Author Topic: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)  (Read 1766247 times)
DMB77
  • Last login:October 22, 2025, 07:33:25 pm
« Reply #3640 on: October 22, 2025, 07:33:25 pm »
Thanks for the update Aragon, MIB is Sooo much better without the guns. Everything is working however I can't aim all the way to right side of the screen.  I didn't change any of the setting in the BepInEx folder, and my desktop resolution is 1080x1920.  Any Ideas on how to fix this?  The game works fine on teknoparrot but I can't use the no crosshairs/gun with TP.
petran79
  • Last login:November 04, 2025, 11:59:04 am
« Reply #3641 on: November 03, 2025, 12:25:36 pm »
What is the argument for Chihiro version of house of the dead 3 to work via cxbx ds 1.0?
when I enter demulshooter.exe -target=chihiro -rom=hod3
cxbxr-ldr.exe does not register the mouse cursor in game. No issues in launching and shooting in Virtua Cop 3 if I enter rom=vcop3
Do I need to type something different than hod3?
PC version has issues as arcademod launcher does not work in Windows 11 unfortunately. I have to set compatibility to Win7
« Last Edit: November 03, 2025, 12:35:38 pm by petran79 »
argonlefou
  • Last login:Today at 01:47:38 am
« Reply #3642 on: November 03, 2025, 05:33:40 pm »
You have the correct command line for chihiro DS build, as you can see here
I have not used it for a long time, I don't exactly remember if there was some issues with build version / rom version to get it to work
I keep using the pc mod instead
As I just replied on your Github ticket, I use both hod3pc and the mod on a windows 11 computer without any trouble
petran79
« Reply #3643 on: November 04, 2025, 10:43:42 am »
I managed to register light gun and it could shoot but cxbx crashed immediately in the first stage.
Tried it again by disabling bezels, exclusive full screen and shaders and it run without crashes even to stage 3. Unfortunately even on a modern cpu (i5 245k in my case), emulation has slowdowns. While VC3 runs smooth.
Only difference are the better textures and vfx. Eg in the Fool boss encounter, you can clearly see the faces of the corpses falling. While on PC even at 1920x1440, those textures were a mess.
So PC version remains the best option till they improve.
Yes, issue was with not copying the patched hot3 exe to exe folder and had it in root folder instead. Now it seems to run
« Last Edit: November 04, 2025, 11:59:04 am by petran79 »
argonlefou
« Reply #3644 on: November 04, 2025, 07:07:46 pm »
Glad to hear that you managed to make it work.
And yes, Chihiro hod3 on Cxbx is not what I'd call "fully playable" state... Unfortunatelly.
Even VC3 has some texture issues, mainly the usual "Virtua Cop Circles" surrounding the enemies are not showing on cxbx.
Xemu is rendering them without any issue, but I don't think it's lightgun friendly
Jayinem
  • Last login:Yesterday at 11:11:14 pm
« Reply #3645 on: November 20, 2025, 06:37:34 pm »
Argon I usually use Teknoparrot for those specific light gun games but I can't get controls to work at all for one game, Point Blank X. So I'm using Demulshooter but 5 is not working to enter coins? 1 is working for start it says coin error. I am also unable to get into any test menus. I did copy the content of Point Blank X to where the .exe is, but I'm confused about your instructions
Edit the newly copied Setting.ini file (located in PBX100-2-NA-MPR0-A63_Data\ subdirectory of the game) to your needs. Available options and values are written in the ini file.
I don't really know how to edit that .ini? It looks like this
CONTROLLER 1 # 0=BNUsio 1=Simulated
GUNPORT 3 # COM port for Gun board
TICKET 0 # 0=Disabled, 1=Enabled
MAIN_PATH ./NVRAM/ # Main save location
BACKUP_PATH ./NVRAM/ # Backup save location
LANGUAGE en-US, ja-JP,zh-CN,ko-KR,es-ES,pt-BR,th-TH,ru-RU,id-ID # language at the first is default
I don't know how to change anything in this can you help?
Edit: I realize now backspace is test menu and I was able to disable coins, however it seems demulshooter is not hooking because it's red and my wiimote doesn't seem calibrated. I copied all of the files of Demulshooter 16.2 and put them where the .exe is and here is my script
Run, DemulShooter.exe -target=es4 -rom=pblankx
run, PBX100-2-NA-MPR0-A63.exe
I tried running Demulshooter.exe as administrator but Demulshooter is still red not green?
Edit 2: Now that I figured out how to disable coins in test menu the game is fully working in Teknoparrot.
« Last Edit: November 20, 2025, 07:09:50 pm by Jayinem »
argonlefou
« Reply #3646 on: November 21, 2025, 10:00:57 am »
This is a simple text file, just change whatever setting you need to be changed
What's after the '#' signs are comments, so just change the setting before like
LANGUAGE es-ES,en-US, ja-JP,zh-CN,ko-KR,pt-BR,th-TH,ru-RU,id-IDif you want Spanish laguage by default
Backspace key was listed in the game wiki page
As for DS not hooking the game,  it can be many things but a demulshooter log would be a good starting point to see if something obviopus is going on
And, as I usually said, trying to get things running directly without using AHK scripts or BAT or frontend is also a good starting point as those scripts/tools can add a layer of possible errors....
Jayinem
« Reply #3647 on: November 24, 2025, 02:04:41 pm »
Not a Demulshooter issue per say but Police Trainer 2 is broken in newer versions of Teknoparrot it throws an error and won't boot. I've been searching for a Teknoparrot emulator version that is about 6 months to a year old but can't find any on google the only one on the official website is actually too old Police Trainer 2 isn't even in the list of games it's from 2023. Does anyone happen to have a Teknoparrot this old that's not updated that you could upload somewhere?
« Last Edit: November 24, 2025, 02:06:59 pm by Jayinem »
Jayinem
On Chihiro_DS 1.0 Virtua Cop 3 works okay and Ghost Squad appeared to the graphics were perfect in the menus and I could shoot with my Wiimote but as soon as I get into actual gameplay the characters are all black and I can't shoot them?
