Author Topic: CRT Emudriver - Non emulated compatible games  (Read 236132 times)
  • Online Online
  • Last login:Today at 04:20:08 am
Re: CRT Emudriver - Non emulated compatible games
« Reply #40 on: October 25, 2020, 06:42:49 am »
Updated list!
I strongly recommend switchres program by @Calamity to avoid having to install all game modelines.
Hi,
Care to explain how you do it without installing modelines ?
I can't figure it out, I thought you had to install correct modelines to let switchres pick them up?
Thanks !
He's using the (long promised) Switchres standalone binary (see attachment).
totozero
  • Last login:June 07, 2023, 07:36:05 am
« Reply #41 on: October 25, 2020, 09:06:55 am »
Gracias compa !  :laugh:
Now, let's see if I can get through it.
Edit : OK let's pretend I want to run C:\game.exe with 352x248 resolution @60hz with arcade_15 preset (already within ini file).
Am I correct assuming that
switchres 352 248 60 -l c:\game.exe will run it and revert back to original resolution upon exit ?
Thanks.
« Last Edit: October 25, 2020, 09:17:00 am by totozero »
  • Online Online
« Reply #42 on: October 25, 2020, 10:26:52 am »
Yes, that's the idea. You probably need to wrap the exe command with "" if spaces are required.
If -allow_hardware_refresh is enabled in switchres.ini, new modes will be added dynamically (no need to use VMMaker for that, Switchres uses the same mechanism as VMMaker for adding/removing modes on the fly). You may hear a plug/unplug sound from your Windows os though, due to this.
If -allow_hardware_refresh is disabled, Switchres will try to update your existing modelines, just like GM does, without adding new modes.
« Last Edit: October 25, 2020, 10:28:25 am by Calamity »
totozero
« Reply #43 on: October 25, 2020, 12:43:23 pm »
Neat ! Thanks, I'll try it asap.
psakhis
« Reply #44 on: October 27, 2020, 06:14:25 pm »
Updated list!
Hi,
Thanks !
BTW this version of maldita castilla is way better for CRT than the ex version, you'll get full screen on a 15khz monitor.
Enable vsync in config.ini if it isn't to remove tearing.
Resolution is 256x224@60
https://drive.google.com/file/d/19D1VWqRyqrHK7gZBqkTdqUOnbdHaMdj1/view?usp=sharing
Thanks! I didn't know about this version.
Updated list and added spreadsheet for more details (input controller, size in MB)
« Last Edit: October 28, 2020, 02:56:04 am by psakhis »
totozero
« Reply #45 on: November 13, 2020, 11:34:35 am »
Hey, may I ask what Kirisade Blade  I & II are ?
My google-fu skills might be rusted but I didn't find any info regarding these titles.
Thanks !
Recapnation
    • Eiusdemmodi
totozero
« Reply #47 on: November 13, 2020, 03:49:23 pm »
Thanks Recap.
Odd, I could swear I read Kirisade on the list  :dizzy:
psakhis
« Reply #48 on: November 20, 2020, 03:15:22 pm »
I'm testing Street of Rage Remake 5.2 and seems vsync it's fixed now!
Widescreen ON (with off fails)
Vsync OFF
Enabled Aero / Composition desktop
Put BORDERLESS in mod/system.txt
Native resolution 416x240@60.
totozero
« Reply #49 on: November 21, 2020, 09:25:04 am »
Hyper DBZ Champ’s build is a must have, as well. Incredible mugen powered game  :)
Runs like a breeze natively 320x240@60
I actually prefer to play this one over dbz figterz, it’s funnier.
Get it here. RIGHT NOW
https://network.mugenguild.com/balthazar/
psakhis
« Reply #50 on: November 22, 2020, 01:21:59 pm »
Thx! Game it's really fun, but i have a lot of tearing  :'(..any suggest?
totozero
« Reply #51 on: November 23, 2020, 02:58:36 am »
Odd, I have no tearing at all (windows 10).
What OS are you running ?
You can try to change the renderer setting to SDL, it 's located in data folder under mugen.cfg
Only changes I've done so far :
;Game native width and height.
