Author Topic: Several games not working  (Read 2005 times)
Chemixtry
  • Last login:January 22, 2021, 07:58:17 pm
  • If an experiment works, something has gone wrong
« on: March 17, 2004, 04:51:58 pm »
I am running MAME 79 and Mamewah frontend on a 750mhz PC. There are some games that just don't work. When I try to run them I just get a black screen. No error message, nothing. I can push escape and I get back to Mamewah. Some of the games are asteroids, spyhunter, xenophobe, and rampage. These games surley can't be to fast for my system since I can run much newer games.  Is there some mystery setting I need to use to get these to work?
Experience is directly proportional to equipment ruined
Tiger-Heli
    • Tiger-Heli
Re:Several games not working
« Reply #1 on: March 18, 2004, 10:57:46 am »
Not sure if you're updating from a previous version or not.  Make sure your ROMS are correct for 0.79.  Make sure these games aren't broken in MAME0.79.
Not much of a pattern to the games, bad roms usally will flash a brief error message on a black screen and then MAME exits.  Odd that you seem to be saying the screen stays black until you Escape, though.
Chemixtry
« Reply #2 on: March 18, 2004, 11:11:43 am »
I've had this problem for a while now. I thought maybe I ahd downloaded some bad roms so I got an entire 0.79 set from a Lazarus burner. The same games still don't work. I tried different monitor resolutions but that didn't do anything. Any other suggestions?
Thenasty
  • Last login:Today at 02:07:16 pm
« Reply #3 on: March 18, 2004, 11:27:16 am »
try running them in the command line. Skip any frontends that your using and start from there.
Free VGA Breakout Cable
Chemixtry
« Reply #4 on: March 18, 2004, 11:44:10 am »
Still doesn't work
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #5 on: March 18, 2004, 01:29:40 pm »
Sounds like you got some bad roms then, just because a Lazarus burner did it, doesn't mean it's always going to be perfect unfortunately.
I had the same issue a while back, got some new roms, and bam, the games worked again....
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #6 on: March 18, 2004, 03:37:03 pm »
Make sure you have "show dos box to auto" in mamwah settings, the dos window gets hidden if you don't and mame may be asking for you to press a key or something.
Cave
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #7 on: March 18, 2004, 07:01:44 pm »
If the ROMs were bad, there would likely be warnings.
Try changing the games resolution.
Chemixtry
« Reply #8 on: March 19, 2004, 01:06:55 am »
When you say games resolution do mean monitor resolution because I tried that. If not could you explain to me how to do it?
mnm
  • Last login:April 05, 2004, 09:23:14 am
  • I'm NOT the one who is outside!
« Reply #9 on: March 19, 2004, 01:33:25 am »
I have a problem with some, not all, of the vector games, they run at a resolution that is too high for my monitor (it puts up a box saying out of range).  If they have some artwork around them eg. Battle Zone, they work fine.  If I run them from a command line and get them to come up in a window, they work correctly, so I'm not sure why they are trying to select such a high resolution.
Martin
[Insert something witty here]
Chemixtry
« Reply #10 on: March 19, 2004, 01:57:34 am »
Thanks Peale!!!! ;D ;D ;D When I changed the mame.ini file resolution to 1024x768 all the games that didn't work before worked just fine.
SirPeale
« Reply #11 on: March 19, 2004, 08:24:37 am »
I had the same problem with some of the games you mentioned, so I figured that was your problem.
« Last Edit: March 19, 2004, 08:39:52 am by Peale »
