Author Topic: Where to find smaller arcade buttons?  (Read 2698 times)
gedman
  • Last login:November 26, 2021, 01:25:30 pm
  • My first cab is almost done. Loving the challenge.
« on: June 28, 2017, 07:45:33 pm »
I need to fit a service button underneath the overhang of my CP.  I only have 1" of space available, so I can't fit a standard button.  Where can I find a smaller button that can work with a 3/4" thick plywood CP?
Gedman
  • Online Online
  • Last login:Today at 01:24:02 pm
Re: Where to find smaller arcade buttons?
« Reply #1 on: June 28, 2017, 08:29:04 pm »
The 3/4" thick part makes finding a suitable small button very difficult.
Can you slim it down to about 0.4" for these threaded buttons?
  Sanwa OBSN-24 -- 24mm convex, threaded, 27mm bezel
  Seimitsu PS-14-DN -- 24mm convex, threaded, 26mm bezel
Or perhaps dremel out pockets for locking tabs?
  Sanwa SDM-20 -- 20mm concave, locking tabs, 23mm bezel
  Sanwa SDM-18 -- 18mm concave, locking tabs, 20mm bezel
Look for them on Paradise Arcade Shop and/or Focus Attack.
EDIT: Wait, I may have misunderstood.
Do you only have 1" wide (see suggestions above) or 1" behind the panel? (see Ultimarc Goldleafs or Seimitsu PS-14-GN-C or Sanwa OBSN threaded buttons )
A Happ/IL button and a Goldleaf installed on 3/4 MDF.
« Last Edit: June 28, 2017, 08:45:39 pm by PL1 »
gedman
« Reply #2 on: June 28, 2017, 09:12:10 pm »
I have 1" wide.  The space behind the CP is several inches.
I could use a forstner bit to remove some wood from behind the CP to make the theeaded buttons work if there is no better option.
  • Online Online
« Reply #3 on: June 28, 2017, 10:31:59 pm »
None that I know of.   :dunno
Forstner bit FTW.
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
« Reply #4 on: June 28, 2017, 10:59:28 pm »
Yeah, I had the same situation.  I drilled out a larger hole to set it into.   :(
« Reply #5 on: June 29, 2017, 12:44:23 pm »
I've used 24mm snap in OBSF 24 buttons in thicker wood and they have worked just fine.  They are a snug fit and generally don't pop out easily.  Just use a 24mm forstner bit to carefully drill a hole in the wood.  If you want you can even use hot glue to keep them in.  But I've never had the need to do that.
https://www.focusattack.com/sanwa-obsf-24mm-pushbutton-white/
DeL
