Author Topic: 5V LED Replacements for C161 Coin Door Bulbs?  (Read 4047 times)
« on: February 03, 2022, 02:29:02 pm »
Does anyone sell a replacement for the C161 bulb that comes with the Xarcade coin door?  I have 5V to use from the encoder and these are 12V.  The bulb itself pulls out so I'm hoping there is something I can slot right into the white clip that hold the bulb...
Thenasty
  • Last login:Today at 12:50:32 pm
Re: 5V LED Replacements for C161 Coin Door Bulbs?
« Reply #1 on: February 03, 2022, 03:49:24 pm »
try a 555 bulb (not an led tho)
Free VGA Breakout Cable
« Reply #2 on: February 03, 2022, 04:44:13 pm »
I ordered some "wedge (555)" frosted LEDs from Comet Pinball.  They had all sorts of colors and they were only $0.69 each so I got some red, yellow and white to play around with.  They look like they will fit the bulb holder and they run on 5V so I plan to just wire from the encoder to the bulb directly.  If it doesn't work I'm only out $10!
Thenasty
« Reply #3 on: February 03, 2022, 06:45:54 pm »
it works, I have my 555 hook up to the 5vdc off IPAC. It will be dimmer but bright enough for its purpose.
jimj
  • Last login:August 27, 2024, 06:39:31 pm
« Reply #4 on: February 13, 2022, 05:12:46 pm »
Did these work for you?  Do you have a link to the bulb you used?
  • Last login:March 08, 2026, 07:17:46 pm
« Reply #5 on: February 13, 2022, 05:31:44 pm »
161 - 12v bulb
555 - 5v bulb
same bulb (T10 wedge) different voltage.
« Reply #6 on: February 14, 2022, 06:56:19 am »
They worked perfectly.  HERE is the link.  I bought 555s and frosted.  They plugged directly into the red 5v connector on the cheap encoder I am using.
jimj
« Reply #7 on: February 14, 2022, 08:48:21 am »
Thanks for confirming.  What color did you like best?  I have yellow coin doors, I was thinking maybe a plain white or red might look nice behind them.
jimj
« Reply #8 on: February 23, 2022, 10:47:38 pm »
I also bought a few frosted 555s.  I powered them from my motherboard USB ports which provide 4.85V.  Below is my review of how they looked with my yellow coin doors (and the current each color used):
cool white - 17mA - coin doors look yellow
warm white - 19mA - inconsistent color, top looks yellow, bottom looks more orange
yellow - 30mA - more of an orange tinted yellow, this is my favorite
red - 31mA - coin doors look red, in a well lit room this is the most noticeable color
« Reply #9 on: February 24, 2022, 06:50:33 am »
Thanks for reporting back.  So you have yellow coin returns and the red bulbs make them appear red?  If so, that’s awesome - I have a cab with yellow returns that I wish were red to match the rest of the design and I was going to try and swap them out and it seemed like a giant pain but if a red bulb will do the trick I’ll order some more!
jimj
« Reply #10 on: February 24, 2022, 08:00:07 pm »
It's hard to accurately capture their color in photos, but I've I attached three pics:
   1.lightsOnNotLit.jpg //room lights on, bulbs not lit
   2.lightsOnLit.jpg //room lights on, bulbs lit, left has yellow bulb, right has a red
   3.lightsOffLit.jpg //room lights off, bulbs lit, left has yellow bulb, right has a red
My red coin door isn't perfectly red, but if I wasn't looking for imperfections and you asked me what color it is I'd simply answer red.  I was surprised by how red it looks, I was expecting the red bulb to make the yellow coin return look orange.
« Last Edit: February 24, 2022, 09:33:47 pm by jimj »
« Reply #11 on: February 25, 2022, 07:22:44 am »
Wow - those pics are great and the return looks really red.  I’m going to give it a shot.  They are less than $1 each so no big deal.  The red ones I already installed in another cabinet are really bright.
You bought clear and not frosted, right?
jimj
« Reply #12 on: February 25, 2022, 08:19:00 am »
They are all frosted.
