Author Topic: GroovyMAME/ARCADE32/64 custom build  (Read 311694 times)
fdv
  • Last login:October 11, 2019, 03:28:47 pm
Re: GroovyMAME/ARCADE32/64 custom build
« Reply #200 on: October 06, 2019, 08:28:11 am »
Maybe it is a matter of compiling with static libraries instead of compiling with dynamic libraries.
mdd45
  • Last login:July 22, 2025, 06:03:10 pm
« Reply #201 on: October 06, 2019, 09:03:53 am »
In that case let's hope haynor666 take this into consideration in order for us to be able to enjoy 0.214 too. 0.211 is working fine fire me too but not 0.213...
Dogway
  • Last login:October 08, 2019, 04:15:59 pm
« Reply #202 on: October 07, 2019, 11:30:02 am »
Does this include an option to save autofire cheat settings?
schmerzkaufen
« Reply #203 on: October 07, 2019, 11:39:30 am »
No, but MAME comes with an autofire LUA plugin now, so both standard Groovy and ARCADE variant have it too.
In mame.ini at 'plugin' just write 'autofire'.
Dogway
« Reply #204 on: October 07, 2019, 03:02:12 pm »
The plugin even with your recommendation doesn't work for me for the joystick (tested dinput and xinput) only the keyboard (hotkey setting), if it worked I could autogenerate autofire .cfg files for all shmups.
The autofire cheat instead does work, but I have to enable it each time (doesn't save)
schmerzkaufen
« Reply #205 on: October 07, 2019, 03:33:03 pm »
The LUA autofire plugin does work. I have no emus installed on that computer here to take a look so maybe I forgot what the right setting are but it is a thing (was added to MAME like a few builds ag, I've used it)
EDIT: maybe they've changed how to use it, dunno, i'll have a look tomorrow. It's very new so they've made changes to it like every build since its introduction.
EDIT2: yeah it works as I described. Maybe you meant you couldn't figure how to make it work? me neither the first time, it's pretty confusing, and of course there's no documentation on it.
To begin I think (to be confirmed tho) that the AF-enabled button (hotkey) can't be same as the default one, this is to allow having both the normal and its AF-enabled duplicate on the same controller if desired. So it's up to you to arrange your inputs for that, but you can assign a button away like on the keyboard if you don't want to keep both on the same controller.
Then the frame press/release arrangement is pretty self-explanatory.
Settings are saved in .cfg's
« Last Edit: October 08, 2019, 08:47:34 am by schmerzkaufen »
antoniomauro
  • Last login:March 10, 2026, 05:57:43 am
« Reply #206 on: October 08, 2019, 11:09:02 am »
Is the compiled 32bit version planned?
Dogway
« Reply #207 on: October 08, 2019, 04:16:00 pm »
@haynor666: thanks for the update!
@schmerzkaufen: finally I made it work, hotkey... well button I'd say. I mapped it to a strange RT and it worked, so I cannot map button_1 or button_2 to autofire... or I might, but then I have to mess with my ctrlr file to repurpose button_1 and button_2 somewhere else in my controller and make room for autofire... I will think something up with a script, gotta be creative.
haynor666
  • retro maniac
« Reply #208 on: October 10, 2019, 03:55:11 am »
Both editions are online, I forgot to mention ;)
mdd45
« Reply #209 on: October 10, 2019, 03:55:45 am »
This is what I'm looking for too!
mdd45
« Reply #210 on: October 10, 2019, 03:59:41 am »
Nice thank you!!!! Do you think that the missing dwmapi.dll error some of us getting on 212 a d 213 32bit is going to be fixed on the 214?
