Author Topic: What planet did this button arrangement come from  (Read 9468 times)
8BitMonk
lamprey
Re: What planet did this button arrangement come from
« Reply #1 on: June 09, 2016, 11:51:18 am »
I didn't have carpal-tunnel before looking at that, but I think I do now. OUCH!
jeremymtc
  • Last login:October 22, 2025, 08:45:06 am
« Reply #2 on: June 09, 2016, 12:35:18 pm »
Whatever planet it is, they must have two left arms there. Or, perhaps the constructor had an extra arm fitted to improve their ski boxing?
« Reply #3 on: June 09, 2016, 12:50:22 pm »
I'm sure if you ask the dude, you would get some version of this response...
"It's always worked well for me, and none of my friends who played have ever mentioned any issues with it"
thomas_surles
« Reply #4 on: June 09, 2016, 12:54:26 pm »
Looks like they just tried to jam too many button on a small panel. I think the way to play it is to cross your arms, use the stick with your right hand and the buttons with your left???
8BitMonk
« Reply #5 on: June 09, 2016, 12:55:46 pm »
The buttons are arched so it's like they used one of the slagcoin templates but then inexplicably rotated it with the curve away from the player. Bizarre.
« Reply #6 on: June 09, 2016, 01:00:04 pm »
Best I can come up with is maybe it started as a 3 button layout (middle red/bottom two yellow, middle blue/bottom two green).
EDIT: Picture uploaded here for posterity
« Last Edit: June 10, 2016, 10:42:13 am by BadMouth »
  • Last login:Today at 01:02:43 am
« Reply #7 on: June 09, 2016, 01:37:12 pm »
Hahahahahahahaaha
Sent from my SM-G386T using Tapatalk
Token
« Reply #8 on: June 09, 2016, 01:51:47 pm »
It's perfect for someone with backward-hand syndrome.
Maphreal
  • Last login:June 26, 2016, 09:26:25 pm
« Reply #9 on: June 09, 2016, 04:18:35 pm »
I wanna say the same thing. It kind of looks like they loaded the control panel in a vise backwards, drilled the pattern, then said "Screw it, I'm not making another." when they noticed the mistake.
Xiaou2
  • Last login:Today at 01:37:25 am
  • NOM NOM NOM
« Reply #10 on: June 09, 2016, 08:26:55 pm »
Its simple.   The cab had a diamond shape button setup. Most likely a metal cp.
Rather than re-work it,  they just added 2 more buttons next to the grouping.
They might have placed the.higher up... but the start button was quite close.
Most likely a case of cheap cabinet flipping for a fast profit.
Generic Eric
« Reply #11 on: June 09, 2016, 09:27:43 pm »
Each player stands 45 degrees to the right, thereby maximizing the area in front of the control panel.
ballboff
  • Last login:July 22, 2024, 02:25:17 am
« Reply #12 on: June 10, 2016, 03:09:48 am »
Nah, you're all wrong! He made it for him and his older brother.  Usually player 2 is the younger brother, but since he built it he made himself player 1.  His brother had larger hands...
« Reply #13 on: June 10, 2016, 07:56:19 am »
Then explain the diamond being so crooked, not the same for each player, and angled?  :angel:
I know you're basing your answer on the Dynamo "double diamond" control panel , but I don't think that's the case:
3rd panel being the best example( none of the 4th holes lined up with the pattern either)
I believe the guy got a Swiss cheese panel like I had with my old Dynamo:
And he just made the most of it.  3 year old tax sticker, and another one for 2016 about to expire, I think the game just isnt making any money on route anymore and he's getting rid of it.
nitrogen_widget
« Reply #14 on: June 10, 2016, 10:18:43 am »
LMAO in my cube at some of these responses.
« Reply #15 on: June 10, 2016, 02:21:25 pm »
It came from Uranus!  :lol >:D
  • Last login:November 26, 2025, 03:26:23 pm
« Reply #16 on: June 10, 2016, 05:49:42 pm »
Uranus...because it looks like ass?
« Reply #17 on: June 10, 2016, 06:15:24 pm »
 ;)  :lol
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #18 on: June 11, 2016, 07:18:25 am »
heh i like how he says 645 hd games then has the following games listed.
has a total of 645 hd games on it
including
Ms Pacman
Galaga
Frogger
Donkey Kong
Donkey Kong Junior
Donkey Kong 3
Simpsons
Punisher
WWF Superstars
X-Men
Street Fighter 2
X-Men vs Streetfighter
D & D
Ghost & Goblins
Metal Slug
1943
TMNT
Robocop
Final Fight
TapeWormInYourGut
  • Last login:August 17, 2025, 06:31:27 pm
« Reply #19 on: June 14, 2016, 07:29:54 am »
I think he accidentally mapped and drilled the pattern on the bottom side instead of the top, and decided to just keep it instead of re-drilling. If you flip the panel vertically put the buttons and joystick on the other side, then the pattern kind of looks looks correct.
