Author Topic: emu4crt Mednafen mod - update 1.26.1  (Read 209583 times)
silmalik
  • Last login:April 16, 2022, 09:08:13 am
    • Mednafen emu4crt mod
Re: emu4crt Mednafen fork - update 1.22.1 / A09
« Reply #120 on: March 05, 2019, 07:03:17 pm »
Here we go!  :)
New revision, align on Medafen last version.
Snes_Faust module added.
purity1516
  • Last login:May 28, 2019, 04:32:32 pm
« Reply #121 on: March 07, 2019, 03:17:11 pm »
Nice work!
naoto.awai
  • Last login:August 19, 2025, 08:25:57 am
« Reply #122 on: June 09, 2019, 09:36:59 am »
Thank You for your great work!
I'm using the last release of emu4crt with Attract Mode 2.5.1 on Windows 7 pro x64.
I'm also using Calamity's driver to output @15 kHz
Emu4crt folder is placed inside my home directory, so I don't have to worry about Windows write-restrictions.
I've manually changed the following parameters in mednafen.cfg:
video.fs 1
video.resolution_switch super
When I run emu4crt from command line, everything works as It's supposed to.
Even if I exit and re-launch the .exe hundred times, the updated mednafen.cfg is stored without any changes.
If I run emu4crt from Attract Mode, only at the first launch full screen and super resolutions works.
This happens because mednafen.cfg is correctly read.
When I exit from Attract Mode to Windwos desktop, the following mednafen.cfg lines are lost:
;Enable time synchronization(waiting) for frame blitting.
video.blit_timesync 1
;Deinterlacer to use for interlaced video.
video.deinterlacer weave
;Attempt to disable desktop composition.
video.disable_composition 1
;Video output driver.
video.driver default
;Enable frameskip during emulation rendering.
video.frameskip 1
;Enable fullscreen mode.
video.fs 1
;Display to use with fullscreen mode.
video.fs.display -1
;Attempt to synchronize OpenGL page flips to vertical retrace period.
video.glvsync 1
;Video resolution switch (0, native or super).
If I don't manually add them, Attract Mode launches emu4crt with a default mednafen.cfg that doesn't included the lines shown above.
Any ideas ?
Thank You in advance!
silmalik
« Reply #123 on: June 12, 2019, 01:06:43 pm »
Hi,
Nope, no idea  :dunno
I’m using other frontend, without issue.
Could you try with official Mednafen release?
We also might learn something from the log file  ;)
Substring
  • Last login:Yesterday at 05:42:15 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #124 on: June 13, 2019, 04:02:27 am »
Hey silmalink
Is your patch ok for mednafen 1.22.2 ? (before I try by myself :D)
silmalik
« Reply #125 on: June 13, 2019, 12:12:05 pm »
Hello Substring,
Nope, not tested on latest release.
I’m busy with other personnal project, I will have a look on a later time.
Please, feel free to report result if you try by your own.   :)
Substring
« Reply #126 on: June 13, 2019, 04:26:57 pm »
Having quite some trouble to apply your patch, even on 1.22.1 (on linux i should say).
In fact, there is a circular reference : include/mednafen is a symlink to src/, so some files get patched twice, and of course, patch complains that it's alerady applied.
For example :
https://github.com/emu4crt/files/blob/master/patches/mednafen-1.22.1-emu4crt-A09.patch#L23 and https://github.com/emu4crt/files/blob/master/patches/mednafen-1.22.1-emu4crt-A09.patch#L1221 are the same patches
So it's hard to validate emu4crt on 1.22.2 :/
silmalik
« Reply #127 on: June 14, 2019, 10:25:35 am »
Aouch!
The symlink is coming from official sources, I can’t do anything about this  :P
I’ve already applied a diff file on a previous release, can’t remember how in details :dunno
Maybe the last diff generation is faulty, I’m not expert on this.
I’ll try to work on it soon.
Substring
« Reply #128 on: June 14, 2019, 01:06:45 pm »
Should I not use the official source to apply your patch ?
When I'm lazy to create a patch, i start from the default source code, init a git repo (git init then git add *), hack/patch the source, then git diff > mypatch.patch and voilà, done.
silmalik
« Reply #129 on: June 17, 2019, 07:13:04 am »
Hi,
Yes, of course, patch is intended to be applied on official sourced.
Thank you for the method to create patch, I didn’t know git diff option, will use it next time  :)
Substring
« Reply #130 on: June 17, 2019, 05:50:27 pm »
Could skip the redudancy problems using -N switch. But your patch tries to patch a file that doesn't exist : .vscode/settings.json
I've attached a "good looking patch", you could give it a try to make sure it does have al the necessary CRT stuff. All done in Linux.
Substring
« Reply #131 on: September 23, 2019, 02:55:58 pm »
3 months later, are we there yet ?
silmalik
« Reply #132 on: September 26, 2019, 05:23:07 am »
Yes, still around.:)
As always not too much time to spend on the fork, waiting for the next stable Mednafen release for an update.
psakhis
« Reply #133 on: September 27, 2019, 11:22:42 am »
Nice!
