Author Topic: emu4crt Mednafen mod - update 1.26.1  (Read 216376 times)
terranigma
  • Last login:March 20, 2019, 04:03:17 am
Re: emu4crt Mednafen fork - update 0.9.48 / A07
« Reply #80 on: March 08, 2018, 04:24:38 pm »
Hi silmalik,
Any plan on Mednafen 1.21 ?
Done! :)
I didn't expect such a short time. I just tested on Linux and great work as usual!
Thank you for effort.
Note: Can you distribute your work also as a patch file against latest upstream version? Maybe other Linux packagers interest to import your work.
« Last Edit: March 08, 2018, 04:37:01 pm by terranigma »
silmalik
  • Last login:April 16, 2022, 09:08:13 am
    • Mednafen emu4crt mod
Re: emu4crt Mednafen fork - update 1.21.0 / A08
« Reply #81 on: March 08, 2018, 06:41:54 pm »
Hi terranova,
You are right, patches will be more suitable.
So, a patch folder is born in the repository: https://github.com/emu4crt/files
I have a question about the behaviour on Linux: how are the resolution switches ? is there any delay and/or visual glitches ?
terranigma
« Reply #82 on: March 08, 2018, 07:15:15 pm »
Hi silmalik,
It seems that you have generated the patch by referencing the root folder, thus patch level shifted up by one level according to my test. I mean, "patch -p1" doesn't work inside of the source tree (but -p2 does) . Probably you have to compare them in same folder like:
cd /
diff -Naur mednafen emu4crt > emu4crt.patch
I didn't notice any worrying delay and glitch issues during resolution switches.
Regards.
Initializing sound...
  Using "ALSA" audio driver with device "sexyal-literal-default":
   Format: 16 bits(signed, 2 bytes, little-endian)
   Rate: 48000
   Channels: 2
   Buffer size: 1536 sample frames(32.000000 ms)
   Latency: 1536 sample frames(32.000000 ms)
   Period size: 512 sample frames(10.666667 ms)
    Warning: Period time is too large(it should be <= ~5.333ms).  Video will appear very jerky.
 Initializing video...
### VIDEO Native resolution init - set to 640x480
  Driver: OpenGL
  Display Mode: 640 x 480 x 24 bpp @ 30Hz  (Window: 640 x 480)
  Shader: none
  Fullscreen: Yes
  Special Scaler: None
  Scanlines: Off
  Destination Rectangle: X=0, Y=0, W=640, H=480
  OpenGL Implementation: X.Org R300 Project ATI RV370 2.1 Mesa 17.2.4
  Checking extensions:
   GL_ARB_texture_non_power_of_two found.
   GL_ARB_sync found.
  Using non-power-of-2 sized textures.
  Checking maximum texture size...
   Apparently it is at least: 2048 x 2048
  Using GL_BGRA, GL_UNSIGNED_INT_8_8_8_8_REV for texture source data.
PSX GPU - Startup resolution change bypass (1).
PSX GPU - Startup resolution change bypass (2).
PSX - GPU register - resolution change to: 640x480 (V=39)
  Driver: OpenGL
  Shader: none
  Fullscreen: Yes
  Scanlines: Off
   GL_ARB_sync found.
MAIN - native resolution switched
PSX - GPU register - resolution change to: 320x240 (V=17)
### VIDEO Native resolution init - set to 320x240
  Driver: OpenGL
  Display Mode: 320 x 240 x 24 bpp @ 50Hz  (Window: 320 x 240)
  Shader: none
  Fullscreen: Yes
  Scanlines: Off
  Destination Rectangle: X=0, Y=0, W=320, H=240
   GL_ARB_sync found.
PSX - GPU register - resolution change to: 368x240 (V=64)
### VIDEO Native resolution init - set to 368x240
  Driver: OpenGL
  Display Mode: 384 x 240 x 24 bpp @ 50Hz  (Window: 384 x 240)
  Shader: none
  Fullscreen: Yes
  Scanlines: Off
  Destination Rectangle: X=8, Y=0, W=368, H=240
   GL_ARB_sync found.
  Driver: OpenGL
  Shader: none
  Fullscreen: Yes
  Scanlines: Off
   GL_ARB_sync found.
