Author Topic: First Cabinet Build: I have no idea what I'm doing  (Read 197745 times)
ivwshane
    • My first mame cab! (WIP)
Re: First Cabinet Build: I have no idea what I'm doing
« Reply #80 on: May 19, 2018, 09:37:41 pm »
I'm pretty sure you will need a pedestal for this. I think I covered how to do it already.
« Last Edit: May 20, 2018, 07:28:06 pm by ivwshane »
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
« Reply #81 on: May 19, 2018, 09:46:41 pm »
I'm pretty sure you will need a pasta for this. I think I covered how to do it already.
You suggested a podium, which I’m not interested in.
  • Last login:Today at 03:55:38 pm
« Reply #82 on: May 19, 2018, 10:16:36 pm »
Change the angle of the CP to 5 degrees.  Generally the back panel is 1" taller than the front but your CP is so big that you may have to go to 1-1/4" or more.  10 degrees is way too steep, IMO.  You may also have trouble with the trackball not rolling as smooth as it should because of gravity.
For structural support, build a u-shaped column underneath it in the center that sticks out from the bottom front panel - there are lots of ways to make this look nice.  Something like this (not perfect but you get the idea):
obizues
« Reply #83 on: May 19, 2018, 10:23:46 pm »
Very interesting.
Any idea what angle the display is on this example?
luizw81
  • Last login:December 05, 2022, 12:39:36 pm
  • I love the Power Glove. It's so bad.
« Reply #84 on: May 19, 2018, 10:38:39 pm »
I hope some little kid doesnt jump up and hang from the center 2 sticks or else you you'll have to use their college fund for funeral expenses.
I was never a fan of the cab you based this design on, and you somehow found a way to make it worse by making it thin profiled.  Have you considered a more NBA Jam shaped control panel? Hope you have great medical insurance too, so you can get carpal tunnel surgery from that CP angle after you're done burying children.
Besides the much appreciated well-wishes for my health and finances, which part of the NBA Jam CP are you referring to?  That it's rectangular or there is "more" space in your opinion for your hands/arms than mine has to properly rest on?
I can from images the NBA Jam CP is taller so it would only result in forearm surgery or taller kids hanging from the center sticks, so is that what you mean?  Or is there a single shotgun blast that fires when someone does that on the NBA Jam cabinet I have forgotten?
I think Malenko is referring to the shape of the CP.  He's not a fan of the aircraft carrier design.
His carpal tunnel comment is due to the extreme downward slant of the CP.  You might want to straighten it up a little.
Sent from my SM-J320R4 using Tapatalk
  • Last login:Today at 02:59:21 pm
« Reply #85 on: May 20, 2018, 05:43:24 am »
I don't normally suggest this, but I think the OP should consider buying a cab. It doesn't seem like he has the skill set to build a cab. I  don't want to insult you, but there are so many red flags in all of these posts. It seems like you are in over your head.
« Reply #86 on: May 20, 2018, 08:59:51 am »
You got it! But the kid grabbing the joysticks comment is more about the center mass of the cab. I don't think they'll be much unsprung weight to the cab so it will be very prone to tipping unless hes going to fill the bottom with sandbags or weights. The angle of the CP just adds to the problem. Here's my CP for my old 4 player MAME cab, exact same dimensions as NBA Jam/Open Ice/ NFL Blitz (ya know, actual 4 player games)
Changes made:
aligned the sticks so that smash TV, Karate Champ, Robotron, etc could be played on each set of sticks
adjusted the button positions for player 4 a little bit
added more buttons to the center players
had a button UNDER the CP, wired to ESC
« Reply #87 on: May 20, 2018, 09:24:15 am »
Well it's a random pic from the internet so I have no idea but if I had to guess I'd say around 5 degrees, like most cabs.
obizues
« Reply #88 on: May 20, 2018, 11:00:57 am »
May I direct your attention to the title of the thread?
« Reply #89 on: May 20, 2018, 11:29:03 am »
The title is the first red flag.
obizues
« Reply #90 on: May 20, 2018, 12:18:53 pm »
I hereby officially dub this:
Project: Red Flag
obizues
« Reply #91 on: May 20, 2018, 12:34:37 pm »
Back to more interesting endeavors... of mocking out my control panel...
