Author Topic: A 3D Printed, Candy Cab-inspired Wall Mounted cabinet: Ascend  (Read 5856 times)
sealcouch
  • Last login:October 19, 2025, 07:08:59 pm
This is an idea that I've had bouncing around my head for quite a while.
After making this little Capcom Mini Cute bartop, I've wanted to make a full sized cabinet.
And I have been working on a little cyberpunk themed basement bar/home theater and it is currently without an arcade cabinet, despite having the perfect spot for one here:
Here's where the design stands currently:
I modeled it around a 23 inch 1440p monitor that I'm currently using.
I have an Ender 5 Plus, so theoretically, as it stands now it could be printed in 10 parts. but this is currently just a shell, with no consideration given to how it would be mounted.  I'm thinking I may end up making a wooden frame on the inside for stability.  I'd expect this is going to be a huge design undertaking but it's not impossible. Once done it would be cool to be able to share the files
I already designed the artwork for it, basically modified Astro City artwork.
I'd like to make it hug the wall a bit more. as it currently would stick out from the wall about 22 inches. Any feedback appreciated!
sealcouch
Re: A 3D Printed, Candy Cab-inspired Wall Mounted cabinet: Ascend
« Reply #1 on: July 24, 2022, 11:42:09 am »
Okay, now that I photoshopped it into place I really really want to see this through.
  • Last login:January 29, 2026, 07:33:48 am
« Reply #2 on: July 24, 2022, 11:50:23 am »
Is that your actual basement?
sealcouch
« Reply #3 on: July 24, 2022, 12:00:16 pm »
Yeah.
Here's a pic from another angle showing a little of the 120 inch projector screen. I really need to try to take some proper photos.
bobbyb13
  • Last login:Yesterday at 01:16:31 am
« Reply #4 on: July 24, 2022, 01:40:16 pm »
I dig the ceiling treatment.
« Reply #5 on: July 24, 2022, 01:42:58 pm »
That’s cool, I dig it.  Akira didn’t have a candy cab in it, though.
Zebidee
  • Last login:Today at 06:07:22 am
« Reply #6 on: July 24, 2022, 02:25:47 pm »
I used to work in a club that looked surprisingly similar.
  • Last login:January 29, 2026, 10:37:15 am
« Reply #7 on: July 24, 2022, 03:19:13 pm »
Cool basement dwelling. And the candy mockup looks great, look forward to seeing your progress.  :cheers:
sealcouch
« Reply #8 on: July 24, 2022, 03:54:53 pm »
Yeah. I put the stripper pole away....for now.
I decided to tilt it down a bit for control panel ergonomics then lobbed a few inches off the back. Now it's only 16 inches off the wall which is way less intrusive but now I feel like I have to redesign the bottom a bit.
Zebidee
« Reply #9 on: July 25, 2022, 02:48:56 am »
Oh is OK, I'm retired these days anyway. Is a good idea to keep a pole handy though, in case of emergencies!
Don't throw out the disco ball!
Yeah, just level the bottom against the floor line, right angle from the wall
sealcouch
« Reply #10 on: July 25, 2022, 09:40:30 pm »
Yep. I did just that and leveled it flat with the ground. Also trying out a new shape to make better use of the space below the screen. I could still put a topper on top if I felt so inclined.  Thoughts on this design vs the other? I feel like it kind of loses a little of the candy cab charm.
Also also, turns out my cousin has an extra pony cab control panel laying around that he's going to let me use. It will so cool to incorporate that into the build.
Also designed a little coin slot to match the original cab. I figured I could make it into a pushbutton for coin up as kind of an homage.
« Last Edit: July 25, 2022, 09:59:08 pm by sealcouch »
bobbyb13
« Reply #11 on: July 27, 2022, 05:41:30 am »
Not a candy cab without upper marquee and speakers!
nitrogen_widget
« Reply #12 on: August 06, 2022, 12:33:28 pm »
what's in the wall you are attaching it to?
remove the drywall and you can get almost 3 less inches sticking out and make it look truly built in.
  • Last login:January 25, 2026, 10:26:13 pm
« Reply #13 on: August 07, 2022, 10:18:47 am »
Impressive basement/man cave or bar!! I like your project and will be following.
eobet
  • Last login:September 20, 2022, 02:19:05 pm
« Reply #14 on: August 28, 2022, 04:24:18 am »
If you are 3D printing it, are you planning on incorporating any of the swooping chamfer designs from the original Astro City cab?
abispac
  • Last login:January 29, 2026, 01:33:55 am
« Reply #15 on: September 02, 2022, 06:36:07 pm »
just following