« Last Edit: March 08, 2018, 07:30:54 pm by terranigma »
purity1516
  • Last login:May 28, 2019, 04:32:32 pm
« Reply #83 on: March 09, 2018, 09:15:30 am »
Hi silmalik,
First of all, congratulations for your great job!
When launching PSX games, I get an superx640i resolution. Is that right or should be 240p? The SS games runs gracefully at superx240p...
Regards
buttersoft
  • Last login:Today at 05:59:43 am
  • Is running at 15kHz
« Reply #84 on: March 10, 2018, 05:41:16 am »
The [hide modes this monitor cannot display] setting can still be found in Windows 10: Display settings / Display adapter properties.
Yes it can! Thank you again, saved ---my bottom--- when i had to reinstall crt_emudriver and the problem recurred even when the AMD external events service was disabled :)
silmalik
« Reply #85 on: March 10, 2018, 09:16:24 am »
Hi silmalik,
cd /
Regards.
Ok, I'll try your suggestion in next release. Thank you.
Hi silmalik,
Hi,
PSX boot logo is displayed in an interlaced mode and the Saturn one is displayed in progressive mode, yes this is expected.
After boot logos, most PSX games switch to progressive display mode, emu4crt should then apply the appropriate mode.
If you suspect a misfunction, please specify game reference and stdout.txt file, I'll have a look at it. ;)
You're welcome :)
purity1516
« Reply #86 on: March 12, 2018, 06:47:38 am »
Hi silmalik,
Hi,
Hi,
You're right! Thanks a lot!
Fishface
  • Last login:April 02, 2018, 05:32:22 pm
« Reply #87 on: March 31, 2018, 10:47:55 am »
Totally digging this. Great job! Any plans on adding support for more modules? I'd love to see Master System in particular  :)
silmalik
« Reply #88 on: April 02, 2018, 05:41:17 pm »
Hi,
Thank you for your interest.
There are other priorities to add to emu4crt: remove the console that produces glitches during resolution switch, frequecy management for example, etc.
And I miss some time these days to work on it.
Moreover, there are strong alternatives: Groovymame of course, Fusion and the recent retroArch build that support native resolution. ;)
purity1516
« Reply #89 on: April 24, 2018, 04:37:05 pm »
Hi silmalik,
I got the following message when I try to run a game (SS or PSX):
"set rate is out of range [22050-19200]"
I'm using super resolution.
What could it be?
silmalik
« Reply #90 on: April 25, 2018, 12:32:28 pm »
Hi Purity1516,
Well, no idea, might be sound related. More information is required.
Please attach the "stdout.txt" log file.
Have you tried the mednafen official build ?
purity1516
« Reply #91 on: April 25, 2018, 04:11:21 pm »
Hi Purity1516,
It's working now! The <video.fs> setting was set to 0 and I changed to 1.
That was not so clear, because even set to 0, the emulator was running in a "fake" fullscreen mode with an oversized image.
Thanks a lot!
silmalik
« Reply #92 on: April 27, 2018, 02:49:34 am »
Well done! :)
Thanks for the feedback.
ArcadeAction
  • Last login:March 03, 2019, 04:35:29 pm
  • I have built my own arcade controls!
    • ArcadeMade.com
« Reply #93 on: May 16, 2018, 06:13:00 pm »
First thanks for making this.
I'm having trouble with resolutions and configuring the value for video.resolution_switch.
When running SuperNES, the displayed resolution is either just a small box in a window (native), super wide-off the screen and stretched (super) or seemingly zoomed in at 2x like I'm sitting in the front row at a movie (0). I am unable to change it to a setting of "1" as it gives me a message that "1" is not a valid option.
I'm running Win764, CRT EmuDriver and an ATI HD 5000 series card.
Thanks for your thoughts
silmalik
« Reply #94 on: May 18, 2018, 07:53:19 pm »
Hi ArcadeAction,
For lastest version, I confirm that only valid values for video.resolution_switch are 0, native and super.
Your description indicates that things are working well in window mode.
To get into fullscreen mode, pressing Alt+Enter should do the job... once you configured correct video modes in CRT Emudriver.