Since FedEx had problems.. I printed out the .pdf on my fancy Epson XP-440 and measured the CP length-wise and it appears to be what I expected.  It's just over 53 1/4 freedom units (inches) or roughly the 1358mm that Sketchup is telling me.  So that means I'm in business.
She's a big girl, well suited for her state's love of cheese, beer, and brats.  Maybe I'll use that as my theme.
« Reply #92 on: May 20, 2018, 01:02:59 pm »
That is 20 inches wider than a Konami 4p control panel. It is way too big. I am the only one giving you the right advice right now. Don't build this. Your design is terrible from top to bottom.
obizues
« Reply #93 on: May 20, 2018, 01:29:40 pm »
Yup it’s a big girl.  It’s actually smaller than a few people wanted me to make it based on the input I’ve recieved believe it or not.
But that’s why we mock it up huh?
« Reply #94 on: May 20, 2018, 01:37:53 pm »
Nobody who knows what they are doing would ever suggest a larger control panel than you are proposing. You don't have to mock it up to realize it is way too big. I am not entirely sure you are for real.
obizues
« Reply #95 on: May 20, 2018, 01:54:56 pm »
Well it’s a good thing I’m mocking it out then so I can come to the same conclusion as you, right?
« Reply #96 on: May 20, 2018, 02:09:22 pm »
Good luck with your build. You obviously don't want my advice so I will stop providing it.
jennifer
« Reply #97 on: May 20, 2018, 02:11:45 pm »
**Observations... I like the big look of it, but keep in mind moving it and doorways, at best keep the width around 34" after the C/p is removed, The tilt of the c/p is a bit much, not only will it be uncomfortable to play for extended periods but your going to get spilled drinks all over it. 2 players is all you need, lots of elbow room for fighter games....And that 4slot coin door is hands down the dumbest thing Jenn has ever seen put to steel.
  • Last login:Today at 01:01:52 am
« Reply #98 on: May 20, 2018, 02:50:10 pm »
You BARELY came to that conclusion? :)
« Reply #99 on: May 20, 2018, 03:04:06 pm »
I said it was obvious.
obizues
« Reply #100 on: May 20, 2018, 03:31:42 pm »
That’s a bit dramatic.
obizues
« Reply #101 on: May 20, 2018, 03:38:50 pm »
I would also agree the tilt will come up. Someone told me 5-10, I started at 10.
I haven’t concluded I don’t want to do 4-players, but without the CP this would be 2’ 7 1/2” wide or 31 1/2”
I’m still middle-ground on a coin door, but it would be 4 or nothing.
« Reply #102 on: May 20, 2018, 04:38:02 pm »
So you think this is 10 degrees?As long as this picture is a true orthographic angle, it isn't. Great to see that you'll follow someones advice, even if its terrible.
I look forward to you being stubborn and doing it your way, I'll be pop corning it up enjoying the show.  Build what you dig.
« Last Edit: May 20, 2018, 04:41:36 pm by Malenko »
« Reply #103 on: May 20, 2018, 05:36:04 pm »
You are obviously going to do what you are going to do and I'm actually looking forward to watching how this all turns out but 53-1/4" is absolutely gigantic.  4 and a half feet!!!  It is ridiculously big and there is no scenario where this is the correct solution.
obizues
« Reply #104 on: May 20, 2018, 05:49:06 pm »
:laugh2:  Man you guys are a trip.  “Listen to advice!”  “You listen to terrible advice!”
I’ve also already said that the angle is coming down... but just because it’s funny to me...
You can clearly see that the picture is not parallel with an X or Y axis, but that didn’t stop you from drawing an arbitrary line to “measure” my angle and prove me wrong.  :lol
But PLEASE continue to try to make fun me trying to create something that I haven’t done before and act like you are holier than though, because it’s really damn funny when someone overshoots their shot like this and ends up looking like a jerk and a fool.   :afro:
obizues
« Reply #105 on: May 20, 2018, 05:50:36 pm »
Yeah, it’ll end up shortening like I’ve said, but it’s a start to physically mock and feel where I can start to cut out space.
ivwshane
« Reply #106 on: May 20, 2018, 07:36:43 pm »
You might be right. When someone doesn't want to address a potentail physical hazard that can severely hurt a child, well, that's when I bow out.
Good luck op.
« Reply #107 on: May 20, 2018, 07:38:14 pm »
Good luck op.
