Author Topic: Centipede 19" Monitor Bezel Template  (Read 2636 times)
frankrizzo2
  • Last login:August 09, 2025, 03:52:53 pm
« on: January 03, 2025, 01:03:05 am »
Here is a template that I drew up for a standup Centipede Arcade monitor bezel as I couldn't find one anywhere. It won't be perfect but it's a lot better than having nothing. I just used poster board from Hobby Lobby. All the areas marked in green I scored with an exacto (not all the way through) and the red lines are crease lines without the scoring. Then bend the flap (top right) and use a little elmers glue or wood glue to attach the flap behind the front facing poster board.
processedmeat
  • Last login:February 22, 2026, 01:43:46 pm
  • Ikeakade Here I come!
Re: Centipede 19" Monitor Bezel Template
« Reply #1 on: January 03, 2025, 02:23:33 pm »
Thanks Frank for sharing this!  Will be putting this template to use in the future.