 ;Recommended settings are:
 ;  640x480   Standard definition 4:3
 ; 1280x720   High definition 16:9
 ; 1920x1080  Full HD 16:9
GameWidth = 320;1280
GameHeight = 240;720
;Set to 1 to enable fullscreen mode, 0 for windowed.
FullScreen = 1
You should be able to remove tearing (hopefully) messing here
[Video]
 ;The video resolution defaults to the same as the game resolution.
 ;You can force an alternate resolution by uncommenting the lines
 ;below.
;Width  = 1280
;Height = 720
 ;This is the color depth at which to run MUGEN.
 ;Only 16 is supported at this time.
Depth = 16
 ;Set to 1 to enable vertical retrace synchronization. Do not enable
 ;if BlitMode = PageFlip.
 ;Not supported in 1.0.
VRetrace = 0
FullScreen = 1
 ;Drawing mode
 ;Choose from Normal (fast) and PageFlip (less image "tearing")
BlitMode = PageFlip
 ;Screen rendering mode.
 ;System - default SDL rendering mode (e.g. windib in Windows)
 ;DirectX - DirectX 5 renderer
 ;OpenGLScreen - hack that allows window resizing but could be slow
RenderMode = OpenGLScreen
« Last Edit: November 23, 2020, 04:56:28 am by totozero »
psakhis
« Reply #52 on: November 23, 2020, 06:54:34 am »
I'm in W7x64, i have tried all parametres  :banghead:
I think with windowed mode no suffer tearing at all, i will try workaround with fullscreen borderless.
totozero
« Reply #53 on: November 23, 2020, 03:22:24 pm »
Yeah I feel you man.
When I was on W7, there was no way to remove tearing from all mugen and openbor stuff. And from some doujins as well.
It's all solved now with Win10, maybe something related with desktop composition (always active in win10).
You could try to reenable it just to see if it fixes the issue (in case it's been disabled).
EDIT : Or you could change your OS. I won't ever go back to W7, W10 LTSC is faster and can be hidden easily without any dirty hack.
« Last Edit: November 23, 2020, 03:28:07 pm by totozero »
totozero
« Reply #54 on: November 23, 2020, 04:56:48 pm »
Oh man, this is absofuckingly gorgeous !  ;D
psakhis
« Reply #55 on: November 23, 2020, 06:09:02 pm »
I found the problem and the solution. Mugen 1.0 it's very slow on my PC (it's deprecated version, only uses 1 core). I updated to 1.1 with OpenGL and now it's perfect and runs very fast!
totozero
« Reply #56 on: November 24, 2020, 03:00:50 am »
Glad you sorted it out  :applaud:
By the way, the DBZ archive file is missing some characters (krillin, c18) and some stages as well.
They have to be downloaded separately and manually installed.
psakhis
« Reply #57 on: November 26, 2020, 07:59:01 am »
Great game. If anyone ara interested with 320x240 config with all characters. All credits for Team Z2's, of course. https://network.mugenguild.com/balthazar/
https://drive.google.com/file/d/1vYOx4Aaa8vlq_U0m1SM-k1Gef8NOh632/view?usp=sharing
psakhis
« Reply #58 on: February 07, 2021, 08:18:32 am »
Hi all!
Five new ready cabinet games!
Cyber Shadow                     400x240@60
Binky's Trash Service            320x240@60 (F4 autohotkey for fullscreen)
Binary Star Infinty              320x240@60
Street Cleaner: the video game   400x240@60
Touhou Luna Nights               640x480@60
(*) I discovered XOutput program for major steam compatibility games, it's a great another alternative joy2key and x360ce.
Saroumane
  • Last login:January 01, 2024, 05:50:52 pm
« Reply #59 on: February 17, 2021, 10:47:37 am »
This topic is a GREAT idea, and we need to add more shmups :)
I'm thinking about Cave games for steam : Mushihimesama, Deathsmiles, Dodopachi Resurrection. And also Psikyo games for steam : Dragon Blaze, Zero Gunner, Gunbird, Strikers 1945 etc.
Let's take Mushihimesama (Steam version)
TL;DR
Nice resolution for consumer CRT TV : 320x240@60
Best resolution for "31KHz" CRT Monitor : 640x480@60
I had very good results by running this game at 320x240@60 on a CRT TV : no scrolling/tearing problem, picture is crisp and clean.