We really need a rep button. At least a thumbs up.
obizues
« Reply #108 on: May 20, 2018, 07:39:49 pm »
Good luck op.
Pretty sure paper and cardboard won’t hurt a child, but you do you.  :dizzy:
The drama in this forum today is real.  :o
« Reply #109 on: May 20, 2018, 07:52:45 pm »
I couldn't really tell, that's why I said if it was an orthographic angle.
https://en.wikipedia.org/wiki/Orthographic_projection
That being said, you've ignored gobs of good advice but accepted a 10* angle as something you should do. I'm unaware of how exactly I made fun of you or acted "holier". I said I don't like the cab you based this on. I said it looks worse with a thin profile. I said the CP Angle is too great. I said the center mess is too far off so its a tipping hazard.  I've build a ton of cabs and made a ton of mistakes. If you'd rather remake the same mistakes all over again then who am I to stop you?
« Reply #110 on: May 20, 2018, 07:55:09 pm »
OP, I’m just going to give you food for thought...
Your control panel is 5 1/4 inches wider than this one...
Reference:
http://forum.arcadecontrols.com/index.php/topic,94966.msg998943.html#msg998943
« Last Edit: May 20, 2018, 07:57:38 pm by yotsuya »
« Reply #111 on: May 20, 2018, 08:04:36 pm »
Reference:
Oh. My. God.
obizues
« Reply #112 on: May 20, 2018, 08:23:25 pm »
I don’t have the desire to continue a pissing contest with you or anyone else, especially when it is intertwined with that person saying I’m doing “X” when that simply isn’t true. In fact I’ve said multiple times it isn’t- yet here we are.
I appreciate constructive criticism, I don’t even mind harsh criticism. What befuddles me, and just makes me laugh, is this weird type of projection that you and some others continue to put on my design.
So feel free to tell me doing X is dumb, or better yet suggest I do Y because Z. But please don’t tell me my cabinet has AIDS and farted on your mother’s eyeball unless you have some sort of reason to claim that. Otherwise this all gets very confusing.
obizues
« Reply #113 on: May 20, 2018, 08:29:13 pm »
Yeah that’s pretty messed up, they didn’t even add room for a trackball. Talk about bending the knee...
I’m already cutting out sections on mine now that I have it in front of me and I have sticks in place so I’m able to “feel” what it’s like standing next to someone to figure out how much space I really need between P3 and P1, and p2 and p4.
What I struggle with is how much space I need between P1 > trackball > p2
obizues
« Reply #114 on: May 20, 2018, 09:46:13 pm »
Okay, better update after doing the mock-up:
It looks like after my first test I can cut out 190mm, or 7.48 freedom units.
Checked hand placements and stick movement overlap:
Not too shabby for first go, and yes those are some sweet moccasins:
... which by the way makes my new draft model a whopping 2 1/4” (ish) inches less-wide then yotsuya’s dredded Snow Brothers machine. ... that’s enough room for cup holders!  :cheers:
  • Bitches love Centipede
« Reply #115 on: May 21, 2018, 12:05:35 am »
Stop calling them "freedom units". Americans didn't invent the imperial system, and if anything, our lack of adopting the metric system may be a contributing factor to the idiocy of our youth.
%Bartop
jennifer
« Reply #116 on: May 21, 2018, 12:18:29 am »
  The metric system?.....Hee,Hee :laugh2:, Ya that totally dumbed down society....(Giggle) From here on out Jennifer will just be her own assistant to human resources ....OMG, (Laugh, and Laugh)
jennifer
« Reply #117 on: May 21, 2018, 12:20:45 am »
**Jennifer still laughing....Lets make freedom units "Great again" :laugh2:
« Reply #118 on: May 21, 2018, 12:40:58 am »
A base 10 system is dumb? 1 foot is cut into 12 inches... 1 inch is broken into half, fourths, eighths, sixteenths, thirtyseconds, sixtyfourths, etc... Clearly imperial is the practical way to go (thick sarcasm for those who never catch it)... And even the OP posted in hundredths of a "freedom unit" while all his measurements on this printout are in millimeters... ::)
« Last Edit: May 21, 2018, 12:43:58 am by Nephasth »
%Bartop
« Reply #119 on: May 21, 2018, 08:07:32 am »
I haven't projected anything, you're just being butthurt about what I typed for some reason.
That last line is just utter horseshit.
