Author Topic: Emulation Station white screen of death  (Read 7482 times)
« on: May 22, 2016, 04:50:55 pm »
My pi2 with retro pie and emulation station recently started a weird thing.
After boot up and the emulation station loading screen, the screen goes white.
I read somewhere that ES will do that if you have more than a certain quantity of folders.
So using winscp, I went in and deleted the files from a couple of folders, cutting down to 10 folders and it worked.
Anyone else seen this problem?
ES ver 3.6
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
Re: Emulation Station white screen of death
« Reply #1 on: May 23, 2016, 09:12:34 am »
It's covered in the RetroPie wiki https://github.com/RetroPie/RetroPie-Setup/wiki/Themes
Your options:-
  • Increase your GPU/CPU split
    Remove some systems (which you did)
    Switch your theme to any Carbon, Pixel, Eudora, Turtle-Pi, or Canela variant (as they have one static background and therefore don't crash when you have many systems)