    • GroovyGameGear.com
« Reply #20 on: June 14, 2016, 03:35:54 pm »
If I were to try to explain this (and I'm about to  :lol) I would say that this was made with consoles in mind.
It makes sense if you view the bottom 4 buttons in a diamond shape (Like PS, XBOX, etc. controls) with the upper two buttons being the L/R shoulders.
Nutty from a standard arcade POV, but notsomuch for consoles.
8BitMonk
« Reply #21 on: June 14, 2016, 03:46:27 pm »
In that regard the concept isn't as nutty but the actual act of playing console games on a standard arcade still is.
thomas_surles
« Reply #22 on: June 14, 2016, 11:05:40 pm »
That actually makes the most sense
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #23 on: June 15, 2016, 05:04:46 pm »
I think its played like some left handed players used to play in the arcade days.They would cross their forearms.  Joystick (typically mounted on the left side) played with right hand. buttons located on the right side are then played with left hand.
I know a couple of left handed players who play like this.
That's the only way this makes sense in my head. It still hurts to look at.
« Last Edit: June 16, 2016, 06:47:53 pm by michelevit »
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
« Reply #24 on: June 16, 2016, 04:03:00 am »
Looks like he just flips machines, I see he has even made a marquee for my jukebox software. He's probably using a cracked version of that or offering them without coin support  ::) That CP is just horrible.
ballboff
« Reply #25 on: June 16, 2016, 07:27:59 am »
including
Ms Pacman
Galaga
Frogger
Donkey Kong
Donkey Kong Junior
Donkey Kong 3
Simpsons
Punisher
WWF Superstars
X-Men
Street Fighter 2
D & D
Ghost & Goblins
Metal Slug
1943
TMNT
Robocop
Final Fight
They used to use the term HD quite a lot back in the day, it only means high definition as people know.  It's only in recent years they have limited the term to just one specific resolution (1920 x 1080, or 1080p as it is known). That particular board i'm certain it has a vga connection and it only goes up to about 800x600.
« Reply #26 on: June 17, 2016, 10:30:43 am »
I don't care what anyone says. Playing arcade-style console games on a little handheld d-pad controller could never hold a candle to playing those games with arcade controls. But this also comes from someone who has been building control panels to use with consoles since the late 70's, when it was virtually the only way to play the popular arcade titles at home.  So I'm probably just set in my ways  :lol
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #27 on: June 17, 2016, 10:45:44 am »
I <3 Cheffo will be the theme of next year's ZapCon shirts.
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #28 on: June 17, 2016, 10:47:22 am »
Please start saving your pennies now so you can come. We need another guest of honor. Ond started that tradition. :cheers:
« Reply #29 on: June 17, 2016, 10:49:09 am »
Therein lies the rub but us spineless cowards need something to  obsessively whine about after all.....
  • Last login:Yesterday at 10:44:44 pm
« Reply #30 on: June 17, 2016, 01:11:54 pm »
I'm not here to have fun.
« Reply #31 on: June 17, 2016, 01:13:44 pm »
There's only so many ways to grift Amazon, brother.
DrakeTungsten
  • Last login:August 14, 2022, 06:36:45 pm
  • I effed with the wrong person!
    • No Quarter - a basic FE, WIP
« Reply #32 on: June 18, 2016, 08:52:04 pm »
I had a brief private exchange with HarveyBirdman. In the end, he showed a lot of class.
« Last Edit: July 17, 2016, 05:05:58 pm by DrakeTungsten »
« Reply #33 on: June 18, 2016, 09:47:28 pm »
I had a brief private exchange with HarveyBirdman. He took some abuse from me in public, so it's only right that I publicly state that, in the end, he showed a lot of class.
HBM is a classy guy. We all are, actually, if you got to know us.
« Reply #34 on: June 18, 2016, 09:50:22 pm »
Except for pbj, but he's our porn watching Amazon gifting ps4ing drunk uncle.
« Reply #35 on: June 18, 2016, 10:13:24 pm »
I'm bummed the site was so wonky around ZapCon. The camaraderie was flowing like wine.
  • Bitches love Centipede
« Reply #36 on: June 18, 2016, 10:23:17 pm »
%Bartop
jan25th
  • Last login:September 11, 2025, 10:15:20 am
  • Long time lurker
    • forum.arcadecontrols.com/index.php/topic,147244.0.html
« Reply #37 on: June 20, 2016, 12:37:40 pm »
!Ay, caramba,
Just popped in to see what all the excitement was over this button arrangement and get this ....
Titchgamer
« Reply #38 on: June 22, 2016, 05:04:36 am »
I can only assume (If there was any logic to that) The builder had the mind of building it to use as 3 rows of 2 as opposed to 2 rows of three.
If you think of it like that the config would work but for someone with relatively small hands like myself the reach over to the top set of 2 would prob be to much and I would be hitting the bottom ones with my palms I think!
Either way, Thats a horrible layout LOL
reptileink
  • An 8 bit hero
« Reply #39 on: June 22, 2016, 03:35:11 pm »
Here's one from my local CL.......explain this?
