Author Topic: Preventing damage to an arcade monitor?  (Read 1436 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: May 12, 2004, 05:02:56 pm »
I am a little confused on this issue.  I know how to set up arcadeos and advmame for use with an arcade monitor but how does a person prevent damage to the monitor during the boot up process?  For the record I am planning on using a J-Pac so I won't have to worry about it but I assume there is a way to get by without the J-Pac because I have seen websites that explain how to hack a vga cable to be used with an arcade monitor.  What I haven't seen is an explanation as to how to prevent damage to your monitor while it is displaying dos before loading the front end.  Thanks in advance.
Thenasty
  • Last login:January 25, 2026, 04:03:57 pm
Re:Preventing damage to an arcade monitor?
« Reply #1 on: May 12, 2004, 05:29:21 pm »
some ppl wiat till the FE is booted up and then turn the monitor on, but I don't do that. Since I use PURE DOS as my OS, I just turn everything on at once. I have been doing this for 1 year not I have not seen any damage done to my monitor. Maybe cause my BOOT proecess does not take that till my FE kicks in w/ 15khz frequency.
Free VGA Breakout Cable
mattv
  • Last login:June 10, 2022, 06:33:25 am
« Reply #2 on: May 13, 2004, 03:49:32 pm »
Most frontends can be configured to play a sound when it is safe to turn the monitor on. Some frontends also have a feature to turn the monitor on via the paralell port once the card is outputting in 15khz mode.
Most people are using a jpac or arcadevga these days - I think your plan to use a jpac is a good one
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #3 on: May 13, 2004, 04:15:11 pm »
You can use the monarc.sys utility to boot to 15KHz right off the bat.  Make it the first line in your config.sys and you should not have any problems.
