Author Topic: CRT Emudriver - Non emulated compatible games  (Read 266961 times)
tisurame
  • Last login:August 03, 2025, 10:50:53 am
Re: CRT Emudriver - Non emulated compatible games
« Reply #320 on: December 29, 2024, 07:02:23 am »
UFO 50
Steam
Native resolution is 384x216
It works perfectly right from the start. No need to change any configuration inside the game.
Highly recommended, since it's 50 (very good) games.
« Last Edit: December 29, 2024, 07:04:22 am by tisurame »
tisurame
« Reply #321 on: January 03, 2025, 08:30:36 am »
Void Stranger
Steam
Native resolution is 224x144, but it's too low for the monitor, so I'm using 288x192. You need to set to windowed mode 1x.
Aspect ratio looks perfect on a 4:3 screen. No need to use the 16:9 mode of your monitor.
8bitGeneration
  • Last login:August 21, 2025, 08:01:49 pm
« Reply #322 on: May 16, 2025, 03:04:18 am »
The Takeover and DOUBLE DRAGON GAIDEN RISE OF THE DRAGONS resolution anyone?
Recapnation
  • Last login:February 23, 2026, 12:10:18 pm
    • Eiusdemmodi
« Reply #323 on: May 16, 2025, 07:56:56 am »
Seems to be 1600 * 900 for Takeover:
DDG's design resolution is 384 * 216:
8bitGeneration
« Reply #324 on: May 17, 2025, 11:30:13 am »
Will try these, much love. Thanks!
« Last Edit: May 17, 2025, 11:32:01 am by 8bitGeneration »
BuckoA51
  • Last login:November 04, 2025, 08:57:40 am
« Reply #325 on: May 22, 2025, 08:19:39 am »
You can't just copy my script Verbatim.
You need to change the path to the exe file yourself..
Mine is located in
C:\Games\KAGE Shadow of the Ninja\KAGE Shadow of the Ninja.exe
Yes I know, I changed the path, doesn't work (as described).
Rion
  • Last login:Today at 07:46:38 pm
  • 240p, 480i
« Reply #326 on: June 04, 2025, 10:17:14 am »
Mine is located in
What is you path then?
8bitGeneration
« Reply #327 on: June 09, 2025, 05:44:32 pm »
NINJA GAIDEN: Ragebound Demo anyone?
phasermaniac
« Reply #328 on: June 10, 2025, 09:39:41 am »
I would bet 480x270
CRTFTW
  • Last login:Yesterday at 01:24:08 pm
« Reply #329 on: July 07, 2025, 01:16:19 pm »
You can easily find out for yourself.
On a standard monitor:
In the game options, set it to the x1 window mode, where 1 pixel on your monitor is 1 pixel in game.
Run and inject Special K, open the OSD, read the window resolution.
That is the resolution of the game. Make that as a custom resolution
BuckoA51
« Reply #330 on: July 08, 2025, 12:31:29 pm »
Btw SkyRacket is listed as 384x216 but I just downloaded the demo and it's 480x270.
tisurame
« Reply #331 on: July 10, 2025, 10:46:24 pm »
Zexion
Steam
Native resolution is 320x224. It works perfectly.
Awesome metroid-like game.
grendelrt
  • Last login:July 31, 2025, 04:05:14 pm
« Reply #332 on: July 31, 2025, 03:10:14 pm »
Earthion looks to run at 320x224 being originally a genesis cart.
https://store.steampowered.com/app/3597580/Earthion/
Hunk_4TH
  • Last login:January 21, 2026, 09:48:13 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #333 on: August 11, 2025, 07:03:04 pm »
Is there a command line to get Switchres to work with Duckstation, Pcsx2, and Dolphin? All standalone. I use Launchbox so I figured the command line could be added there. I'm new to Switchres outside of Retroarch.
8bitGeneration
« Reply #334 on: August 21, 2025, 08:01:49 pm »
I would bet 480x270
no NINJA GAIDEN - Ragebound is showing some bad pixels with that resolution like letters artifacts while moving etc...
I did that opened the game on my pc monitor and i switched the game to windowed also did Alt+Enter, Special K when accessing OSD with Ctrl+Shift+Backspace in resolutions it's not showing me the resolution that i should be using on the CRT TV, it's only showing the resolution of the window and what do you mean by set it to the x1 window mode in game options there is no such option in the game there is only windowed and it lets you choose a resolution, what did i miss?
Rion
  • 240p, 480i
« Reply #335 on: August 25, 2025, 03:27:04 am »
I would bet 480x270
Looks like its 854x480
50% downscaling would be 427x240
I haven't tried myself so its just guessing at this point.