I use this fork for Sega Saturn with native resolution; a lot of faster than RA plugin.
Thank you very much!
silmalik
Re: emu4crt Mednafen fork - update 1.23.0 UNSTABLE / A09
« Reply #134 on: October 08, 2019, 06:39:43 pm »
Thanks for the feedback.
A new version is online, based on lastest 1.23.0 UNSTABLE Mednafen release.
@Substring: I've followed your recommendation about patch file, there should be some progress  ;)
Substring
« Reply #135 on: October 09, 2019, 03:48:52 am »
Nice, I shall test it :)
alex2005
  • Last login:Today at 07:04:38 am
« Reply #136 on: November 01, 2019, 01:06:23 pm »
Hey Silmalik,
I have not find any documentation in mednafen but maybe do you know how to hide the mouse cursor when starting a game in mednafen? Is this a feature that can somehow be accomplished in your build?
Thanks a lot :)
psakhis
« Reply #137 on: December 25, 2019, 03:09:23 pm »
Hi friends!
New version Mednafen 1.24 with a major improve performance on Saturn.
 :applaud: :applaud: :applaud:
silmalik
« Reply #138 on: December 26, 2019, 04:08:10 pm »
@alex2005,
I've missed to answer, let's hope you figured out how to solve your issue during this time.
Never have such problem with mouse cursor. I will have a look if I can reproduce and if it's bring by the mod.
A log file would be useful to have some information on your configuration ;)
@psakhis
Well… some obscure new parameters have been added to mess with thread affinity, that's interesting indeed.
But that doesn't sound too much easy to use though.
We'll see this shortly with the next mod release :)
« Last Edit: December 26, 2019, 04:18:01 pm by silmalik »
alex2005
« Reply #139 on: December 27, 2019, 05:44:40 am »
@alex2005,
Hi Silmalik! Happy Christmas :)
Unfortunately I still have the cursor issue. When launching a game the cursor shows up and disapears after a few miliseconds.
I have attached a log file, I hope that is good enough.
I just noticed in the log it refers to some snes.cfg and snes.pal files which I do not have. Do you maybe know how to set these up? Or maybe they are not really necessary?
Thanks always for your support and great work!
« Last Edit: December 27, 2019, 09:49:42 am by alex2005 »
totozero
  • Last login:June 07, 2023, 07:36:05 am
« Reply #140 on: December 27, 2019, 09:42:32 am »
Hi mate, please post your mednafen.cfg file, I'll look into it.
Mouse cursor don't show when I run mednafen.
Let's hope it's not related with your hyperspin setup, I won't be of any help, I dumped the damn thing long time ago in favour of attract-mode.
Cheers,
« Last Edit: December 27, 2019, 09:44:28 am by totozero »
alex2005
« Reply #141 on: December 27, 2019, 09:50:23 am »
Cheers,
thanks mate.
CFG file attached in previous post (renamed to .txt)
I hope its not a hyperspin issue (just in case I updated HS to latest 1.5.1 version today, but issue still remains.
Link to video: https://photos.app.goo.gl/vHokPde8rzguqCe89
« Last Edit: December 27, 2019, 09:58:15 am by alex2005 »
totozero
« Reply #142 on: December 27, 2019, 09:55:51 am »
Quote from: silmalik
Hey buddy,
thanks for keeping this up. SNES Faust works without any flaws (at least from my curated list).
May I add two requests for next build ?
- Minor grip : is it possible to compile a version which wouldn't show the cmd window while launching, just for aesthetic matter ? Or at least run it minimized ?
I'd love to transition from my frontend (attract-mode) to a game without showing evidence another proggie has launched (a la groovymame).
- Please consider enabling pce_fast core, I tried it on my main rig with normal mednafen, I felt it was more responsive / snappier than the regular pce core. Would love to test it on my Astro city.
Many thanks and have a festive happy season !
totozero
« Reply #143 on: December 27, 2019, 10:19:56 am »
Quote from: alex2005
thanks mate.
Okay first things first...
You know that judging from your *.cfg file, you're running an outdated version ? Did you even try super resolutions ? If not, you should, they work wonders.
Or maybe you mixed *. exe and *.cfg files from different builds ? If so, you should not as some settings have changed between versions.
I'd start with new fresh mednafen install, a clean mednafen.cfg and see from here if the mouse cursor issue is still there.
It's only a 5 minutes setup with a good text editor (notepad++ for instance) if you know what you're doing.
Cheers,
« Last Edit: December 27, 2019, 10:21:54 am by totozero »
alex2005
« Reply #144 on: December 27, 2019, 02:17:57 pm »
Thanks for the advise.
I'm using super resolutions, I noticed that I do not call mednafen directly from hyperspin but instead "emu4crt" which handles all resolutions. Maybe its not an issue with mednafen itself but with emu4crt.
