Author Topic: Need information on Monitors  (Read 4281 times)
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:27:24 am
« on: June 21, 2002, 07:10:09 pm »
I've read somewhere about a Polo hantarex monitor that is auto switching between 15khz and 25khz. Where can I find information about this monitor or any other type of monitor that is auto switching and most importanly, who sells it ?  Thanx
Free VGA Breakout Cable
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Re: Need information on Monitors
« Reply #1 on: June 26, 2002, 12:03:55 pm »
Thenasty
« Reply #2 on: June 26, 2002, 03:04:49 pm »
Thanks, I looked at the web page and I -e-mailed them. But in the meantime while I wait, I wonder if anyone out here have the Polo/2 15-25Khz Automatic Monitor. If you know anyone here in US or anyone that sells this monitor, please LMK. THNX
Andy Geez
« Reply #3 on: June 26, 2002, 05:11:14 pm »
I own a Hantarex Polo2 Automatico (Auto 15/25khz switching), what would you like to know?
Thenasty
« Reply #4 on: June 27, 2002, 06:25:06 am »
I want to use for it MAME. I wanted to know if for example, ( I am using AdvanceMame), I setup Jungle King (its a 15khz) and run it, then I also have a setup for 25Khz and run NARC. I have  2    .rc files one for 15khz and 1 for 25khz. Could the Monitor handle this on the FLY ? I mean do you have to turn monitor off first to get the other frequency ? I hope I did not lose you there. Thankz..
Andy Geez
« Reply #5 on: June 27, 2002, 09:07:45 am »
Yes it is automatic, so you don't have to switch off, that be the point of automatic! ;)
Another thing, you wouldn't need 2 different .rc files either, just create the modes with advv.exe and create the standard res modes 320x240 and so on and the med res ones 512x384, 512x400 and so on.
Works a treat..
One point, you'll have about zero chance of buying one in the US, US like to buy US products, not European products.
Your best bet is to buy the Wells Gardner D9200 which is a similar price..
Thenasty
« Reply #6 on: June 27, 2002, 04:41:22 pm »
I guess you live in UK. I looked at the WGd9200 but it seems like its the same thing what I'm after. I needed something like the POLO. One connection and will auto switch to iether 15,25 khz or even the 31khz. I dunno if the d9200 is like that.
This is what exactly I wanted to do....The game NARC it used Med Res and palying it the Standard, the image will have to be shrink. So with a POLO this might take care of that problem when it switches to 25khz, the image should be better compared to 15khz. Any idea you have would diffenately appreciated. Thnx
Andy Geez
« Reply #7 on: June 28, 2002, 08:59:41 am »
To my Knowledge the WG9200 is very similiar to PC monitors and supports automatic switching..
You do know with the BladeT64 from Andy (www.ultimarc.com) you'll be able to play Narc at 640x400 at 57fps on a Standard Res monitor?? I can take a few photos if you want to see how the quality looks.
You can probably import a Hantarex over from Europe, the monitor weighs around 25kg so you'd be looking at around $150 USD I should think. They do 2 power rated version 100 -120VAC and 220 -240VAC.
Cheers
Andy