But I also had the feeling it could be better : Mushihimesama sprites have been redone in higher resolution (Steam port comes from Xbox360 port)
So : for a perfect result you have to find a PC CRT Monitor that can handle 640x480  non-interlaced (480p)
I use this modeline with a Sony Multiscan 200ES :
Modeline    "Mode 0" 25.18 640 656 752 800 480 490 492 525 -hsync -vsync
In-game Screen settings are very important.
Screen settings (for 480p)
  • Smoothing ON  (Really needed for nice backgrounds)
  • Zoom 150% ( I had initially  some random streched lines/pixels when I put other values for "Zoom".)
General screen settings
  • Aspect ratio 4:3
  • Rotate Left Roll
  • Link Rotation ON
The difference between 240p vs 480p on a CRT for this game :
https://i.ibb.co/pL2NB1S/mushi240p-VS480p.png
« Last Edit: February 18, 2021, 05:15:55 pm by Saroumane »
Rion
  • Last login:Yesterday at 07:49:11 pm
  • 240p, 480i
« Reply #60 on: February 20, 2021, 06:49:52 pm »
I love this thread!
Please make it a sticky  :notworthy:
psakhis
« Reply #61 on: April 04, 2021, 06:14:22 pm »
TL;DR
  • Aspect ratio 4:3
  • Rotate Left Roll
  • Link Rotation ON
Yeah, these titles are not on my list because they already exist in arcade or console ports. Most of them in PS2 with 640x240 on a CRT consumer have very good results.
Rion
  • 240p, 480i
« Reply #62 on: April 20, 2021, 09:27:16 am »
Record of Lodoss War: Deedlit in Wonder Labyrinth (Steam)
Trying to get this scaled right but i'm unsuccessful.
640x360 is the native resolution i think?
psakhis
« Reply #63 on: April 20, 2021, 04:35:06 pm »
Your best bet it's 640x480 or 854x480 for 4:3 aspect.
Rion
  • 240p, 480i
« Reply #64 on: April 20, 2021, 05:42:23 pm »
Thanks. Looks like 640x480 is the best option for now.
Rion
  • 240p, 480i
« Reply #65 on: April 23, 2021, 05:57:56 am »
« Last Edit: April 23, 2021, 06:00:40 am by Rion »
psakhis
« Reply #66 on: April 27, 2021, 08:10:30 am »
Tanuki Justice! and 3 more
Tanuki Justice                   384x216@60 (enable aero for vsync)
Primal Light                     854x480@60i
Powerglove Reloaded              320x240@60
Tiger Claw                       320x240@60
BuckoA51
  • Last login:November 04, 2025, 08:57:40 am
« Reply #67 on: April 30, 2021, 04:57:59 am »
Underrated thread.. here's Undertale running on my Multisync at 320x240.
It's sometimes hard to see what the monsters say during battle but honestly this looks so much better to me than the game running on a fixed resolution display with faux scanlines through something like an OSSC that it's worth it IMO.
psakhis
« Reply #68 on: May 09, 2021, 01:29:04 pm »
Hi,
Today i have finally got two titles (great shoot'em ups) that i didn't get configure controls properly in my cab:
- Sky Force Anniversay  640x480@60i
- Sky Force Reloaded    640x480@60i
The first one, with XOutput works well, only mention for map controls you need to press "ALT" key when execute the game first time.