« Last Edit: October 10, 2019, 04:01:38 am by mdd45 »
haynor666
  • retro maniac
« Reply #211 on: October 10, 2019, 04:34:05 am »
I didn't tested 32 build in 32bit env. or XP. I'm affraid error might pop up also here. Mamedev abandoned XP long time ago and I'm abandoning 32 build at the end of year.
mdd45
« Reply #212 on: October 10, 2019, 04:35:43 am »
214 32bit file is not on mega folder...
haynor666
  • retro maniac
« Reply #213 on: October 10, 2019, 11:37:44 am »
It is now. Thanks for spotting this ;)
fdv
« Reply #214 on: October 11, 2019, 03:28:47 pm »
The missing dwmapi.dll error still happens in 214  :'( Could you, please, provide a fix?
haynor666
  • retro maniac
« Reply #215 on: October 11, 2019, 03:41:55 pm »
I'm sorry but I don't know how :(
mdd45
« Reply #216 on: October 12, 2019, 12:58:17 pm »
if someone finds a workaround for winxp 32bit and dwmapi.dll error, please post it here, even though i don't think that this is going to be fixed. Even the unpatched official mame 0.214 build doesn't boot, giving another error on winxp 32
haynor666
  • retro maniac
« Reply #217 on: October 27, 2019, 10:37:55 am »
IMPORTANT NEWS
Two months before I was planning but...
Version 215 will be (probably) last version built for x86 systems. It was always built for XP in mind but mamedev now abandons x86 builds and also abandons 5.3 tools as well (which I use for XP/x86 build due compability reasons).
Robbbert
  • Last login:March 03, 2026, 11:30:09 pm
« Reply #218 on: October 27, 2019, 11:33:46 am »
Yes 0.215 will be the last for XP. I tried building the latest git (will be in 0.216) with 5.3 and it does not compile. So, the end.
haynor666
  • retro maniac
« Reply #219 on: October 28, 2019, 03:36:05 am »
Personally not a big problem. I don't use x86 systems from long time not too mention XP. I think most people knew what will happen soon.
Substring
  • Last login:March 19, 2026, 06:10:08 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #220 on: October 28, 2019, 08:28:53 am »
Original mame dev team statement for curious people : https://www.mamedev.org/?p=474
in 2019, maintaining 32bits software is a paradox ... (yeah, same would go for CRT display  ;D)
donluca
  • Last login:March 08, 2026, 04:59:21 am
« Reply #221 on: October 28, 2019, 02:01:09 pm »
What about XP's kernel evolutions, namely 64-bit XP and the successive (and last iteration) Windows Server 2003 (which comes in both 32 and 64 bits).
I've been using a super stripped down 2003 installation, 64-bits with huge satisfaction. It's basically the last evolution of Windows XP, but with better hardware support and 64-bits. When you remove everything from it, it's basically an improved Windows XP.
EDIT: before I get flooded with messages like in the past, just google it, it is part of a suite named Windows XP 2003 eXPerience Edition October 2011.
« Last Edit: October 28, 2019, 02:06:14 pm by donluca »
2.- Inflatable dolls
haynor666
  • retro maniac
« Reply #222 on: October 28, 2019, 02:59:30 pm »
CRT is a different thing - we need this CRTs to get picture close to real hardware. groovymame is designed to run on CRTs and we have still options to do this.
On the other hand 32 bit systems are limiting usage of modern hardware and probably limiting mame as well. As for XP itself - I would like to keep compatibility but mamedev abandoned XP long time ago and with recent tools will not be possible to build XP compatible exe. XPx64 it's abandoned long time ago. It was very niche system anyway.
It's time to move on people to at least 7x64.
donluca
« Reply #223 on: October 29, 2019, 01:41:03 pm »
That's really a pity.
My setup was almost instant-on, with w7 even with an SSD I won't get the same boot times (and I'll have to put some more RAM in it, sadly).
anchounio
  • Last login:February 17, 2026, 07:31:39 am
« Reply #224 on: November 02, 2019, 09:45:57 am »
Looking forward to 0.215  :notworthy:
shiryu55
  • Last login:April 18, 2023, 03:46:44 am
« Reply #225 on: November 08, 2019, 08:29:43 am »
xp 32bit ,dwmapi.dll is not found. solution was found ?, or in the next and last version 215 will be solved.
haynor666
  • retro maniac
« Reply #226 on: November 09, 2019, 07:23:22 am »
I'm sorry but I don't have solution for this.
Version 215 is out.
donluca
« Reply #227 on: November 09, 2019, 07:55:32 am »
It looks like it's looking for the Destktop Windows Manager extension which is present only from Vista onwards.
Although there's another user here who said that it worked fine on his end (I think it's in the main discussion thread).
