Author Topic: XBOXPadMicro - A firmware that turns Arduino Micro (Leonardo) into an XBOX pad!  (Read 87906 times)
bootsector
  • Last login:December 29, 2018, 12:48:52 am
I was chatting with sharpfork about the lack of MinimusAVR cheap alternatives and he mentioned that people started to make pad-hacks again thanks to the AVR shortage.
I've then created a firmware for cheapo Arduino Mini clones like this one: http://www.ebay.com/itm/401051886672
Beta testers are welcome!  ;D
Instructions can be found at: https://drive.google.com/open?id=1wF3S697crrigmpRB93IHXBsS6oylC_RSxvSNOloRzB4
Cheers
bootsector
« Last Edit: December 20, 2016, 07:05:49 am by bootsector »
plazma
  • Last login:April 11, 2021, 11:37:54 am
Nice. I bought cheap S controller clones for rewiring.
baritonomarchetto
  • Last login:Today at 07:09:37 am
Does the library manage the rumble motors?
bootsector
So this is for use with the original xbox?
I'm assuming it doesn't show up on a PC as an xinput controller?
bootsector
Yes, this is a Classic/Original XBOX encoder, so it shows up to the XBOX as a regular controller. It works with the Classic/Original XBOX only, not PCs or any other console.
  • Last login:Yesterday at 08:00:13 pm
Thanks, man, this was starting to be a real problem for using original Xbox.
sokignano
  • Last login:February 09, 2022, 01:52:41 pm
I was looking at the pinout and I have one question? Where does the out to the xbox get wired in? The micro usb port?
bootsector
Yes, you connect it to the XBOX via  the micro USB port.
shaolindrunkard
  • Last login:February 12, 2026, 11:54:11 am
Forgive me and no offense but, why?
Cheap and easy way to wire up arcade controls to an Xbox.
sokignano
So I flashed the board hooked up some buttons and it worked!!!!!!! Thank you!
I have one request. Can you program on the unused pins to be a multiple button press. Like the 2 triggers, back, and black button, so that I can wire up one button to reset the system.
Thank you again!
bootsector
Thank you again!
So we have the first beta-tester!  ;D
There are no unused pins. All pins are mapped to some functionality of an original XBOX controller.
You could always wire up a single button to all desired functions to a single GND wire, that would achieve what you just mentioned.
Did you have the chance to check if all pin functions in the diagram below are correct?
You can use the Test Pad App in order to verify that!
Let me know!
sokignano
With this stick I was making for a friend and only needed it for arcade games so I gave him a simple Capcom style layout. With a few extra buttons for Coin, Start, L3 and System Reset. So I wired up the L, R, Back, and Black buttons together, and anytime i pressed any of the aforementioned buttons the system would reset lol So i thought if I could get one of the pins that wasnt being used to emulate the L,R,B,BL reset on one pin that would have been great! :)
sokignano
I just read the rest of the post, the buttons I tested were, UP, DOWN, LEFT, RIGHT, A, B, X, Y, LT, RT, BACK, START ,R3, BLACK. I didnt have any use for the analog Sticks, or L3, or WHITE
MaxRod
  • Last login:November 10, 2018, 09:20:47 am
As I've mentioned. I still have a stash of minimus here. There doesn't seem to be much demand for them to continue pursuing a larger order of these. I have about 40 left.
Re: the minimus site. I asked about the site but didnt get a definitive answer. I know people that could host the site
What were you selling them for again?
MaxRod
initially i was just offering them at prices depending on who wanted them and how many they wanted.
:dizzy:
:dizzy:
Sooooooooo..... bro price for one shipped?
MaxRod
pm me a place where a postman can hand it to you.
Rodent.Vienna
  • Last login:November 20, 2020, 03:47:26 am
Hi,
thank you for porting this over to 32u4!
an Option to turn the right analog stick pins into mouse x+ x- y+ y- pins for trackball, spinners or encoders would be nice :)
Thank you for your efforts!
Alex
Brian74
  • Yep... I built that!!
Subscribed
bootsector
My super cheap Arduino Micro clone boards from eBay has just arrived. I've flash the firmware as per documentation and everything works as intended.
Since the purpose of this firmware is solely to prevent people to padhack classic XBOX joysticks in order to get their arcade built in a simple and cheap way, I shall not add more features to this firmware, unless it's a critical bug.
As for the features such as adding analog capabilities, I will leave that to the upcoming KADE miniArcade 2.0 board...
scroeffie
KADE miniArcade 2.0 < ?? there is going to be a kade 2.0 ? for the xbox ??
bootsector
For the XBOX and for all the devices listed in the "Output Systems" below:
Output will be plug-and-play and automatic (no need to change firmware between output systems).
It will be based on an Atmega32u4 (Arduino Micro is not an option because it lacks a couple of usable pins) and it will support several analog input ports, mappable to any button for output systems.
PL1 should get a sample soon and he should share his discoveries in a post around here...
