Author Topic: javeryh's Small-ish Bartop ["Jack Attack!"]  (Read 218429 times)
Re: javeryh's Small-ish Bartop ["Jack Attack!"]
« Reply #360 on: March 14, 2019, 07:36:19 pm »
Whoa, rare mountain sighting!
« Reply #361 on: March 14, 2019, 08:01:00 pm »
Sounds good, I'll wait to hear from you.
OK - I measured the dustwasher and it is exactly 2" in diameter.  It's a Sanwa and is made for sticks without the cover around the shaft (smaller hole).  I don't have a clear one but I went ahead and ordered 2 of these: https://www.focusattack.com/clear-31mm-1-16-acrylic-dustwasher-fits-sanwa-jlf-without-shaft-cover/.  It is a different size than the one I have (31mm vs. the ~51mm Sanwa).
When you size the image, can you make it a few different sizes?  Like 1-15/16", 2", 2-1/16" for the 2" cover and 30mm, 31mm and 32mm for the one I just ordered?  This way, I could just print them all and use the one that fits best.  There is a slight lip around the dustwasher so maybe placing the decal inside of that would be best... not sure but I don't think printing a bunch will cost that much more.  What do you think?  I'm open to suggestions on how to make this work!
I'd say first off, determine how it plays being shorter vs longer... pick the one you prefer. Don't skimp on playability over the hassle of having to shave the mounting plate - you'll kick yourself.   Secondly, bolts showing is cool.   :cheers:
Good call!  I'll see what I'd prefer.  Honestly, I don't think the 1/4" will make a difference in playability but you never know...
Is there enough space to mount the joystick sideways? Turn it 90 degrees and wire it accordingly?
Unfortunately, no.  I tried this when I got home from work and it didn't fit.  I am using a ServoStik and it has a motor attached to the side of the joystick to turn the restrictor plate so the footprint is quite large.
How about removing some of the mounting plate. Looking at mine I could lose an 1/8 and still be able to use same bolt holes.
If I don't sink it into the CP I will definitely remove some of the mounting plate.  I checked and I can definitely remove enough and still preserve the bolt holes.  What should I use to cut the metal?  The mounting plate is kind of thick...
WOW! Blast from the past! Nice to see you still active. Your work is always spot on, great job. I'm due for a bartop someday.
mountain holy crap!  Nice to hear from you - hope all is well.  Get going on that bartop so you can put mine to shame!   :cheers:
Arroyo
  • Last login:September 12, 2025, 06:46:27 pm
  • Budgets are boring
« Reply #362 on: March 14, 2019, 10:34:30 pm »
I’ve ordered those and they are rather small in my opinion:
Focus Attack:
Graphic under clear dust washer (Sanwa JLF standard diameter):
Comparison:
Sure thing.  You want it in separate files or all in one?
EDIT:
BTW: the Sanwa JLF’s I measure at 1.48inches:
I grabbed the servo stick I have and yes the dust washer is much bigger:
The shaft diameter is the same.  What I didn’t mention is that I bought the clear dust washers from Art’s hobbies:
http://www.tek-innovations.com/arthobbies/?loc=products&cat=7&subcat=&item=46.
He has the the JLF size standard, but can cut any size you want.
« Last Edit: March 14, 2019, 10:59:41 pm by Arroyo »
  • Last login:November 21, 2025, 12:27:33 pm
« Reply #363 on: March 15, 2019, 05:36:43 am »
You ordered clear acrylic dust washers from some dirty stranger? I am insulted. Time to go cry in my beer.
Richie_jones
  • Last login:February 20, 2025, 01:55:28 pm
« Reply #364 on: March 15, 2019, 08:05:19 am »
Just use a grinder with metal disk to remove section of plate..
Arroyo
« Reply #365 on: March 15, 2019, 08:20:40 am »
Ah Mike you know I only have eyes for you ;-).  Yeah ask Mike for the dustwashers he does great work, and he party’s like a rock star.  Beer at 5am on a Friday eh Mike?