I could get rid of it, if I just knew how to implement these super resolutions in mednafen.cfg file :)
I'll take a deeper look during the weekend and see if i can figure it out.
totozero
« Reply #145 on: December 27, 2019, 06:55:41 pm »
Hmmm... Not sure I fully understood what you've just written...
Emu4crt IS Mednafen with switchres, you don't have to download anything else aside the archive Silmalik posted to run the binaries.
Run the exe (i.e crt4emu.exe) once and it will create a mednafen.cfg from scratch.
At the end of the cfg file there's a switch :
video.resolution_switch 0
Now if you want to have both vanilla mednafen and emu4crt installed, better put each version to a separate folder as from my experience they don't mix well. It seems you can't have both *.exe together due to *.cfg conflicts.
Vanilla mednafen doesn't support super resolutions.
Cheers.
« Last Edit: December 27, 2019, 07:05:02 pm by totozero »
alex2005
« Reply #146 on: December 28, 2019, 06:18:14 am »
Cheers.
That was it, thanks a lot!
I installed from scratch a new emu4crt directory and with this setting worked.
Seems like you said, having both in the same directory somehow conflicted :)
Sorted it, thanks again! And sorry for a bit of offtopic :)
totozero
« Reply #147 on: December 28, 2019, 10:01:16 am »
Glad you sorted it out  ;)
silmalik
« Reply #148 on: December 28, 2019, 07:06:25 pm »
Hi,
@Glad to learn that your issue is fixed now. Well done Totozero!  :)
About - Minor grip : is it possible to compile a version which wouldn't show the cmd window while launching, just for aesthetic matter ? Or at least run it minimized ?
Sure, that's annoying. This is a consequence of a recent Mednafen update on log management. I tried to "fix" it without success, need to dig further.
Well, I may have a look on it on a later time. No promise though.
silmalik
« Reply #149 on: January 02, 2020, 03:14:44 pm »
The update to Mednafen 1.24.0 UNSTABLE is available!
Not too much time to challenge the new features of the SNES Faust and Saturn cores, feel free to report about it. :)
Thank you.
psakhis
« Reply #150 on: January 02, 2020, 03:27:43 pm »
I hope test Saturn, but how you said... the new options of threads are a little confuse for configuration...
Very Thanks!! @silmalik
silmalik
« Reply #151 on: January 02, 2020, 04:24:57 pm »
Seven possible combinations if I calculate correctly. And potentially, the best combination can be different depending on the game...  Aouch!
psakhis
Re: emu4crt Mednafen fork - update 1.24.0 UNSTABLE / A09
« Reply #152 on: January 14, 2020, 11:15:08 am »
Hi!
I do a regression test, and all it's fine with Pcengine, Saturn and Psx. All new options of Saturn's core on default (0 - not activated).
I'm waiting for more details for these new options, i don't find too much documentation about.
Thx!
silmalik
« Reply #153 on: January 14, 2020, 12:16:10 pm »
Hi,
Well... I guess you have missed a regression on psx horizontal centering. :angel:
That will will be fixed in a next release soon.
fuchi_jeg
  • Last login:January 31, 2026, 02:13:39 pm
« Reply #154 on: January 15, 2020, 10:49:59 am »
I've been using your mod to play a few systems that dont otherwise have an emulator that plays well with CRTs.  It's working great, especially for handheld systems.  The only problem I'm having is mednafen sometimes causes the display to hang in 16 bit color depth. Is there any way to lock mednafen to 32 bit color?
silmalik
« Reply #155 on: January 15, 2020, 01:45:58 pm »
I can't see why mednafen would do such thing.
Please, can you give us some details?  The platform you use, settings and also a log file would be very useful.
fuchi_jeg
« Reply #156 on: January 15, 2020, 02:36:59 pm »
I'm using windows 7 64 and  rocket launcher. I get a notification on the taskbar at launch starting that windows has changed to 16bit color depth.  When the game is closed windows stays in 16 bit mode. Even launching other emulators doesn't being back 32 bit.
psakhis
« Reply #157 on: January 15, 2020, 02:43:25 pm »
Mmmmm...it happens to me too in the past and i did some actions for prevent auto change depth bit color but i don't know if it's suficient....
I remember:
 * Disable aero desktop composition (i only enable it for pcsx2 and vsync purposes)
 * Hide taskbar
 * Disable notifications of depth color changes...
fuchi_jeg
« Reply #158 on: January 15, 2020, 02:55:49 pm »
Thank you! I'll try disabling aero.  Would it have the same effect if I disabled it through the mednafen cfg file? If I totally disable it through windows xebra emulator has terrible screen tearing.
silmalik
« Reply #159 on: January 15, 2020, 03:25:40 pm »
To exclude any Rocketlauncher side effect, do you have same issue when launched from a basic command line ?
Have a look on the stdout.txt file in mednafen folder, we may learn something.