The second one is more dificult but possible with XOutput and HIDGuardian (maybe more easy with x360ce 4 with HIDGuardian too), the steps are:
 1. Enable startup HIDGuardian XOutput and enable it for joystick devices (this prevents HIDGuardian hide to Xoutput dinput joysticks)
 2. Set affectedDevices entry register with HID joystics, you can see how on this video
 3. Export regedit affectedDevices key with joysticks (hidguardian_yes.reg) and the same register but without HIDs (hidguardian_no.reg)
 4. Only you need is a batch program for execute game with this steps:
     1. regedit /S hidguardian_yes.reg (with this line when reconnect devices hidguardian hide them for programs)
     2. start /min "" "XOutput.exe" (with this line start xinput emulation for dinput joysticks)
     3. devcon.exe restart "HID\VID_2341&PID_8036*" (this is my HID joysticks, you need to put yours; with this line restart devices and hidguardian hide them)
     4. execute game
     5. taskkill /IM XOutput.exe /f (kill xoutput process)
     6. regedit /S hidguardian_no.reg (restore registry with no hide joysticks)
     7. devcon.exe restart "HID\VID_2341&PID_8036*" (this is my HID joysticks, you need to put yours; with this line restart devices and hidguardian show them again)
It's a little tricky but works  ;D
« Last Edit: May 09, 2021, 04:32:14 pm by psakhis »
Rion
  • 240p, 480i
« Reply #69 on: June 14, 2021, 12:23:42 pm »
Astalon Tears of the Earth  - 432x240@60
Mighty Goose - 480x270@50/60
abispac
  • Last login:December 18, 2025, 11:07:20 am
« Reply #70 on: June 14, 2021, 01:52:36 pm »
Anyone knows if theres a way to force a game into 640x480? im trying to run kof14 but i get odd resolutions. It would be nice if theres a tweak to make it work at a crt resolutions. thanks
Rion
  • 240p, 480i
« Reply #71 on: June 15, 2021, 05:47:25 am »
Tested the GOG version and i can choose 640x480 in the menu.
abispac
« Reply #72 on: June 16, 2021, 03:09:53 pm »
perhaps the one i have instaled has 640x480 but ill need an lcd screen to be able to choose that resolution, ill also try the GOG version, thanks
phasermaniac
« Reply #73 on: July 03, 2021, 01:51:17 pm »
Hi! Anyone know which is the correct resolution for Alex kidd Dx?
I got the closer to perfect on 480x270, but the text still doesn't display right.
I also found ZeroRanger to be a good vertical shump in my opinion. It seems to work right on 240p.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #74 on: July 06, 2021, 02:43:25 am »
Has anyone been able to get any of the newest Street Fighter games working? (SF IV, IV Ultra, V)
Recapnation
    • Eiusdemmodi
« Reply #75 on: July 11, 2021, 05:21:16 am »
Not tested, but the base of Alex Kidd's graphics seems to be of 640 x 360:
https://postback.geedorah.com/foros/viewtopic.php?pid=32864#p32864
But then if you have the HUD, portraits and whatnot designed at a higher rez, you can't expect them to look "right". It's an awful "feature" even for flat panels usage but overly present these days. (In this game's case, it's clearly an afterthought as it was going to have 384 x 288 graphics in its original fan game form. It's not that we're missing much, it seems, anyway.)
alex2005
  • Last login:Yesterday at 08:14:32 am
« Reply #76 on: July 11, 2021, 06:32:26 am »
Ultra SF IV works perfect at 640x480
I didnt manage to make SFV work at this resolution.
Deef
  • Last login:July 14, 2021, 05:17:54 am
  • I'm building a nostalgia machine!
« Reply #77 on: July 14, 2021, 04:43:15 am »
Hello!
First of all, a big thank you to everybody, Calamity, Psakhis, and so many more who I have scrolled through comments and replies of while building my PC to CRT setup. I've avoided replying and asking where possible, since I always figured if I keep searching/pondering enough, I may not need to bother anybody with a query. I'm a bit stumped at the moment though.
I want to run some games from my Steam Library that would, like many in this list, suit themselves really well to a CRT setup. I downloaded the switchres zip in this thread and I'm embarrassed to say I just don't know what the heck I'm doing. I've attached what I'm seeing since, I look at it and read peoples settings in here, and I'm just unsure how it is supposed to look, so I think if anybody could perhaps take a moment, and just break it down for me as simple as taking any game and an example of inputting it into the ini file.
Thanks for any help, and any questions I can answer that'll help you help me, just let me know and I'll get on it.
Rion
  • 240p, 480i
« Reply #78 on: July 14, 2021, 05:17:17 am »
Annalynn - 288×224@60
Rion
  • 240p, 480i
« Reply #79 on: July 14, 2021, 05:26:07 am »
Hello!
Switchres Github
Latest standalone version can be downloaded via Actions - Select latest workflow runs - Scroll down to Artifacts. Download latest binary
