Author Topic: GroovyMAME/ARCADE32/64 custom build  (Read 295586 times)
haynor666
  • retro maniac
Re: GroovyMAME/ARCADE32
« Reply #40 on: November 04, 2017, 10:47:11 am »
All those fixes are either hacks so won't be in official mame or changes were not accepted by mamedev (like Iron Horse fix).
Some of those are really not correct (like Neo Geo resolutions changes) - only to improve display/sound not matter if real hardware had or had not such issues/behaviour.
Some changes are just guess or some logical assumptions but not verified.
michino
  • Last login:March 08, 2018, 10:13:01 am
« Reply #41 on: November 04, 2017, 03:37:11 pm »
All other files (plugins, artwork) You should get from official mame 191 archive.
Thanks a lot.
Any change to do in the mame.ini from 0.189 version?
haynor666
  • retro maniac
« Reply #42 on: November 05, 2017, 06:34:44 am »
Probably not.
AstroFan
  • Last login:December 28, 2025, 05:01:49 pm
« Reply #43 on: November 08, 2017, 03:26:30 pm »
Can you build a 32bit version without the "Your graphics card does not support non-power-of-two textures" error?
It was discussed here: http://forum.arcadecontrols.com/index.php/topic,155585.0.html
haynor666
  • retro maniac
« Reply #44 on: November 10, 2017, 07:28:27 am »
Done, please use link in first post and let me know if this works.
AstroFan
« Reply #45 on: November 11, 2017, 07:42:15 am »
Works perfectly, Cave performance has improved 2x! Thanks!
haynor666
  • retro maniac
« Reply #46 on: November 13, 2017, 02:22:35 pm »
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #47 on: November 14, 2017, 02:19:41 pm »
Temporary build using git from yesterday: https://mega.nz/#!hkkViLBR!1Z5op_JbX_gpgrdJJDoC40bgysjjQ6WDnjjMuL79DZ8
quick tested tonight, brilliant. Many thanks for the preview !
michino
« Reply #48 on: November 14, 2017, 04:50:42 pm »
AstroFan
« Reply #49 on: November 16, 2017, 07:39:33 am »
The git version has the "non-power-of-two textures" error again  :'(
haynor666
  • retro maniac
« Reply #50 on: November 16, 2017, 07:43:37 am »
Ups, I forgot to apply this patch. I'll compile latest GIT with this patch as well.
BTW. You could try PGM2 emulation after I made new test build ;)
haynor666
  • retro maniac
« Reply #51 on: November 16, 2017, 04:39:52 pm »
New version from today - [removed]
« Last Edit: December 05, 2017, 04:18:42 pm by haynor666 »
haynor666
  • retro maniac
« Reply #52 on: December 05, 2017, 04:19:39 pm »
Version 192 is out. Added solution for bypassing message "non-power-of-two textures".
lettuce
  • Make It So!
« Reply #53 on: December 16, 2017, 11:58:39 am »
Thank you!
funkycochise
  • 8 bits generation
« Reply #54 on: December 16, 2017, 09:15:24 pm »
Thank you haynor.
antoniomauro
  • Last login:January 14, 2026, 11:05:26 am
« Reply #55 on: January 09, 2018, 03:14:35 am »
Are 0.192 diff compatible with 0.193 source?
haynor666
  • retro maniac
« Reply #56 on: January 09, 2018, 07:26:35 am »
I have 193 diff created but I didn't build 193 so far. I don't have enough time fpr my hobby right now.
Josef1975
  • Last login:July 09, 2021, 06:01:15 am
    • MY ARCADE CABINET
« Reply #57 on: January 27, 2018, 10:41:39 am »
Hi, any news about .193 release?
In any case really thanks for your Great work!
haynor666
  • retro maniac
« Reply #58 on: January 28, 2018, 02:03:58 pm »
It's too late to publish 193 so wait for 194 :)
Josef1975
    • MY ARCADE CABINET
« Reply #59 on: January 28, 2018, 03:48:57 pm »
ok thanks!!!  ;D
haynor666
  • retro maniac
« Reply #60 on: February 03, 2018, 10:34:30 am »
Version 194 is out. Temporary only 64bit build and without neo-geo resolutions changes.
funkycochise
  • 8 bits generation
« Reply #61 on: February 03, 2018, 11:55:16 am »
alex2005
  • Last login:January 26, 2026, 10:26:30 am
yRe: GroovyMAME/ARCADE32
« Reply #62 on: February 03, 2018, 03:06:20 pm »
whats behind these neo geo resolutions changes? is this an issue?
haynor666
  • retro maniac
« Reply #63 on: February 03, 2018, 04:14:58 pm »
Solved. I simply miss some declarations in include neogeo.h  ;D
Compilation errors in 32 bit env - sorry, no build this time.
https://github.com/mamedev/mame/issues/2936
- SOLVED by compiling with older compiler.