Rion
  • 240p, 480i
« Reply #336 on: September 18, 2025, 04:21:10 pm »
Super Mario Bros Remastered
Super Mario Bros Remastered (GitHub)
256x240@60
Rion
  • 240p, 480i
« Reply #337 on: December 12, 2025, 02:51:57 pm »
Terminator 2D: NO FATE
Steam
Native res is 796x448
50% Down-scaling to a progressive resolution
398x224@60Hz
Or just run it in it's native resolution interlaced
796x448i@60Hz
In loving memory of Sergi Clara (psakhis)
« Last Edit: December 14, 2025, 12:53:25 pm by Rion »
rancid
  • Last login:December 14, 2025, 11:51:54 am
« Reply #338 on: December 14, 2025, 11:48:25 am »
Hi All,
Super dumb question and I apologize, but is it possible to get "pseudo" scanlines with a 31khz PC CRT Monitor using these native resolutions?  I am trying to use switchres with super resolutions and I can't get anything to work where it is full screen, but it does display in small windows.  I have switchres fully working in retroarch, but anything outside of retroarch just isn't working well.  When I look in the display settings for windows I see the desktop resolution varies from the active resolution which I assume is the main problem.
Rion
  • 240p, 480i
« Reply #339 on: December 14, 2025, 01:04:02 pm »
Neon Inferno
Steam
Native res is 424x240
424x240@60Hz
Rion
  • 240p, 480i
« Reply #340 on: December 15, 2025, 03:33:00 pm »
SHINOBI NON GRATA
Steam
Native res is 1024x576
384x216@60Hz Correct AR: 16:9 - Black bars top/bottom
426x240@60Hz Incorrect AR: 4:3 - Fullscreen
Game Settings:
Option
Fullscreen: ON
Resolution: 720p
V-SYNC: ON
Retro filter: OFF
Display Dot By dot: ON
Gamescope settings:
Nested Resolution: 1024x576
Output Resolution: 1024x576/384x216/426x240 (What looks best)
Refresh rate: 60
Scaler: Integer
Fullscreen
Rion
  • 240p, 480i
« Reply #341 on: December 16, 2025, 05:07:51 am »
Wings of Endless
Steam
Native res is 480x270
480x240@60Hz
Start game in 480x270 then switch to 480x240 when the game has booted up.
Linux Specific settings:
Gamescope settings:
Nested Resolution: 480x270
Output Resolution: 480x270
Refresh rate: 60
Scaler: Stretch
Fullscreen
Switchres: 480x240
Rion
  • 240p, 480i
« Reply #342 on: December 16, 2025, 03:43:44 pm »
BLADECHIMERA
Steam
DRAINUS
Steam
Record of Lodoss War-Deedlit in Wonder Labyrinth-
Steam
Touhou Luna Nights
Steam
Native res is 640x360 for all games listed above from Team Ladybug.
640x480i@60Hz
Start game in 640x480 then use Integer Scaling.
I used GameScope in Linux but should work just the same using integer-scaler in windows.
Game will be displayed in correct aspect ratio 16:9 with black borders top/bottom
If you just want 4:3 fullscreen then skip using integer scaling.
Game Options as follow:
640x360
V-Sync: ON
Fullscreen
Switchres: 640x480
Gamescope settings:
Nested Resolution: 640x360
Output Resolution: 640x360
Refresh rate: 60
Scaler: Integer
Fullscreen
Switchres: 640x480
BLADECHIMERA
DRAINUS
Touhou Luna Nights
Rion
  • 240p, 480i
« Reply #343 on: December 29, 2025, 09:41:54 am »
NIGHT STRIKER GEAR
Steam
640x480i@60Hz Correct AR: 16:9 - Black bars top/bottom
854x480i@60Hz Incorrect AR: 4:3 - Fullscreen
Game Settings
Game Start -> Config -> Screen:
Fullscreen: ON
Resolution: 640x360
Bilinear: OFF/ON (Depending on what you want)
Progressive Resolution in Linux
Gamescope settings:
Refresh rate: 60
Scaler: Stretch
Fullscreen
Switchres: 480x240p
Rion
  • 240p, 480i
« Reply #344 on: February 07, 2026, 11:16:03 am »
Lovish
Steam
Native res is 320x192
Switchres: 320x192@60Hz
Game Options
Window Size: Fullscreen
Soft Pixels: OFF
Rion
  • 240p, 480i
« Reply #345 on: February 25, 2026, 07:35:24 pm »
Revolgear Zero
Steam
Native res is 384x216
Switchres: 384x216@60Hz
Game Options
