Author Topic: 3D Printable Atari Volcano buttons  (Read 8211 times)
ids
  • Fighter Captured
« on: February 17, 2023, 09:56:34 pm »
Using OpenSCAD, so you can pick any CP thickness, any button height/width, lit with 3mm led, and uses standard microswitches: https://www.thingiverse.com/thing:5856985
Can select compatibility with standard button wrench or a simpler basic design.
Time to re-do all my control panels!
« Last Edit: February 17, 2023, 10:14:23 pm by ids »
Re: 3D Printable Atari Volcano buttons
« Reply #1 on: February 18, 2023, 11:54:02 am »
This is awesome... I think I paid $30 for a pair of the repros.
  • Last login:February 27, 2026, 02:29:01 pm
ids
  • Fighter Captured
« Reply #3 on: February 18, 2023, 01:33:58 pm »
Slicer tells me this is about $0.30 worth of PLA for one - add cost of microswitch and LED, could make at least 15 of these for the price of a repo, and not have to worry about how to fit it to your CP  ;D
Most of the libraries around me print for free, so you save that $0.30 as well.
ids
  • Fighter Captured
« Reply #5 on: February 18, 2023, 02:32:34 pm »
https://www.arcadeshop.com/d/95/start-buttons.htm
So I paid $40 for the pair haha
They don't ship directly to Canada, so hard to say what the total cost would be for me.
I just printed some cones at 0.08mm layer height and they look fantastic.  4 for ~$0.15
« Reply #6 on: February 18, 2023, 06:21:10 pm »
Can the printed button be sanded and painted to look like metal?  3D prints always have that rough look to me.
ids
  • Fighter Captured
« Reply #7 on: February 18, 2023, 07:06:51 pm »
Yes, sanding and painting are options.  I don't think the latest prints I did at 0.08mm layer height would benefit much, unless you would want a more metallic sheen.  You're right that 3D prints typically look rough.  I understand that resin printers are much better but have no direct experience with those.  I've attached a pic here of my latest cone prints - not the usual rough look.  Could apply some metallic paint perhaps.  The push-button part is a little bit rough - I'm going to experiment with that, 100% infill, 0.08mm layers, etc, see how good I can get them.
« Reply #8 on: February 18, 2023, 09:38:01 pm »
The texture seems like an easy fix.   Put the button in a lathe or drill press and hold some sandpaper to it.   Fantastic job.
ids
  • Fighter Captured
« Reply #9 on: February 18, 2023, 10:14:51 pm »
I think I'm good with the look tbh, but to each their own.  Had considered applying a metallic glossy paint or something, but... happy with it the way it is, with no sanding, painting,....  Would really need a bright light and close examination before suspecting anything but mass produced.
« Last Edit: February 18, 2023, 11:20:39 pm by ids »
« Reply #10 on: February 18, 2023, 10:45:13 pm »
Yeah. That looks pretty good.
« Reply #11 on: February 19, 2023, 12:44:36 pm »
Wow.  It really looks great.  No touch up needed and if someone was looking for blemishes they would still have a hard time finding any.
« Reply #12 on: February 19, 2023, 11:06:15 pm »
That does look good. I am like Javery - I paid a good deal for my Tempest cabinet. I would've been happier with those.
ids
  • Fighter Captured
« Reply #13 on: February 20, 2023, 09:33:19 am »
sweet cab - love tempest, it's the primary reason I got a spinner.
You've inspired me - in order to attach the cone to a drill, per:
I've modelled a  shank attachment - screw on the cone and you're good to go:
(default is a quarter inch hex, but is customizable - thingiverse updated)
If the lazies don't win, I'll see about getting the cones to have that metallic appearance.
ids
  • Fighter Captured
« Reply #14 on: February 20, 2023, 10:20:09 pm »
added a customizable, drop-in "washer" as well, to help cover traditional button holes
Ginsonic
  • Last login:January 12, 2026, 06:48:01 am
  • Arcade enthusiast !
« Reply #15 on: February 21, 2023, 02:19:40 am »
3D printing is the best friend of cabinet builders.
You can even print your items with resin, the results are fantastic! :)
Zeosstud
  • Last login:February 24, 2026, 05:32:44 pm
« Reply #16 on: February 21, 2023, 09:29:34 pm »
That is a fantastic add for the community, good for you. Enjoy!!
Zeosstud
danny_galaga
  • Last login:Today at 03:35:46 am
    • dans cocktail lounge
« Reply #17 on: February 25, 2023, 08:43:46 pm »
Easier to add 'ironing' in Cura and let the printer do the smoothing for you 🙂
« Reply #18 on: February 26, 2023, 10:21:40 am »
I downloaded this sleeve and printed it.
I have an Assault cab that some jackhole mutilated.
He cut a larger hole for P1 start and put a regular P1 start button in there.
I have the volcano shell that I need and a friend has the button. I am going to pick that up today.
I will send a pic when I put it all together.
It will at least let me use the correct button until I can buy some metal and fabricate a new CP for the cab.
Thanks.
ids
  • Fighter Captured
« Reply #19 on: February 26, 2023, 10:40:11 am »
Thanks.
Let me know if you need tweaks to the design to support a real volcano button and metal panel, as it was designed for the 3D printed parts with a thicker wood panel in mind
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #20 on: March 04, 2023, 12:00:21 pm »
I could probably print these in resin for people who need them. Really need to justify the expense of the printer to my wife.
  • Last login:Yesterday at 09:33:22 am
« Reply #21 on: March 04, 2023, 11:59:53 pm »
Monkeyvoodoo
« Reply #22 on: March 06, 2023, 12:58:58 am »
Shipping and a Cup of coffee?