If need to go furher, please attach your mednafen.cfg and stdout.txt files.  ;)
Jack
  • Last login:March 07, 2025, 06:28:36 pm
  • See You Space Cowboy..
« Reply #95 on: October 01, 2018, 05:32:38 pm »
Is it possible to use a lightgun like the dolphin bar with this emulator? Thanks.
silmalik
« Reply #96 on: October 02, 2018, 01:36:31 pm »
Hi,
Never tested.
It may work as long as this bar can emulate a mouse, but only experiences could confirm.
Feel free to share if you decide to try, I'm interested. :)
bluetrain
  • Last login:October 22, 2019, 03:21:04 am
« Reply #97 on: October 23, 2018, 05:38:07 am »
I can´t get the proper resolution for snes, tried both native and super resolution (in cfg and of course in vmmaker) but in full screen the pixels take up like 1/3 of the screen. If I do alt+enter the screen goes bananas. It seems to be pixel perfect picture but in like second or so I get jitter/tearing and it doesn´t stop if close the program so I have to restart windows.
silmalik
« Reply #98 on: October 23, 2018, 04:59:56 pm »
Hi,
Please, attach "stdout.txt" log file to allow investigations.
In the meantime, some questions:
 - does it work for other systems like PSX or PC engine ?
 - did you apply this ?:
  1 - Stop and Disable service: AMD External events utility
  2 - Ensure that the Windows advanced display option is enable: "hide modes that is monitor cannot display"
bluetrain
« Reply #99 on: October 24, 2018, 05:55:22 am »
Hi Silmalik,
I think I found a way around. :) In VM-maker I had all the super resolutions (included 50hz for pal) included and it works really great with GM so I figured it should work both with PAL and NTSC. So what i did was, remove all the PAL resolutions in VM-maker and only use NTSC roms in mednafen. Then it works flawlessly and I really don´t care about PAL anyway so it´s not a problem. Kudos for your (and Calamitys too) great work with the fork. I´m just blown away by the picture quality that I get on my sony trinitron 25", it´s kind of sick, really :)
On a side note. Is it possible to add Sega Genesis?
silmalik
« Reply #100 on: October 24, 2018, 02:54:05 pm »
Not sure about what happened, only logs would tell, but I'm glad that you've fixed your issue. :)
Unfortunatly, Genesis emulation is not so great in Mednafen, it uses an old external core with limitations.
From official web site: "Sega Genesis/Megadrive emulation should still be considered experimental; there are still likely timing bugs in the 68K emulation code, the YM2612 emulation code is not particularly accurate, and the VDP code has timing-related issues.  Sega 32X and Sega CD are not currently supported [...]"
So, I don't feel great motivation to investe time on this.  :-\
bluetrain
« Reply #101 on: October 25, 2018, 04:11:49 am »
Gotcha! Is that a common problem with emulating the genesis or has it specifically to do with mednafen? May I ask if you have any rec on another genesis emulator for 240p?
lolo40
  • Last login:September 22, 2021, 06:38:50 pm
« Reply #102 on: October 25, 2018, 10:04:52 am »
Kega Fusion, old but very good.
You have to modified the Fusion.ini file to activate the expert mode.
silmalik
« Reply #103 on: October 25, 2018, 05:38:12 pm »
I'm using Fusion too :)
jillstars
  • Last login:December 01, 2018, 04:23:35 am
« Reply #104 on: November 24, 2018, 04:49:00 am »
Two games appear to be having problems in resolution.
Blood Roar 2 during the game. Unstable resolution.
Digimon World 2003 at the opening. Flashing, shaking.
Anyway do not give up on this work of yours. Far better than Retroarch which is a bag of bugs and incompatibilities.
(Google translate. =/)
silmalik
« Reply #105 on: November 26, 2018, 02:48:33 pm »
Hi jillstars,
Please, attach "stdout.txt" log file, it will help for analyse and to reproduce the issue.
