Author Topic: Pac-Pro joystick - Any way to reduce throw length?  (Read 1695 times)
sroberts
  • Last login:February 12, 2026, 05:38:49 pm
  • Will my game cabinet ever be finished??
« on: May 12, 2023, 09:26:25 pm »
My Pac-Pro joystick works really well with PacMan, Frogger, et al, but the throw length is too long compared to the original Midway Packman joystick. Are there any mods I can make to reduce the throw length?  Maybe build a restrictor plate?
I'd be interested an original Midway joystick if anyone has a source, but I do not want to play the eBay lottery.
Thenasty
  • Last login:February 26, 2026, 10:04:40 pm
Re: Pac-Pro joystick - Any way to reduce throw length?
« Reply #1 on: May 14, 2023, 01:15:48 pm »
I have Pac-Pro and nothing beats the original Midway 4-way stick.
I had the Pac-man stick but was to large of a footprint for my already over crowded control panel, so I sold it.
Until now, still crossing my finger that someone has a smart machine to take the original and somehow cut everything in half (stick, base, leafs etc... except for the ball).
I'll buy one in a heartbeat (I don't care if it cost $50.00)
Free VGA Breakout Cable
  • Last login:Today at 11:28:34 am
    • GroovyGameGear.com
« Reply #2 on: May 16, 2023, 12:15:20 pm »
The Pac-Pro already has pretty short shaft, which of course, is necessary for a short throw.  A top-mounted restrictor plate may be enough, but modifications of this nature do not exist in a "vacuum."  All of the parts and the positions for those parts, are designed with all of the other parts in mind, to balance things out and make things work properly.  You may find that adding a restrictor would not only require a different diameter shaft and/or adjustment of the switches, but may also require a different diameter actuator.
IOW, it can be done, but changing something could open a "can-of-worms" best left unopened.
It sounds like a Leaf-Pro stick with the 4-way restrictor might be more to your liking.  However, this stick uses a different mounting pattern, so an adapter would be necessary to use the same mounting footprint as the Pac-Pro.
