 on: May 14, 2004, 01:46:25 pm »
You have to take into consideration what the older Jamma games could handle as well.  True classics are Pre-jamma, but they are the reason for the invention of Jamma.  A Jamma Harness has fire positions for three buttons per player.
Don't forget Karate Champ uses two sticks per player and no buttons.
BJallow
  • Last login:March 12, 2004, 05:46:08 pm
« Reply #7 on: May 14, 2004, 02:15:57 pm »
I used 4 buttons, since I enjoyed Mouse Trap on the Atari and thought I'd play the arcade version.  Truth is, I rarely play it.
Lilwolf
« Reply #8 on: May 14, 2004, 02:44:49 pm »
btw... take a look at the games.
There probably arent' going to be that many games which will be added with 4way controller + 4+ buttons
so see what you will be missing if you only add 3...
I personally LOVE super punchout!
paigeoliver
  • Awesome face!
« Reply #9 on: May 14, 2004, 05:40:10 pm »
2 buttons unless you want to play Mouse Trap, in that case it is 4.
I went through the ENTIRE 4-way list game by game to determine this (the TRUE 4-way list, not the incorrect sortinfo list). There are a couple other games besides Mouse Trap with more than 2 buttons, but each and every one of them is complete garbage (a terrible Tennis game, and a couple of Mahjonngs).
Thenasty
  • Last login:January 29, 2026, 11:38:03 am
« Reply #10 on: May 15, 2004, 11:49:24 am »
I suggest 4 buttons in diamond setup pattern liek the game "Vanguard"
You can however start with the 3 inverted triangle as mentioned then you have room to the 4th one being a diamond shape for "Vanguard" it is very playable as an 4-way setup.
Free VGA Breakout Cable
paigeoliver
  • Awesome face!
« Reply #11 on: May 15, 2004, 05:09:03 pm »
Vanguard is an 8-way game. I actually usually play it dualjoy myself.
adder
« Reply #12 on: December 02, 2014, 11:26:35 am »
Quote from: paigeoliver
2 buttons unless you want to play Mouse Trap, in that case it is 4. I went through the ENTIRE 4-way list game by game to determine this (the TRUE 4-way list, not the incorrect sortinfo list). There are a couple other games besides Mouse Trap with more than 2 buttons, but each and every one of them is complete garbage (a terrible Tennis game, and a couple of Mahjonngs).
and so 10 years later... ;) are we still kind of agreement on this? as im thinking of building a 4way joystick box but only have 2 spare pushbuttons. so 2 buttons should cover the classics?
  • Last login:Today at 07:02:00 pm
« Reply #13 on: December 02, 2014, 11:35:24 am »
Yep. My 4-way only classics cocktail has 2 buttons and like 90 games.
Saneless
  • Last login:September 19, 2015, 12:29:26 pm
Re: How many buttons for a 4 way joystick panel?
« Reply #14 on: December 02, 2014, 11:59:18 am »
I have 2 in my 4-way area, but I guess if I had to use more I still have my standard 8 way with 7.
I'm not sure I've even used more than 1 button in any game I've played.
nitrogen_widget
« Reply #15 on: December 02, 2014, 12:22:04 pm »
I'm building a 4-way vertical that I originally bought 3 buttons for.
i'm going to go with 2 now.
I'm using an old PC with an old version of mame.
My list started at about 150 long & it has been whittled down to 110 & that's because I only had time to figure out I hated 35 of those 40 games I tried. :)
« Reply #16 on: December 02, 2014, 12:46:02 pm »
Most games usually have 2, but I choose 3 only please I play Punchout pretty often.  However, you can get away with 2 if you re-map player 2 start to be the Uppercut.  I did that on my first vertical machine which only had 2 buttons.
D
« Reply #17 on: December 02, 2014, 12:57:03 pm »
A few more - Dambusters is one, Iron Horse is another. If you really want to scrap the barrel, there is Chinese Hero as well.
Go with 2 buttons.  8)
« Reply #18 on: December 02, 2014, 01:01:18 pm »
On the other hand, if you only do 2 buttons, you won't be able to play Omega Race the right way...  >:D
adder
« Reply #19 on: December 02, 2014, 01:52:30 pm »
Quote from: Vigo
.... Iron Horse is another....
---steaming pile of meadow muffin---, i quite like that game  :)  3 buttons it is then  ;D
« Last Edit: December 02, 2014, 06:40:35 pm by HaRuMaN »
adder
« Reply #20 on: December 02, 2014, 01:54:02 pm »
actually i notice on klov that iron horse is listed as an 8way game?
hmm
http://www.arcade-museum.com/game_detail.php?game_id=8206
« Reply #21 on: December 02, 2014, 03:15:56 pm »
Yeah, I'm not sure.... I see from arcade history that it is 4 way.
http://www.arcade-history.com/?n=iron-horse-model-gx560&page=detail&id=1203
 :dunno Might be a game that is 4 way, but there is no advantage of using a 4 way joystick.
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #22 on: December 02, 2014, 03:23:12 pm »
The only game I can think of that I use all 3 buttons would be Bank Panic.
Minwah
    • MAMEWAH
« Reply #23 on: December 03, 2014, 07:59:19 am »
I agree, worth having 3 buttons for that one!
paigeoliver
  • Awesome face!
« Reply #24 on: February 26, 2015, 03:39:45 pm »
Dedicated 4-way cabinets are normally done vertically, as the vast majority of 4-way games are vertical in nature. Punchout isnt a vertical game, neither is Omega Race, nor is Bank Panic. Omega Race also doesn't use a joystick.Punchout's dual screen nature makes supporting it a nightmare anyway, regardless of machine.
Dambusters is an odd case. By everything that is holy it SHOULD be an 8-way game, but it isn't. It does however handle 8-way input rather well for a four way game, always defaulting to the new direction when it encounters a diagonal.
I am not sure it is worth installing a 3rd button is worth it just for bad Scramble clone and Bank Panic.