I'm currently working on other project but there will be an emu4crt update in some time.  ;)
jillstars
« Reply #106 on: November 27, 2018, 04:12:18 pm »
Hi jillstars,
Config:
i5 3330 3,0 @ 3,2 ghz
8 GB DDR3
HD4670 DDR2
Software
Windows 7 64x
Medgui reborn mod for Emu4crt
crt_emudriver_&_tools_2.0_beta_13_12.6_W.7.8.10-64
super resolutions
silmalik
« Reply #107 on: November 27, 2018, 07:20:33 pm »
Perfect, thanks for the update.
No issues revealed in the log files. ??? I will need to look further.
silmalik
« Reply #108 on: November 28, 2018, 05:59:07 pm »
Hi jillstars,
Both games are ok on my setup.
Bloody Roar 2 runs in 480i (interlace mode) and Radeon HD4000 can have issues with such modes: stuttering, etc...
Can you confirm that other 480i games run correctly ? Tekken 3 for example.
For Digimon World 2003, as you are using PAL version, please check with arcade OSD that your PAL video modelines are OK (2560x288 & 2560x576).
jillstars
« Reply #109 on: December 01, 2018, 04:22:39 am »
Hi jillstars,
Thank you.
I did some testing using only the original emulator and it looks like the problem really is performance.
Somehow these two games do not perform well here. Picture shakes. Digimon World 2003 only has issue with the opening video.
Thanks for the help.
NYI
  • Last login:January 13, 2020, 11:01:09 pm
« Reply #110 on: December 31, 2018, 04:24:22 pm »
Just wanted to thank you for this. Having two really solid emulators in Groovymame and your fork of Mednafen with super resolution support makes things very simple. Your work is very much appreciated!
totozero
  • Last login:June 07, 2023, 07:36:05 am
« Reply #111 on: January 06, 2019, 09:15:25 am »
Hi Silmalik,
I’ve been testing your fork on my cab and so far it’s working great !
Thanks for the hard work you’ve put into it  :applaud:
On the other hand do you know by any chance if the snes Faust module can be activated on your build ? Haven’t look into it yet but the lag reduce thingy it comes with sounds like something worth checking.
Cheers.
totozero
« Reply #112 on: January 06, 2019, 04:32:50 pm »
Ok I’ve tried to run the faust snes module but it seems you didn’t add it to your fork.
Any chance you might add it, please pretty please ?
Cheers.
silmalik
« Reply #113 on: January 09, 2019, 05:17:01 pm »
Hi,
Thank you for the positive feedbacks.  :)
Ok, I'll have a look to faust integration for next release. No promise though.
totozero
« Reply #114 on: January 10, 2019, 05:21:42 am »
Much appreciated.
Thanks mate !
totozero
« Reply #115 on: January 14, 2019, 04:11:01 am »
Hi Silmalik, I've been testing the pcengine modules, the pce module is fine, though I got some slowdowns playing some pce-cd like lords of thunder.
But I can't get pce_fast module to work, meaning I hear sounds but there's no image.
Does it work on your hand with your fork ?
"Official" Mednafen definitely does, I tested it on my main rig.
Cheers.
silmalik
« Reply #116 on: January 14, 2019, 05:04:27 pm »
Hi Totozero,
Well, the pce_fast core is not included in the mod... getting some sounds is a pretty good surprise. :)
I'm not sure that there is a big interest to include it, because, as far as I know, all PCE games runs at a 240p video mode.
So, using official Mednafen at a super-resolution (2560x240) should produce same results.
About your slowdows... did you try the "cd.image_memcache" option to optimize CD emulated access   ?
https://mednafen.github.io/documentation/mednafen.html#cd.image_memcache
purity1516
« Reply #117 on: February 19, 2019, 02:48:21 pm »
Hi silmalik
Any plans to upgrade emu4crt to the keep it in line with the latest mednafen ?
Thanks for your great job on this port!
silmalik
« Reply #118 on: February 19, 2019, 05:13:09 pm »
Hi,
I've just setup a compilation environment yesterday, I will start working on it soon.
I got a new job that doesn't offer me too much time for this, but it's still on plan.
Don't expect a new release before some weeks, I'm afraid.
purity1516
« Reply #119 on: February 19, 2019, 07:03:25 pm »
Hi,
What a coincidence! Take your time, man.
Congrats for your new job!