« Last Edit: January 31, 2017, 02:57:44 pm by bootsector »
scroeffie
so its just a software change not the hardware
bootsector
Both Software AND Hardware have changed compared to the original KADE miniArcade
scroeffie
so when does the new kade come out ? wil they have another kickstarter
bootsector
No ETA. We still need to discuss how this is going to be released. Probably not via kickstarter.
scroeffie
oke
scroeffie
if it wil be solder only its not for me but wil see :)
scroeffie
any update !
  • Last login:Today at 05:02:13 am
any update !
How about an unexpected XBOXPadMicro update?
Since I know that you're looking for a no-soldering solution, here it is.
The Arduino Micro knockoff board here sold by "gowoops" comes with header pins already soldered onto it.   ;D
Wiring Option 1:
Use pre-fab 4-pin harnesses like this and a daisy-chan ground like this from Paradise Arcade Shop. (If you ask Bryan and Susan, they might be able to substitute a daisy-chain ground with one female dupont pin on one end instead of all 0.187" Quick Disconnects)
Wiring Option 2:
Connect dupont jumpers like the ones here to the desired header pins.
Cut off the other end of the jumper, strip the wire, and feed it into one side of a euro-style terminal strip like this.
On the other side of the terminal strip, connect pre-crimped wires cut from a JAMMA harness. (cut off and discard the big edge connector)
johnnygal2
  • Last login:October 08, 2022, 03:16:04 am
I have a Arduino Micro clone (http://www.ebay.co.uk/itm/252639960296?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT) that I'm trying to program with avrdude on widows 8.
I can see them COM port ok in device manager. I have tried the drivers supplied with this XBOXPadMicro zip and also the latest.
I always get the error: Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
I have tried resetting the Arduino and running avrdude straight away (failing until the com port is re-established) but get the same error.
I can download a sketch ok using Arduino IDE.
After each try, if I rerun avrdude again, it will hang rather than giving the error message above. It will do this until I reset the Arduino.
The verbose output from avrdude is attached.
Any suggestions anyone?
Thanks,
John
« Last Edit: February 12, 2017, 02:10:33 pm by johnnygal2 »
Programming the Micro can be a bit finnicky sometimes.
You might want to use ArduinoBuilder to load the "XBOXPadMicro.hex" firmware file.
There's a simple 3-step tutorial here.
johnnygal2
Thanks for that Scott. However, even with Arduino Builder I cannot load my hex.
I get the error:
Forcing reset using 1200bps open/close on COM7... no new port found
Searching for similar errors, some people found changing usb port helped - not for me. I'll maybe try another PC.
Just to check....I should be able to program this directly using the USB port on the Arduino Micro? Or should I be using an FTDI adapter connected to the ICSP header on the Arduino?
Thanks.
johnnygal2
Ahh ok, the ICSP header isn't a serial port, so would need a separate programmer to use this port. Guess Im doing it right then by using the onboard usb on the Arduino.
I tried another PC with the same result, even before loading the Arduino drivers it gave the same error so perhaps my issues lies in the drivers.
I get the error:
Plug in your Micro then open Arduino Builder.
Does it show "COM7" (or "COM8", etc.) to the right of the "Build Only" button?
The "finnicky" part is that while "COM1" always shows up, sometimes the second port "COM7" doesn't.
Here's how I fix COM7 not showing up:
1. Close all Arduino loading software. (Arduino Bulder and Arduino 1.0.6 software)
2. Plug the Micro board into a USB connection.
3. Open the Arduino 1.0.6 software.
4. Open one of the small default sketches. (I usually use "Blink".)
5. Click on the right arrow (Upload) icon.
6. About 1-2 seconds later, press the reset button on the Micro to put it into bootloader mode.
- Perfect timing on the press is just before the software finishes compiling and starts uploading.
- Too soon and the board drops out of bootloader mode before the upload is complete. (upload fails)
- Too late and you interupt the upload. (upload fails)
7. If the upload fails, repeat steps 5 and 6.
8. Once the upload succeeds, go to menu "Tools-Serial Port" to verify that COM7 is visible.
9. Close the Aduno 1.0.6 software.
10. Open Arduino Builder.
11. Set board type to "Arduino Micro".
12. Click on "Load Skech/HEX" and select the "XBOXPadMicro.hex" file.
13. Click on "COM7" to upload the hex to the board.
Yes, you can load the hex via the USB IF you can see the second COM port. (COM7)
johnnygal2
Thanks Scott, what a polava!
Seeing as though Arduino IDE does it from the GUI, I thought other tools would be able to emulate it without this jumping through hoops ;-)
I didn't have any luck using the exact method you specified, but using ArduinoBuilder and resetting just as I pressed the "COMxx" button, it spotted the new com port and programmed my hex ok.
Cheers,
John
« Last Edit: February 11, 2017, 04:21:48 pm by johnnygal2 »
