Author Topic: removing lock from coin door w/o key  (Read 1679 times)
nomad
  • Last login:March 31, 2007, 04:15:28 pm
« on: March 21, 2004, 07:02:31 pm »
Hello, I was wondering if anyone knows a way in which to remove a lock from a coin door (like one purchased from eBay) without the key and without messing up the door?
Thenasty
  • Last login:October 31, 2025, 09:36:31 pm
Re:removing lock from coin door w/o key
« Reply #1 on: March 21, 2004, 07:15:08 pm »
open up the back door. Sometimes you can do it from there specailly if your coin door is an UP/DOWN.
Free VGA Breakout Cable
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #2 on: March 21, 2004, 09:52:17 pm »
get out your drill and a bit and drill it out.
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: March 21, 2004, 10:07:09 pm »
If you can get to the back of the coin door, the lock is no problem.  On my cabinet, you just unscrew a screw on the back of the lock, remove the metal bar and then loosen the nut that holds the lock in the coin door.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #4 on: March 21, 2004, 10:16:20 pm »
Sound like he has just the lock.  Unscrew the back of the lock (there should be a screw there) and remove the cam.  Then, there should be a nut that holds the unit to the door.  Unscrew that, you may need pliers (I like to use a pair of vice grips.)
Then replace the lock.  I know a guy that has them.  ;)
MinerAl
  • Last login:January 27, 2025, 07:02:58 pm
  • duck
« Reply #5 on: March 22, 2004, 12:35:51 am »
Shotgun.
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #6 on: March 22, 2004, 12:44:24 am »
 If you can't get to the back of the lock, you can try the old screwdriver trick.  Just insert a screwdriver and turn hard until it moves 1/4 turn.  Typically these locks are not that good, so that works.   Then you can remove the lock and replace it.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: March 22, 2004, 10:18:27 am »
Is the door already installed on a machine or did you just buy it and haven't put it on?
nomad
« Reply #8 on: March 22, 2004, 03:21:11 pm »
I am thinking about purchasing a coin door from ebay and the guy does not have the key for the one I am interested in.  So I was just wondering how one would go about removing the lock.  Thanks for the replies :)
Thenasty
« Reply #9 on: March 22, 2004, 03:31:35 pm »
Easy:
1. Remove the NUT
2. Remove the CAM
3. REMOVE another NUT under the CAM
4. Pull it out.
5. Replace w/a new one.
Ken Layton
  • Guru
  • Technician
« Reply #10 on: March 22, 2004, 06:44:29 pm »
After removing the old lock then you go to the harware store or a lock shop and buy another lock and key.
