Author Topic: Erratic frame rate with Carnevil & Maximum Force (log included)  (Read 10985 times)
Trnzaddict
  • Last login:September 21, 2025, 10:48:29 am
« on: December 13, 2018, 06:55:06 pm »
Hi, I'm getting some serious issues when playing Carnevil & Maximum Force on GM. Does not happen on vanilla MAME.
Basically Carnevil seems to run at 210%, sometimes up to 410% %, like the throttle is broken.
Maximum Force has erratic frame issues as well. It hovers at around 88% then jumps up to 105, then back down, up etc. Again on vanilla MAME, runs 100%.
Whats strange is what kind of brings the speed back down to somewhat normal levels is if I enable frame delay, but because I'm using the d3d9EX, I read that enabling frame delay is useless as you're already getting maximum input lag reduction when using that video mode.
I'm running an i7 8700k, so it's not a hardware issue. It chews through MAME easily.
haynor666
  • Last login:October 02, 2025, 04:39:12 pm
  • retro maniac
schmerzkaufen
Re: Erratic frame rate with Carnevil & Maximum Force (log included)
« Reply #2 on: December 14, 2018, 04:13:16 am »
Not 'maximum', just using d3d9ex (frame_delay off) means the video is synced within a single frame instead of the ususal 2~3, so it takes care of the greatest portion of the usual unwanted lag.
Then to get rid of most of that last remaining frame you will need frame_delay ON, often at the highest possible setting (requires extra cpu+gpu muscle on top of what the MAME drivers already require for themselves)
In theory plain d3d9 with frame_delay set to 1 behaves just like d3d9ex, however in practice some (heavy) games will freak out and it doesn't seem to necessarily be a matter of processing power, or at the very least it doesn't seem to be the CPU's fault (maybe the GPU is the bottleneck, dunno for sure)
So for those games just use d3d9ex without frame_delay, until maybe future development changes that somehow.
(and, well, use triplebuffer in this particular case of course)
« Last Edit: December 14, 2018, 04:15:32 am by schmerzkaufen »
Trnzaddict
« Reply #3 on: December 14, 2018, 03:51:41 pm »
Known problem
http://forum.arcadecontrols.com/index.php/topic,113382.msg1664344.html#msg1664344
http://forum.arcadecontrols.com/index.php/topic,135129.msg1394725.html#msg1394725
Oh...ok no problem I’ll just make a custom ini for the games affected.
Ahhhh ok. I read it incorrectly then. Thanks for the clarification.
Well that’s great news that I can shave even more off by using them together.
Trnzaddict
« Reply #4 on: December 30, 2018, 02:29:43 pm »
Hi, so I've finally had some time to work on this due to some free time for the holidays...
Even with carnevil.ini with autosync disabled and triplebuffering enabled, now I'm getting a flat out crash from GM.
I have a new log included. According to the cmd window, there is a direct3d error going on.
  • Last login:Today at 02:55:00 am
« Reply #5 on: January 01, 2019, 02:16:07 pm »
Create a blank ini file for carnevil. Add this option: changeres 0
It's dynamic mode switching what's breaking it (it doesn't play nice with -triplebuffer which renders multithreaded).
« Last Edit: January 01, 2019, 02:17:46 pm by Calamity »
Trnzaddict
« Reply #6 on: January 11, 2019, 03:58:10 pm »
Hi Calamity, sorry for the late response, even with changeres 0 on carnevil.ini, the throttle is still broken.
Is it doing it on your build? I even tried both
Switchres 0
changeres 0
doesn't make a difference. Still running at 290% :( Is there anything else I'm missing? New Log Included.
« Reply #7 on: January 13, 2019, 02:13:26 pm »
Check this:
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -waitvsync
You have triplebuffer disabled now.
The options you need to apply are:
-autosync 0     (which will in turn disable -syncrefresh)
-triplebuffer 1
-changeres 0
Trnzaddict
« Reply #8 on: January 14, 2019, 04:21:24 pm »
Check this:
-triplebuffer 1
-changeres 0
Hi Calamity, throttle still broken :(
I have made a carnevil.ini with just these 3 options
autosync 0
triplebuffer 1
changeres 0
No difference.
New log posted. Is this happening on your set up? It could very well just be broke in newer builds? Can anyone try this game and see if it is still broke or something on my side?
Upon looking at the log it seems that MAME is ignoring my ini files? It still shows:
but I know MAME is reading my ini files because it I set framedelay to 9 on carnevil.ini it slows the game to a crawl. Really stumped here.
« Reply #9 on: January 14, 2019, 04:44:12 pm »
Check:
SwitchRes: Setting option -triplebuffer
Syncrefresh should be disabled. It's enabled because you have some ini getting in the middle.
Start from scratch. Download my package. Unzip in new folder. Edit monitor settings, roms. Command line: mame64 carnevil -noautosync -triplebuffer -nochangeres
EDIT: Or, with your current installation, command line: mame64 carnevil -noautosync -nosyncrefresh -triplebuffer -nochangeres
« Last Edit: January 14, 2019, 04:46:42 pm by Calamity »
Trnzaddict
« Reply #10 on: January 14, 2019, 08:20:13 pm »
Check:
Ok, adding syncrefresh 0 to carnevil.ini fixed everything. It could of ignored autosync because I have my mame.ini file in my GM executable folder that is used for all games and autosync is enabled but I have specific game ini’s in the ini folder. I thought those were supposed to have precedence over the global ini when mame launches??
Also used this for Maximum Force and Area 51. Everything works great now, thank you so much!
DaddyLongLegs
  • Last login:October 11, 2021, 02:23:36 pm
« Reply #11 on: May 03, 2020, 07:50:21 am »
I am having this exact same issue but the conclusion isn't exactly obvious to me. Do I simply create carnevil.ini, place it in MAME\INI\presets, and the only thing that needs to be in the carnevil.ini file is "syncrefresh 0" and that's it?
Trnzaddict
« Reply #12 on: May 04, 2020, 08:51:01 am »
Try:
triplebuffer  0
syncrefresh 0
waitvsync 0
DaddyLongLegs
« Reply #13 on: September 22, 2021, 11:02:13 am »
Try:
triplebuffer  0
syncrefresh 0
waitvsync 0
Thanks so much for this.
The only thing I am noticing is there's really bad screen tearing. Is there any way to fix that?
If I don't use this custom ini, the screen tearing is gone, but the game runs at the wrong speed.
« Reply #14 on: September 22, 2021, 01:09:07 pm »
This is a known issue with this game.
Since triplebuffer option is gone, try setting
syncrefresh 0
waitvsync 1
DaddyLongLegs
« Reply #15 on: September 22, 2021, 01:26:29 pm »
syncrefresh 0
waitvsync 1
This worked. You are amazing. Thank you so much!