« Reply #366 on: March 15, 2019, 08:32:44 am »
Hey. It's St. Patrick's Day...almost.
Guinness Beef Stew and toast for breakfast.
A nip of Kilbeggan whiskey.
My wife was Irish. I am practicing Irish.
Arroyo
« Reply #367 on: March 15, 2019, 09:05:47 am »
Ah, St. Paddy’s day....
Sorry Javery, couldn’t help myself, poor attempt at humor.
« Last Edit: March 15, 2019, 09:41:23 am by Arroyo »
« Reply #368 on: March 15, 2019, 02:26:34 pm »
Focus Attack:
Comparison:
EDIT:
Thanks for the pics.  I think I actually like the smaller ones better.  The 2" dust washer takes up most of the yellow box on the CP and it's too much.  So if the smaller dust washers will work, let's go with that.  So I only need 30mm, 31mm and 32mm diameters on the art (I think).  Separate files are probably best - when I send them to Scott at gameongrafix I think his printed will cut the vinyl to the exact size I need.  Last thing I want to do it try and cut out a circle with a razor by hand!
Sorry Mike - had I known...
I'm going to have to buy this tool.  I have a dremel - maybe one of the attachments will work?  Hacksaw seems like it would take forever and just sticking it under the chop saw seems like a recipe for disaster...  I'm going to post some pics of the issue so you can get a better idea what I mean.
Arroyo
« Reply #369 on: March 15, 2019, 02:41:49 pm »
I placed the graphic on first and then used an Exacto to follow the dust washer like a template, just like installing sideart.  I'd suggest getting a few printed as it can be difficult to get the alignment right.  May want to get a couple that aren't pre-cut in case the larger size material helps with alignment (more for your hands to grip on to).
I'll work on the art files and send it your way as soon as possible.  Question, the circle graphics in the front vary a little, did you have a preference? I used the one on the very left, under the joystick, but maybe you like the one on the right better.
« Reply #370 on: March 15, 2019, 02:57:02 pm »
OK - so you actually cut them out yourself?  I can give that a shot (even though I struggled with the side art haha).  I don't have a preference on the art.  Whatever you think will look best.
So the second pic you posted is a clear dust washer with the vinyl graphic on the bottom?  It looks great.
Arroyo
« Reply #371 on: March 15, 2019, 03:01:16 pm »
Yup, and it actually has some issues in that the vinyl graphic I used had a thicker material underneath it with adhesive put on by the printing company.  Didn’t cut as smoothly as I would have liked.  With standard vinyl like I have on the main graphics of my control panel however it’s much easier.  So shouldn’t be too bad.  Bigger issue is getting the alignment right and choosing your adhesive.
« Reply #372 on: March 15, 2019, 06:14:09 pm »
OK cool - I'm going to go for it.  Seems doable.
Here's a stupid video of what is going on with the joystick mount:
What is the best way to cut the plate?  A grinder of some sort seems like it would work but I honestly have no idea as I have never worked with metal before and this is a fairly thick/solid piece.
And here are some pics:
This is probably the best shot to give you an idea of the issue.
Here's an overhead shot - super tight fit!  The motor just barely fits in there.  Going to be fun to wire this panel up!
This is probably where I'd have to cut.  Clears the bolt holes... although the bolts might present an issue if they are close enough to the angled section (I think it will be OK).
« Last Edit: March 15, 2019, 06:15:51 pm by javeryh »
JDFan
« Reply #373 on: March 15, 2019, 08:58:11 pm »
Angle grinder for $10 from harbor freight would do it !
  • Last login:Today at 11:29:09 am
« Reply #374 on: March 15, 2019, 09:06:45 pm »
There are a number of cutoff wheels that can cut through that plate.
I'd recommend the 426 (5 pack) or 426B (20 pack) reinforced wheel.
If your Dremel came with them, 420 wheels might work, but they will wear out very quickly and break very easily.
True, but it's more of a chainsaw than a scalpel.   :lol
EDIT: Forgot to mention the EZ456 or EZ456B if you have the EZ Lock mandrel.
