Author Topic: Output Blaster  (Read 25838 times)
Boomslang
Output Blaster
« on: December 08, 2019, 12:15:36 am »
https://github.com/Boomslangnz/OutputBlaster/releases
A few people were asking me about this so thought I will finally make a post regarding it.
This is a small plugin which works with TeknoParrot to add Outputs for Mamehooker or MameInterOp SDK
Pretty simple, just place OutputBlaster.dll in game exe or elf folder and then on TeknoParrotUI under game settings. Tick Enable Outputs for it to load it
Ive just added FFB output to a bunch of games (raw value) and it should hopefully have lamps already done for most games.
Think ive done around 22 games on it, but if you are unsure which ones. Either look at source code or just check if the game has Enable Outputs under TeknoParrotUI
vandale
  • Id 10 and t error
Re: Output Blaster
« Reply #1 on: December 08, 2019, 01:18:51 am »
that's awesome, thanks man. Im just getting into teknoparrot and this is just icing on the cake!!!
gareth_iowc
  • Last login:October 04, 2022, 03:27:37 am
Re: Output Blaster
« Reply #2 on: December 13, 2019, 06:04:24 pm »
Thank you boomslang this is amazing!
« Last Edit: December 13, 2019, 07:20:19 pm by gareth_iowc »
gareth_iowc
Re: Output Blaster
« Reply #3 on: February 16, 2020, 05:00:19 pm »
Any tips on getting Daytona 3 to hook?
I've added outputblaster.dll into Daytona3\Sega\Daytona, in this folder is where the main game daytona.exe is located.
I believe my config is ok as I've got Mario kart output being displayed in mamehooker when running.
Boomslang
Re: Output Blaster
« Reply #4 on: February 16, 2020, 06:08:35 pm »
Did you enable outputs?
gareth_iowc
Re: Output Blaster
« Reply #5 on: February 23, 2020, 11:14:15 am »
Yeah I've enabled outputs
Boomslang
Re: Output Blaster
« Reply #6 on: February 24, 2020, 12:49:43 am »
Hm strange
For me I have to run all these games as administrator including mamehooker for them to work
Boomslang
Re: Output Blaster
« Reply #7 on: April 29, 2020, 06:14:23 pm »
New Version of Output Blaster. Now Version 0.4
*EDIT*
lol just thought actually, m2 emulator properly won't work for anyone as dll won't be loaded at the moment, I just use ffb plugin to load it usually
*EDIT 2*
actually it will aslong as you have ffb plugin in folder too. Add EnableOutputs=1 to FFBPlugin.ini and it will load OutputBlaster.dll. If you don't want ffb stuff then don't add device guid etc
« Last Edit: April 29, 2020, 06:33:09 pm by Boomslang »
Sky25es
  • Last login:November 24, 2025, 12:35:19 pm
Re: Output Blaster
« Reply #8 on: June 27, 2020, 04:06:30 pm »
Just a question. Would it be possible (if it's not too much work) to make output blaster compatible with standalone games or other loaders other than Teknoparrot ? I really like TP, but many games work, at least for me, better with other loaders.
Many thanks again for your work.
gareth_iowc
Re: Output Blaster
« Reply #9 on: June 28, 2020, 05:27:21 pm »
are you using output blaster with mamehooker?
mamehooker can support other programs like model 2 and supermodel 3
Sky25es
Re: Output Blaster
« Reply #10 on: June 28, 2020, 08:16:24 pm »
Yes, I'm using Mamehooker. I know about model 2 and supermodel support, but I'm referring to other Pc based games. Mario Kart GP DX I.e. is easier for me to setup with Jconfig.
  • Last login:Today at 02:10:08 am
Re: Output Blaster
« Reply #11 on: June 29, 2020, 01:06:35 am »
And with troubleshooter's help you can do so.... I haven't released those files though mainly because Boomslang has been doing such a great job.  We sat down a memory mapped quite a few of those games a few years back.
Sky25es
Re: Output Blaster
« Reply #12 on: June 29, 2020, 05:36:57 am »
Wow! Great news Howard. Thanks  :cheers:
Let's wait for a new release of TS then (or maybe a hybrid version of outputblaster).
frankrizzo2
  • Last login:August 09, 2025, 03:52:53 pm
Re: Output Blaster
« Reply #13 on: March 03, 2021, 05:39:49 pm »
If anyone is having trouble getting TeknoParrot to run in Mamehooker try to drop the x86 files from the OutputBlaster folder into the exe. I couldn't get it to work for days with the 64bit dll but as soon as I dropped the x86 in there Mamehooker recognized it immediately.
