Author Topic: Launching Mame vectrex mine storm from hyperspin or rocketlauncher problem.  (Read 4380 times)
abispac
  • Last login:Today at 12:09:04 am
So ive had a problem for a long time now, that i would like to solve, but cant seem to find a solution. I use hyperspin as my front end, and works just fine with every single emulator. I use Mame with Vectrex games , because i have more features than with other emulators. I can launch all games just fine except, minestorms. As a work around, ive been playin minestorm 2, but to be honest i like first one better , as im used to the satges as they are. So i want to fix  whatever is broken to be able to launch minestorm. So heres got i got right now.  I use rocketlauncher (forums are down at the moment) all games launch normally ecept minestorm. Outside rocketlauncher if i use the command, mame vectrex scramble, the scramble or any other game launch just fine, it also works like , mame vectrex -cart scramble, but if i use , mame vectrex minestrm, game wont launch, also mame vectrex -cart minestrm, wont launch. If i use just mame vectrex, minestorm would launch just fine. So im kind of stuck right now. I know minestorm works on mame, i just cant figure out how to launch it from rocketlauncher. Thanks for any help.
chillinwater
  • Last login:Yesterday at 12:16:39 am
so if the game runs directly from mame, then check hyperspins database for mame, or vectrex or gce vectrex whatever it is youve named the database with which your running "minestrm"
also check rocketlaunchers databases where your using "minestrm"
the game name has to match the romname exactly for it to launch.
these romname's can change from updated versions of mame. sometime by just 1 letter but thats enough to mess it all up.
<game name="minestrm" index="true" image="m">
    <description>Mine Storm</description>
    <cloneof />
    <manufacturer></manufacturer>
    <crc></crc>
    <genre></genre>
    <year></year>
    <rating></rating>
    <enabled>Yes</enabled>
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:26:04 pm
maybe you're missing the ROM.
As you know, if you just try mame vectrex it will work because that's the built in game for vectrex (no need for the ROM).
There is a ROM version of minestorm and that is the ROM that GCE had fixed the problem with the built in game after level 13 (i think).
Those people who reach that level playing found out the problem called the company and sent them a Cartridge. But for those owners that did not reach that level (many of us did not), never knew that problem existed, so company never sent them a cartridge.
The company just send the cartridge for those who complained.
Free VGA Breakout Cable
abispac
    <cloneof />
    <crc></crc>
    <genre></genre>
    <year></year>
    <rating></rating>
Tried this, did not work.
abispac
I do have a rom and it dont work if i have it like a regular game. Thats why im posting here, cant seem to find a solution.
Haze
    • MAME Development Blog
To launch the original game just boot the system with *no* cartridge, it's the built in game.
I'm not sure what the softlist entry is doing there, because it was never available as a cartridge, doesn't work if loaded as such, and should be removed from there.
abispac
Yeah, that works in mme ,but cant find the para meters to make it work in rocketlauncher.
Haze
does it allow you to pass
mame vectrex -cart ""
or just launch it like any regular MAME system, with no cartridge parameter?
Sorry I'm not really familiar with RocketLauncher, but it seems to be quite a big oversight in the software if it doesn't, because there are a lot of systems where you'd want to launch either the base system without a cartridge, OR with one of the softlist entries inserted.