« Last Edit: March 15, 2019, 09:17:41 pm by PL1 »
JDFan
« Reply #375 on: March 15, 2019, 09:12:27 pm »
Yep but they'll cut through just about anything and for the price it's definitely worth having around next time you've got to cut through something !  :cheers:
Richie_jones
« Reply #376 on: March 16, 2019, 03:24:16 am »
If you don't have the tools take it to a car garage and slip them a fiver. Sure they'll cut it off easy
firedance
  • Last login:Today at 07:01:01 am
« Reply #377 on: March 16, 2019, 01:26:48 pm »
all you may need is a metal file as you don't need to remove that much metal. such as this  - https://www.harborfreight.com/hand-tools/files/8-inch-flat-file-96626.html
maybe slower but can be more precise, defo no angle grinder, will only end in tears  :o
could always saw it off - https://www.harborfreight.com/12-in-hacksaw-62780.html
Laythe
« Reply #378 on: March 16, 2019, 07:09:55 pm »
For the amount of steel you need to remove, I'd use a belt sander.
« Reply #379 on: March 25, 2019, 02:55:07 pm »
Thanks for the suggestions - I'm going to try and get it cut this week.  I should have time going forward to focus on this stupid cabinet until it is complete.  Had my fantasy baseball draft in AC over the weekend so I didn't get anything done... I'm also exhausted but it was fun... other than my team, which probably stinks.  I'm trying to get organized so I'm typing out a punch list...
Revised Punch List:
  • Drill 4 holes in front of CP for admin buttons using forstner bits
  • Drill 4 holes in corners of CP for bolts to attach CP to cabinet
  • Either (1) route out 1/4" of material under CP to recess joystick and drill 4 holes for through bolts to hold joystick in place OR (2) use 1/2" screws from under side of CP to hold joystick in place.  I'd like to do #2 because it is easier but I am not sure if the screws will come loose over time.
  • Print dust washer art
  • Install t-molding
  • Install monitor to inside of cabinet against bezel
  • Polish edges of clear dust washer with Novus
  • Attach dust washer art to bottom of clear dust washer
  • Figure out how to control ServoStik motor with Raspberry Pi
  • Create splash screen or intro video for Raspberry Pi boot
  • Configure Raspberry Pi
  • Wire everything
I think that's it.  Not too much left.  I hope to at least finish the CP stuff, monitor install and t-molding by the end of this coming weekend.  Software stuff will take me a little while because of my brain deficiencies in that area.   :cheers:
yamatetsu
  • Last login:Today at 10:53:30 am
  • Just because.
« Reply #380 on: March 25, 2019, 04:16:50 pm »
Just put insert-nuts into the holes. They'll hold the screws.
« Reply #381 on: March 25, 2019, 05:00:53 pm »
For #2, threaded inserts with wide, flat outer threads are your friend.
GGG inserts are great.
Ultimarc inserts are great.
Inserts with narrow outer threads are . . . not-nearly-as-good for MDF.  They are designed for hardwood.
Check out "Mounting controls in the control panel -- Hardware", "Under mount (threaded inserts)", and "Under mount (support blocks)" sections in the FAQ.
https://web.archive.org/web/20160809113045/http://newwiki.arcadecontrols.com/index.php?title=FAQ#Joysticks
« Reply #382 on: March 26, 2019, 09:30:52 am »
Thanks - just ordered from GGG.  Hopefully it arrives by the weekend!
Looks like I'm cutting the mounting plate back instead of sinking it, which I think is the right call.  The extra 1/4" height in the joystick doesn't matter and on a build this small I think having the stick sit a little bit lower works better (won't block the screen, looks good proportionately, etc.).   :cheers:
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
« Reply #383 on: March 26, 2019, 09:34:22 am »
I agree, cutting the plate is the right call. Excited to see this one come together. Great craftsmanship.
