Author Topic: EXPANSE - A wall mount space themed cabinet (5-12, Cabinet Complete)  (Read 85545 times)
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
Starting up a new project. It's been at least 10 years since the last cabinet I made.
Project Goals
  • Single sheet of plywood
  • Wall mounted
  • Unique design
The Hardware
  • Mounting
  • Controls
    • Ultimarc Ultrastik 360 Sticks
    • Ultimarc ServoStik upgrades
    • Happ buttons
    • TurboTwist 2 Spinner
    • Happ 3" Trackball
    • Aimtrak Lightguns with Recoil
    • Ultimarc iPac
  • Audio
  • Monitors
    • Primary Display: LG 27MP48HQ-P 27" IPS Full HD 1920x1080 Monitor
    • Marquee Display: STi AMX2220ML 20" Wide LCD Panel
  • PC
    • Dell Optiplex 7040 Micro, i7, 8GB, 960GB storage
  • Software
    • OS: Windows 10  :(
    • Front End: Launchbox BigBox
Status
Cabinet - Complete
Light Guns - Pending
The cabinet uses two HDTV mounts to hang the cabinet on the wall over the top of a plugin.
Thanks for having a look and for any feedback.
« Last Edit: May 12, 2019, 06:57:37 pm by meltman »
  • Last login:Today at 12:23:39 pm
Re: Project REDSHIFT - a wall mounted 2-player upright
« Reply #1 on: October 17, 2018, 11:35:11 am »
The base of an arcade cabinet doesn't extend past the control panel. You are saving zero floor space unless you store stuff under the cab when it is not in use. You also sacrifice the ability to move it easily.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #2 on: October 17, 2018, 11:39:21 am »
This design will allow barstools to be tucked right up against, saving floor space.
Having it be easy to move isn't an objective. There's a spot on the wall where it's going to go and it will stay there.
I'd make the argument that any "skinny" depth cabinet needs to be anchored to the wall with kids around so unless I build a full depth one it wont be easy to move.
« Reply #3 on: October 17, 2018, 11:40:06 am »
Unless I am missing something. Disclaimer: drawings are not to scale.
Sent from my Pixel using Tapatalk
« Reply #4 on: October 17, 2018, 11:46:48 am »
Interesting design.  Why the overhang on the sides of the CP?
« Reply #5 on: October 17, 2018, 11:47:15 am »
It makes sense if you are going to store your bar stools under there. Otherwise you could anchor a skinny cab to the wall for more stability.
You have a clear idea of what you want to do. Good luck with your build.
  • Last login:Today at 12:16:07 pm
« Reply #6 on: October 17, 2018, 11:50:11 am »
Going to get started hopefully this weekend on making some templates out of hardboard to begin routing!
Interesting design.   ;D
One possible issue is the distance between the trackball and monitor bezel.
You might want to make a cardboard mockup to see if there is enough clearance to avoid jamming your fingers.   :cheers:
meltman
  • Brilliant!
    • My arcade gallery
« Reply #7 on: October 17, 2018, 11:56:15 am »
I can tell you dont live in Chicago - hah. It's worth it to design for bar stool storage.
Beer holding capabilities
Absolutely - good call mocking it up. Though the way I play goldentee is using two thumbs instead of whacking it like a maniac.
I'm going to have a piece of tempered glass over the monitor portion, then under the monitor will be an equal thickness speaker grill.
« Reply #8 on: October 17, 2018, 12:06:52 pm »
I would suggest keeping beverages off of the control surface. Beer has an amazing ability to spill spectacularly. A small end table works well. Your beverages are out of the way, but still close by.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #9 on: October 19, 2018, 11:11:15 am »
First round of tools arrived. This project gave me a great excuse to get these. Been wanting a router and saw for awhile now.
« Reply #10 on: October 19, 2018, 11:14:45 am »
This is how it starts. I hope you weren't too attached to your money. ;D
meltman
  • Brilliant!
    • My arcade gallery
« Reply #11 on: October 20, 2018, 05:52:11 pm »
Some work today started with supplies gathering.
Also received my Tripath amplifier and two very skinny speakers from Parts Express. These will go below the monitor.
Here's my ghetto work area under my kitchen.
And finally, some results. These are my router templates for the sides, and top/bottom of the control panel.