Boomslang
Re: Output Blaster
« Reply #14 on: March 04, 2021, 02:12:45 am »
X86 dll is for x86 applications, x64 for x64 applications
You might be getting confused with using x64 windows etc
frankrizzo2
Re: Output Blaster
« Reply #15 on: March 04, 2021, 10:24:05 am »
Well that makes sense. I was under the impression that it was based on operating system so thank you for clarifying. I'm so glad you created the plug-in though as its one less program to run in the background.
fablog
  • Last login:January 04, 2026, 04:27:15 pm
Re: Output Blaster
« Reply #16 on: April 25, 2021, 08:57:58 pm »
Hi Boomslang,
It seem's outputblaster is broken with technoparrots games (or my PC is broken), no pb with other emulators. Yesterday my VR panel was working, today no lights. Maybe a bad Teknoparrot update!?
« Last Edit: April 25, 2021, 09:17:43 pm by fablog »
Boomslang
Re: Output Blaster
« Reply #17 on: April 25, 2021, 10:50:01 pm »
hm doubt its anything to do with teknoparrot
Output Blaster is independent really, its just TP loads the dll.
Boomslang
Re: Output Blaster
« Reply #18 on: April 26, 2021, 02:35:24 am »
How many people using Output Blaster?
thinking about updating it for new games etc
As for question awhile back if other emulators/loaders other then teknoparrot can use Output Blaster? sure. It's simply a dll and just needs to be loaded (which is all Teknoparrot) is doing
I did not add wrapper code etc for it to get loaded automatically like I do for FFB Plugin and no plans to do that but its easy for any application to load OutputBlaster.dll
fablog
Re: Output Blaster
« Reply #19 on: April 26, 2021, 08:10:15 am »
Outputblaster is still working very well with Mame, Model 2 emu, Supermodel but nothing with all the Teknoparrot games. In the logs I don't see any output. I can't be sure it's a problem with Teknoparrot, but the probability seem's high. It happened just after a technoparrot update.
Edit: I was wrong on everything, I'm the one broken  :banghead:
I set Teknoparrot in admin mode because it ask for it to play Mario Kart DX, it broke the output!! Lesson learned, sorry for the waste of time.
« Last Edit: April 26, 2021, 09:37:40 am by fablog »
Boomslang
Re: Output Blaster
« Reply #20 on: April 27, 2021, 04:08:36 am »
fablog
Re: Output Blaster
« Reply #21 on: April 27, 2021, 01:23:13 pm »
Envoyé de mon LEX722 en utilisant Tapatalk
ceycey1733
  • Last login:August 03, 2021, 01:57:21 am
Re: Output Blaster
« Reply #22 on: April 28, 2021, 01:49:48 pm »
Can you publish a detailed document for the output blaster please
BigPanik
  • Last login:February 28, 2026, 03:54:36 pm
Re: Output Blaster
« Reply #23 on: May 11, 2021, 02:30:42 pm »
Hi Boomslang,
Thanks to share your work!
I’m looking for to grab Demul Hikaru Star Wars podracer deluxe outputs (lamps and Solenoid).
Could you explain how is working your PatternScan function from ffb plugin? You do the job for Demul Nascar and others Hikaru games but find nothing about podracer.
Thanks a lot
arcadeturk
  • Last login:March 28, 2022, 04:32:51 pm
Re: Output Blaster
« Reply #24 on: November 12, 2021, 05:50:21 pm »
I can't run mamehooker with Teknoparrot. I put Output Blaster in game folder, selected teknoparrot enablaOutputs. Are there any other settings for mamehooker?
Thanks a lot
Boomslang
Re: Output Blaster
« Reply #25 on: November 15, 2021, 10:43:39 pm »
Thanks a lot
hm no, however on one of my other pcs I had to run everything with Administrator status for Output Blaster to work with Mamehooker
fablog
Re: Output Blaster
« Reply #26 on: July 27, 2024, 03:43:36 pm »
Hi Boomslang, I just tried Outputblaster with Initial D 5 and only Start and Change view buttons  output something. We should have Up, Down, Left and Right buttons too. Could you check please?
Envoyé de mon Pixel 6a en utilisant Tapatalk
buttersoft
  • Last login:Yesterday at 07:06:57 pm
  • Is running at 15kHz
Re: Output Blaster
« Reply #27 on: July 30, 2024, 10:17:41 pm »
I'm not sure how often BoomslangNZ checks this forum. He has his own channels on the Teknoparrot discord, and some of the other users there might know more about this particular game.
fablog
Re: Output Blaster
« Reply #28 on: July 30, 2024, 10:19:17 pm »
Thanks, I will try there!
