Author Topic: Arcade Power supply  (Read 1258 times)
tbird
  • Last login:July 11, 2016, 11:24:00 am
Arcade Power supply
« on: June 17, 2016, 07:45:20 am »
Hi All, Iv'e started to work on my own Arcade project centralised with a raspberry PI 3 as the main driver, I've spent a lot of time looking at what elements I need to include what's best etc. My current issue is around power. I want have a single power supply at the back of the unit I've looked at installing a arcade power supply like this for example http://www.arcadeworlduk.com/products/Black-Arcade-JAMMA-Power-Supply.html . I will have the following power supplies
1. 12v Power for Illuminated buttons
2. 12v Power for Speakers
3. Raspberry PI3 2.5 Amp
4. Monitor - Standard UK power
5. Top display light - Standard UK
So my question is I have multiples of for example 12v, can I attach more than 1 item to each terminal so could I for example connect Lights&Speakers together on the same 12v terminal as I only have one. And again could I strip the power cables on the Montior and Top display light and attach them both to the AC
Thanks in advance
Slippyblade
Re: Arcade Power supply
« Reply #1 on: June 17, 2016, 12:52:58 pm »
Why not just use a single ATX power supply and pull your various voltages from that?  Then you have ONE power supply in the system, much less of a change of ground issues.
Thenasty
  • Trade Count: (+17)
  • Last login:December 17, 2025, 10:15:06 pm
« Reply #2 on: June 18, 2016, 07:33:34 am »
Free VGA Breakout Cable
wbassett
  • Last login:October 05, 2024, 02:18:42 am
« Reply #3 on: June 18, 2016, 09:11:07 am »
Thenasty if you still have some I would be interested in a couple.
DarthBS
  • Last login:May 26, 2019, 01:35:39 am
« Reply #4 on: June 18, 2016, 10:31:58 am »
thenasty pm sent. need me some power. thanks@!