« Last Edit: February 10, 2018, 05:22:14 am by haynor666 »
alex2005
« Reply #64 on: February 04, 2018, 04:27:13 am »
thank you so much!!! awesome build!!
Josef1975
    • MY ARCADE CABINET
« Reply #65 on: February 05, 2018, 03:20:14 pm »
fantastic! thank you
will test in my ladercab soon!  :notworthy:
haynor666
  • retro maniac
« Reply #66 on: February 06, 2018, 11:38:13 am »
Test build:
Cut visible areas in following games, removing black borders:
Double Dragon, Double Dragon II, Thunder Strike
Super Cross II
Mad Crush, Gladiator 1984
China Gate
Wonder Boy 3, Riot City, Aurail
Wonder Boy
Xain'n'Sleena
Battle Rangers
Express Raider
Rock'n'Rage
Exzisus
Gang Busters
Garyo Retsuden
Liberation
Cosmo Gang the Puzzle, Tinkle'n'Pit now whole driver needs this
Nova 2001
Jungle King, Sea Fighter Poseidon
Teenage Mutant Hero Turtles, Bells'n'Whistles
various games in system1 driver
https://mega.nz/#!ZpFyETwI!upZvi6b4k8OKedvy1S-REH_jcfKD6nTQl94GjG5mvBo
« Last Edit: February 09, 2018, 11:41:40 am by haynor666 »
funkycochise
  • 8 bits generation
« Reply #67 on: February 07, 2018, 02:15:30 pm »
you have removed your test build,
I was curious about it  :-[
haynor666
  • retro maniac
« Reply #68 on: February 07, 2018, 04:53:29 pm »
I'm buidling it again with additional changes, just give me 30 mins.
funkycochise
  • 8 bits generation
« Reply #69 on: February 07, 2018, 07:30:35 pm »
thank you, I was just feared that you changed your mind.
there is no hurry  :applaud:
I’ll test it tomorrow
funkycochise
  • 8 bits generation
« Reply #70 on: February 11, 2018, 10:19:47 am »
tested quicky with ddragon, wboy, wb3, exprraid
works really nicely. Thank you for this work
adopted !
keilmillerjr
  • Web Developer.
« Reply #71 on: February 26, 2018, 12:39:43 pm »
Thank you for this build. I cant wait to try it with the neo geo resolution mod!
alex2005
« Reply #72 on: March 09, 2018, 06:09:01 am »
is there any 0.195 nonag release somewhere yet? :)
keilmillerjr
  • Web Developer.
« Reply #73 on: March 18, 2018, 06:36:08 am »
+1 :)
haynor666
  • retro maniac
« Reply #74 on: March 20, 2018, 03:27:19 pm »
I don't have time right now. Since mame have now proper c-chip emulation probably next version will 196 or 197.
haynor666
  • retro maniac
« Reply #75 on: March 31, 2018, 04:37:13 pm »
Version 196 out. For now without Iron Horse modification.
« Last Edit: March 31, 2018, 06:16:27 pm by haynor666 »
funkycochise
  • 8 bits generation
« Reply #76 on: April 01, 2018, 03:05:19 am »
as always, thank you !
Thanks for your effort in maintaining this build.
haynor666
  • retro maniac
« Reply #77 on: April 01, 2018, 12:41:28 pm »
UPDATE: Iron Horse modification is fixed, builds will be updated shortly.
haynor666
  • retro maniac
« Reply #78 on: April 02, 2018, 10:55:37 am »
I forgot to mention that version 200 will be probably last one with support for 32 build. Right now saturn.cpp cannot be compiled with latest compiler. Older compiler works but in some time it will be probably abandoned so it's matter of time unless someone fix saturn.cpp.
Of course there is still source provided so everybody can do it by yourself.
alex2005
« Reply #79 on: April 12, 2018, 04:05:04 pm »
thank you so much! !
best compilation ever! !
