Author Topic: Tail Gunner - no sound  (Read 2543 times)
spisi
  • Last login:February 26, 2026, 05:36:58 pm
« on: December 02, 2022, 09:51:37 am »
I downloaded the rom for Tail Gunner and there is no sound.  I found a post about it from 2004, it seemed that they had fixed it in MAME back then.  Any info on this would be appreciated.  Thanks in advance.
Thenasty
  • Last login:Yesterday at 09:23:56 pm
Re: Tail Gunner - no sound
« Reply #1 on: December 02, 2022, 12:11:04 pm »
I Remember this game needed SAMPLES for sound.
Free VGA Breakout Cable
spisi
« Reply #2 on: December 02, 2022, 12:31:30 pm »
Can't find em anywhere...
spisi
« Reply #3 on: December 02, 2022, 01:03:46 pm »
  • Last login:Today at 12:48:14 am
spisi
« Reply #5 on: December 03, 2022, 05:30:55 pm »
Thanks Scott. Having trouble with this game saving high scores...
« Reply #6 on: December 03, 2022, 11:58:05 pm »
Hiscore plugin not working in Tailgunner for me, either, but I haven't dug into it.   :dunno
https://docs.mamedev.org/plugins/hiscore.html
- Running MAME from command line with -verbose might help you narrow down what is and is not working.
If you can't get the plugin working, save states are working for this game.
- Make a simple "tailg.ini" file like this that enables autosave.
# CORE STATE/PLAYBACK OPTIONS
autosave                  1
- It will throw an error the first time you run it with the new .ini because it didn't autosave last time you exited the game.
- Second time you run it, it should work.   :cheers:
- AFAIK the only downside to this approach is the momentary "State successfully loaded" popup window when you launch the game.
spisi
« Reply #7 on: December 04, 2022, 11:11:22 am »
That did the trick! The Mame Whisperer comes through yet again!  :applaud:
« Reply #8 on: December 04, 2022, 03:17:13 pm »
Glad to assist.   ;D