« Reply #384 on: April 08, 2019, 11:48:22 am »
Thanks!  I'm taking my time (obviously) but also finding the time has been extremely difficult.  I think it is the perfect storm of the ages of my kids.  There is always something I have to go to or shuttle them to, etc.  There is barely any time to keep the house running (groceries, laundry, lawn care, etc.) never mind extra time for hobbies.  Things are actually less stressful at work than they are at home!
Anyway, I drilled some holes and cut the joystick mounting plate this past weekend.  It's progress!
The process was the same as the action buttons:
- use an awl to mark the center
- drill 1/4" down (this time with a 24mm forstner bit)
- use 1/16" drill bit to drill through center all the way through the panel
- use larger forstner bit from the back so that there is room for the button nut
Here's a front shot of all 4 buttons drilled down 1/4" except the one to the far right is finished.
Here's a close up of the front - I used painter's tape to try and preserve the art.
Here's a close up of the back.  You can see the other pilot holes to the right of the hole that is drilled where the other buttons would go.  This entire process would be MUCH easier with a drill press but I don't have one so I had to just wing it.
All 4 button holes are drilled out and ready for test fitting.
Looking good.  I was nervous about the buttons on the end because they had to be dead on due to the art - I think it came out pretty nice.
This is how it will look when the cabinet is finished in 2025.
I'm going to need to make some button inserts for the admin buttons so people will know what they do.  I'm not sure exactly what I'm going to call them.  The button on the far left will probably be "Exit" and the button on the far right will probably be "Pause" but the middle 2 are kind of weird.  For MAME, one of them will need to be "Coin" and the other "Start" but for any consoles they will need to be "Select" and "Start".  I probably should have thought this through...
Jimbo
    • Wood Finishes Direct
« Reply #385 on: April 08, 2019, 12:04:36 pm »
Looking good!  :applaud:  Scary stuff done!
Having a dedicated EXIT button is a good idea.  On my Videotron bartop I used the Retropie default of START+COIN to exit from games, and because I put those two buttons together, it's quite easy to hit them both at the same time when you're trying to coin up and start a game (kids do this like mad putting loads of coins in all the time).  In hindsight I'd have separated the buttons a little.  So you'll probably want to remove that configuation so it doesn't happen on yours :)
« Reply #386 on: April 09, 2019, 10:54:38 am »
Thanks Jimbo - I'm also concerned about accidentally hitting the Exit button but I'm not sure I want to complicate matters by adding a hot key function or something.  I'm really undecided on the admin button functionality.  I know I want Exit and Pause and I need P1 Start at least and probably Select for console games if I decide to add any but not sure how to set everything up.  That's future me's problem when I start trying to configure everything.
This weekend I should be able to attach the CP to the cabinet.  After going back and forth in my head a million times I'm leaning towards using 4 rare Earth magnets - that should be enough to hold it in place while playing.  I'm just not ready to drill holes all the way through the CP!  If they don't work, I could always add the through bolts later on... probably.  This leads me to the second thing I'm going to do - install the joystick using the undermount kit from GroovyGameGear.  The issue is that the bolts and inserts are 1/2" so it leads me to believe they are meant for 3/4" panels.  But with the thickness of the joystick mounting plate (1/16") plus the thickness of the artwork (1/64") and maybe a washer I think I could drill down about 3/8" and make it work.  I will need to be super steady with the drill, which makes me nervous.
If I get these things done, I'll install the monitor and t-molding and then start trying to hook everything up.  Finish line is in sight.
I did manage to cut the joystick mounting plate with my Dremel on Sunday.  It wasn't too bad although I probably could have been a little neater.
Seems like it will work.   :cheers:
« Reply #387 on: April 09, 2019, 10:57:18 am »
How many Dremel discs did you shatter?
« Reply #388 on: April 09, 2019, 11:25:05 am »
Haha - zero actually.  I was wicked nervous about it though.  I did it in steps - cut about 1/2" on the line and then cut perpendicular to remove that piece and repeated this all the way across.  I noticed quickly that I couldn't cut it all in one shot because the disc could get jammed easily.  I was also worried that a piece of metal was going to go flying too.  Had the heavy duty safety goggles on and everything.  I cut it outside on my work bench even though the pics were taken in my basement where I've been working on it.
