Author Topic: How should i fasten down my CP?  (Read 1850 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: February 02, 2018, 11:26:56 pm »
I really dont want to go from the top as you would see screws unless there is another way to do it or i can screw it down from the sides.  I also thought about going from the sides using 1/8 pressure pins that i would just squeeze in at the bottom flush to the cp so i could swing it open then use 2 more pins on the top sides and put a ring on the pins so i could pull them out easily.
Any ideas would be appreciated :)
Or i could put some L brackets underneath which would make it so i dont need any screws on top or the side
http://i1207.photobucket.com/albums/bb472/equlizer36/2018-02-02%2021.09.59_zpsg0mlmq6i.jpg
http://i1207.photobucket.com/albums/bb472/equlizer36/2018-02-02%2021.10.19_zpsad4lqzz9.jpg
http://i1207.photobucket.com/albums/bb472/equlizer36/2018-02-02%2021.03.21_zpskkaeety4.jpg
« Last Edit: February 02, 2018, 11:50:21 pm by equlizer »
Thenasty
  • Last login:January 29, 2026, 11:38:03 am
Re: How should i fasten down my CP?
« Reply #1 on: February 03, 2018, 01:29:13 pm »
Free VGA Breakout Cable
equlizer
« Reply #2 on: February 04, 2018, 04:14:25 am »
« Last Edit: February 04, 2018, 04:21:20 am by equlizer »
GeoMan
  • Last login:January 01, 2026, 09:49:39 am
« Reply #3 on: February 04, 2018, 08:26:16 am »
Magnets?