« Reply #12 on: October 20, 2018, 05:57:28 pm »
Normally I’m not a fan of wall-mounted cabs, but you’ve planned it out the right way. This one will work out. Kudos to you.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #13 on: October 20, 2018, 06:35:23 pm »
I appreciate that. I'm not normally a fan either, but I wanted to give this design a go. Usually they look quite weird like a bartop glued to the wall.
On PL1's recommendation, I've extended the play surface 2 inches so there will ample space for trackball play.
Thanks for suggesting that PL1!
markc74
  • Flipping out
« Reply #14 on: October 20, 2018, 07:56:11 pm »
I like it. I tried a wall mount a while ago but could never trust my daughter not to practice pull ups on it.
Looks like you've gone for a flat marquee against the wall. You could try some el tape behind some perspex and have some graphics on there if u wanted.
« Reply #15 on: October 20, 2018, 10:15:22 pm »
Exactly. A flat bartop causing you to stand a foot from the wall is a bad idea. This is more of a functional game countertop, which I can dig.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #16 on: October 21, 2018, 07:44:20 am »
You know too much.
Get out of my head!
meltman
  • Brilliant!
    • My arcade gallery
« Reply #17 on: October 23, 2018, 08:26:09 pm »
Not much progress. Spent a bunch of time refining the templates. I made sure they were smooth and straight and that the slots where the boards will "slot" together were dimensionally accurate.
Now that they are good I'll set up the router and make some real pieces soon.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #18 on: October 27, 2018, 07:39:53 pm »
Progress!
Traced the templates to rough cut with the jigsaw before routing.
Test fitting!
Much much sawdust after routing.
All clean.
Tomorrow I'm going to try and knock out the other panels, then cut the openings for the access doors under the control panel and on the bottom angled panel.
I have the monitor in my possession as well so I'll be tracing it out and getting the panel created for it as well.
« Reply #19 on: October 28, 2018, 02:36:08 pm »
You’re a brave soul. The words indoor, mdf, and routing should rarely be used together in the same sentence.
« Reply #20 on: October 28, 2018, 03:03:00 pm »
On an unrelated subject, why do you have at least 3 good sized water heaters in your basement?
« Last Edit: October 28, 2018, 04:11:20 pm by Mike A »
« Reply #21 on: October 28, 2018, 03:39:00 pm »
Different units in his building.
« Reply #22 on: October 28, 2018, 03:39:19 pm »
What's the name about?
Richie_jones
« Reply #23 on: October 28, 2018, 04:55:46 pm »
Cool design.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #24 on: October 28, 2018, 07:02:55 pm »
Object traveling away from you in space will shift spectrum toward red.
More updates!
Careful sanding. Man this is precise!
Lots of holes.
Still many more holes to drill.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #25 on: November 03, 2018, 04:39:23 pm »
More work complete. First I finished doweling the upper and lower panel, then test fitting.
Fits really well, almost like I 3D modeled it  ;D
Next up was to close the gap on the control panel. I decided to kerf around the edges.
Oh this will work okay!
Aaaand no. I managed to f' that up nicely.
New thought, let's groove the control panel upper and lower and do a hardboard filler.
Entirely too much time later this is where I'm at.
I need to add some support structure inside the control panel, but that is simple to accomplish. This essentially completes the cabinet structure.
Tomorrow I'll tackle control layout, monitor cutout, and access panels. More routing incoming!
BGoulette
    • lazerjoose.com
« Reply #26 on: November 03, 2018, 08:52:44 pm »
I'm putzing around with my router on other, non-arcade-related projects: I really like your hardboard solution! Looks great!
meltman
  • Brilliant!
    • My arcade gallery
« Reply #27 on: November 04, 2018, 11:01:12 am »
Thanks! I think it turned out pretty well.
I did have to use the router to thin down the 5/32" hardboard around the curves. That was too tight of bend for the full thickness.
markc74
  • Flipping out
« Reply #28 on: November 04, 2018, 05:10:36 pm »
Nice technique. Have done my fill of bending wood so know how much a pain in the ass it can be.
Were you planning on putting t-molding on the control panel top and bottom? If so you might want to be careful to make sure the grooves don't cut too far in and weaken the edges. Speaking from experience...!
meltman
  • Brilliant!
    • My arcade gallery
« Reply #29 on: November 04, 2018, 06:47:53 pm »
I am putting t-molding on the edges. I think I'm good, the grooves are 1/16th deep so just enough to hold the board in the slot. Definitely appreciate the warning!