« Reply #389 on: April 09, 2019, 11:30:13 am »
They must make them more sturdy than they used to.
I am glad it worked out for you. This should bump the completion date to somewhere in 2525.
Richie_jones
« Reply #390 on: April 09, 2019, 12:03:24 pm »
Have you de burred that edge..looks sharp
« Reply #391 on: April 09, 2019, 02:38:19 pm »
Current schedule is now bumped up to 2025 - high school graduation present.
I did de-burr it... by basically grinding the edge of the wheel along the edge on both sides.  Seems OK...
Jimbo
« Reply #392 on: April 10, 2019, 04:48:31 am »
The default for retropie is start+select for exiting an emulator, which I use on the usb controllers for console games.  I doubled this up to have the coin button on the control panel mapped to select also.  This works fine, people know to hit start and coin together to exit from mame games, and I don't need a dedicated exit button.  The *only* problem I had was I put start and coin too close together that they sometimes trigger exit when pressed madly by the kids (although they are aware of it now they do it much less).
« Reply #393 on: April 11, 2019, 04:51:05 pm »
This sounds perfect.  I'm envisioning it being something like this for the 4 buttons on the front panel:
Consoles:  EXIT ------- SELECT - START ------- PAUSE
Arcade:  EXIT ------- COIN - START ------ PAUSE
Is that something I can easily set up?  I know the default EXIT in Retropie is START+SELECT but there has to be a way to remap this... I hope.
J_K_M_A_N
« Reply #394 on: April 11, 2019, 05:18:18 pm »
If you take out the hot key trigger, then you can use any of the buttons for any of the hot key functions (but they can't be used for regular buttons). When you set up a controller, just hold down a key for the hot key (long enough to make it cancel) and it will ask you if you want to use the select key as the hot key trigger and say no. That is what I do when using the PI for emulation. I like a dedicated exit button and pause and speedup.
J_K_M_A_N
« Last Edit: April 11, 2019, 05:20:00 pm by J_K_M_A_N »
Jimbo
« Reply #395 on: April 12, 2019, 05:51:28 am »
Yep you can sort it like that no problem.  Good plan.  :cheers:
« Reply #396 on: April 12, 2019, 11:43:56 am »
Thanks guys - that's good news.  I'm sure I'll have some questions when the time comes but at least in my head everything seems possible!
So... I'm about to attach the CP to the cabinet and I've decided to try using some 1/4" rare Earth magnets to hold it in place.  I think with these things in the 4 corners of the CP (8 total magnets) it should be quite secure but I really won't know until I finish and start playing on it.  As it is now, there is no side to side movement of the CP and you also cant move it forward and that's with nothing holding it in place so really I'd only have to worry about it coming off if someone pressed down (or pulled up) on the joystick too hard.  Seems unlikely.
Right now, my plan is to (somehow) locate the spots on the underside of the CP and the 1/2" rails that support the CP where I will carefully drill out a hole the same depth as the magnets.  Then I'll epoxy the magnets in place with the tops hopefully being flush to the surface.  I'm actually going to place the magnets about 1" away from where I would try to use carriage bolts or something just in case the magnets don't work so I'll have a place to drill without needing to remove them.
Does anyone have any thoughts/experience with this? Or tips?
Arroyo
« Reply #397 on: April 12, 2019, 11:59:59 am »
Any reason not to use magnets that are countersunk and just screw them in?
https://www.amazon.com/dp/B071ZKQ2X5/ref=cm_sw_r_sms_c_api_i_EwlSCb3X0R4H8
« Reply #398 on: April 12, 2019, 03:58:22 pm »
I don't have that much room, unfortuantely.  The magnets need to be somewhat tiny because I'm sinking them into the 1/2" wide rails that hold up the CP.  I also only have 1/2" of material to work with underneath the CP so screws would likely want to pop through the top.  Maybe they make these things in much smaller sizes?
Arroyo
« Reply #399 on: April 12, 2019, 06:55:24 pm »