  • Last login:March 15, 2026, 04:39:26 pm
« Reply #228 on: November 09, 2019, 01:24:21 pm »
I think this is caused by the change we introduced in Switchres v0.017o to reduce latency in bgfx. Or does this problem also happen with baseline MAME and XP?
donluca
« Reply #229 on: November 09, 2019, 03:22:00 pm »
No clue unfortunately but one of those days I wanted to bring up a couple virtual machines and do some testing to try understand what's going on.
I've always felt that a stripped down windows 2003 64 bit installation is the best possible OS for GroovyMAME.
keilmillerjr
  • Web Developer.
« Reply #230 on: November 29, 2019, 12:22:00 pm »
mame0216 is an awesome release. Can’t wait for the patch update so I can start compiling and testing!
haynor666
  • retro maniac
« Reply #231 on: December 01, 2019, 05:05:26 am »
Version 216 is out.
mdd45
« Reply #232 on: December 03, 2019, 01:35:14 pm »
according to this: http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=384077&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
is this possible for anyone to build at least a .215 for WinXP 32 using using GCC 5.3  (gcc7.2  according to user pmc3 or whatever it needs to run on xp), in order to have at least the latest (maybe) possible groovymame for our dinosaur pc?
EDIT: the 0216 builds on emu-france.com works great on my win32 XP! thank you pmc3 !
« Last Edit: December 04, 2019, 04:45:30 pm by mdd45 »
keilmillerjr
  • Web Developer.
« Reply #233 on: December 12, 2019, 05:30:16 am »
Thank you for the patch update! Added the following 64-bit bins to https://gitlab.com/arcademvs/mame/
mame0216_64bit_linux_gs
mame0216_64bit_linux_gsv
mame0216_64bit_mac_sv
haynor666
  • retro maniac
« Reply #234 on: December 15, 2019, 09:15:34 am »
I am glad that my mame derrative is usefull on other systems. Thanks for those builds :)
haynor666
  • retro maniac
« Reply #235 on: December 27, 2019, 09:32:03 am »
Version 217 is out.
From this version I'm using MinGW 9.2.0 (mame latest compiling tools). x64 binary will be available in next hour.
Because latest groovymame patch is created differently (git?) than previous I uploaded also modified sources.
keilmillerjr
  • Web Developer.
« Reply #236 on: December 27, 2019, 08:17:41 pm »
Version 217 is out.
Patch for groovymame is still available. Still retaining patches allows you to choose what you need.
haynor666
  • retro maniac
« Reply #237 on: December 28, 2019, 05:17:42 am »
Of course it is. I had problems with applaying it to my source using patch.exe from MinGW so I modified it a bit.
Problem was with entries like
diff --git a/scripts/src/emu.lua b/scripts/src/emu.lua
index 1561bb1b69..c311baa932 100644
--- a/scripts/src/emu.lua
+++ b/scripts/src/emu.lua
which was like this
diff --Nru scripts/src/emu.lua b/scripts/src/emu.lua
--- scripts/src/emu.lua
+++ scripts/src/emu.lua
Calamity actually mentioned what should be done to bypass this but I didn't spot this on time.
Anyway there was error in my source so I've uploaded new one. Binary is fine.
UPDATE
I forgot to mentioned another taito_f2 fix for pbobble4 for missing graphics. Patch was derrived from ARCADE64/created by dink.
« Last Edit: December 28, 2019, 05:58:09 am by haynor666 »
keilmillerjr
  • Web Developer.
« Reply #238 on: December 28, 2019, 10:38:16 am »
That is an extended header. I believe the unix patch utility will ignore it. I dont think the windows patch.exe is good utility. We can always strip it manually. Any chance of still releasing patches?
haynor666
  • retro maniac
« Reply #239 on: December 28, 2019, 11:16:26 am »
My patches are fine. Last fix for version 217 should be ok. It work with windows patch.exe. Groovymame mame and d3d9ex patches are also working with patch.exe just fine with command -p1.
Because putting modified groovymame main patch as well d3d9ex patch would be confusing I once again re-uploaded 217 patches archive. This time only various fixes are in archive.
Fix for old video cards is abandoned as well x32 builds.
« Last Edit: December 28, 2019, 11:19:11 am by haynor666 »