Today we cut the bezel! Ignore my drawing all over it.  ::) The speakers are set lower which will make sense once I get glass over the screen.
My adorable little speakers fit perfectly in this 1 1/8" wide slot.
The monitor fits *exactly*. It's hard to see but the edge is rabbeted so the monitor is inset into the panel.
I also cut the access panel for under the controls. It will have a hardboard door when it's all said and done.
Somehow I managed to skip a picture of the lower main access door where the PC will hide. I'll get a pic later. It will also have a hardboard door.
Jimbo
    • Wood Finishes Direct
Re: Project REDSHIFT - a wall mounted 2-player upright (11-4, Bezel work)
« Reply #30 on: November 05, 2018, 05:28:53 am »
Looks good!  Nice sleek design   :applaud:
I'm curious, how did you get all your dowels to line up precisely?
I'm going to use dowels on my bartop project too.  I've 3D printed some little dowel template jigs to use, but curious to hear how you did it.
meltman
  • Brilliant!
    • My arcade gallery
« Reply #31 on: November 05, 2018, 08:13:17 am »
For the dowels, I carefully measured the spacing, then did the board edge first. I used this jig:
https://www.amazon.com/Milescraft-1319-JointMate-Handheld-Dowel/dp/B01M8L1WVN/ref=sr_1_6?s=power-hand-tools&ie=UTF8&qid=1541422928&sr=1-6&keywords=dowel+jig
Once those holes were drilled, I stood the board up against the other board (where the holes would align in the future), then carefully leaned it over, then put a dowel in, and marked each position.
Then I used a straight edge to center the board in it's proper position and use the same jig (with the edge guard removed) to drill each hole.
You kind of gotta look down the bore of the jig and eye-ball center as best you can. I think I had about 3 dowel holes I had to oblong a bit to make it go together. Not a big deal with all the dowels I used though right? Haha.
Jimbo
« Reply #32 on: November 05, 2018, 11:42:50 am »
Haha yeah.  Nice one.  Too many dowel holes shouldn't be a problem :)  Nice little jig that.  :cheers:
meltman
  • Brilliant!
    • My arcade gallery
Re: Project REDSHIFT - a wall mounted 2-player upright (11-13, New items)
« Reply #33 on: November 13, 2018, 05:29:41 pm »
Got a couple of outstanding items from Andy @ ultimarc. Thanks Andy!
I didn't have much time over the weekend to do any work on the cabinet. I did have time to start working on artwork, specifically the control panel. Slow process that.
meltman
  • Brilliant!
    • My arcade gallery
Re: Project REDSHIFT - a wall mounted 2-player upright (11-16, Panel Layout)
« Reply #34 on: November 16, 2018, 09:39:03 pm »
I'd love a bit of help on this if anyone can chime in. Here's an image of the control panel layout I'm considering. This will be a plexiglass inlay in the main panel.
I'm mainly looking to see if spacing is appropriate. I saw a thread before that discussed spacing but for the life of me cannot find it.
Input please - does the P1/trackball/P2 spacing look appropriate?
Laythe
  • Last login:February 04, 2026, 08:00:11 pm
« Reply #35 on: November 17, 2018, 01:25:08 am »
Your stick-to-buttons distance looks tight to me, just eyeballing it - does the joystick housing beneath the panel clear the button nuts?
meltman
  • Brilliant!
    • My arcade gallery
It should. Its an Astro city layout. I’ll print and confirm. The stick to button spacing is based off of this image http://tengokugame.free.fr/panel_scan_astro.jpg
Does the centering look correct? Like from an edge of panel to stick for P1 and edge of panel to buttons for p2?
« Last Edit: November 17, 2018, 08:45:24 am by meltman »
Laythe
Oh, cool.  If it's an existing pattern, it'll surely work as long as you're using a similarly sized stick.
There are several geometry-correct answers to problems like this but what matters is what looks right.
I think it looks okay.  I might try nudging the whole P2 setup a little left, but not much.  1/4 inch maybe, if those are 1 1/8 button holes?  But then I'd just be seeing if I thought that looked better or worse - it's fairly subjective.
meltman
  • Brilliant!
    • My arcade gallery
Really appreciate your insight.
After printing and seeing in the real, I have a few adjustments to make.
yo1dog
  • Last login:November 12, 2024, 04:38:47 pm
    • MikeArcade
« Last Edit: November 25, 2018, 12:28:02 am by yo1dog »
