Author Topic: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)  (Read 1972893 times)
0 Members and 25 Guests are viewing this topic.
argonlefou
  • Last login:Yesterday at 07:08:33 pm
I've been testing Ultimate Trophy with Demulshooter and found two problems, maybe generated by my rare config:
If I press trigger at the beggining, in the "press any button" first screen, keyboard and mouse wont work, so I can't proceed to the game.
In Classic and Bonus modes, which are turn based if two players, player 1 works, but player 2 uses gun 2 coordinates but gun 1 buttons
I can't say about the "press any button" screen as I'm not interfering with menu/GUI controls....DS only acts on the hunting scenes
As for classic/bonus mode, I just fixed it in a new update.
As I explained to someone else regarding that issue :
Indeed, there was a mixup for turn-by-turn controls.
This is fixed in last v15.3 update.
Using DemulShooter will work that way :
    When playing simultaneous multiplayer mode, both P1 and P2 devices will be used for each player to have it's own gun
    When playing turn-by-turn multiplayer mode, only P1 device will be used for both player
I'm aware some would rather have separate devices for turn-by-turn, but this would prevent users having only 1 gun from playing turn-by-turn as DemulShooter cannot use the same device for different players
purbeast
  • Last login:March 02, 2026, 06:11:19 pm
Is there any option with DemulShooter or any of it's supporting tools (like the GUI to set game specific controls) that will hide the mouse cursor when DemulShooter is hooked to the game?
I recently setup Friction and Silent Hill and both of those games when they load up, have the spinning cursor in front of the game and then it eventually turns into the arrow pointer, and it won't go away.
I am trying to just hide it so it doesn't show up since this will be in a light gun cabinet where a mouse won't be easily available.
Thanks.
Unfortunately no, as those mouse cursor are not handled by the game window but system wide.
There's a tool for that purpose, it's called "nomousy" and you can find it here and there on the internet
It will show/hide cursos system wide in windows
Unity game are a specific case, where unity engine has embedded code to hide/show those cursor,so it is possible to use it to force/hook/mod cursor visibility
Okay thanks I will check this out later.  I'm running both of those games via a bat file too so I think I can just add the hide/show commmands in there.
DMB77
  • Last login:October 22, 2025, 07:33:25 pm
I have an issue with Big Buck Hunter - Ultimate Trophy the crosshairs are aligned fine in all the menus, but once I'm in the game, it's off to left, messing up my aim.  Anyone else experienced this or know how to fix it?
Edit:  Updating to 15.3 fixed it.  Thanks Argon!
« Last Edit: April 21, 2025, 05:27:39 pm by DMB77 »
purbeast
Okay great that nomousy.exe worked for me.
Now I'm running into another issue with Silent Hill: The Arcade, and I don't think this really is demulshooter specific but thought I'd ask here since I'm using that to set the exit keys.
I have a custom exit key set in HyperSpin so that I hold down P2 start button on my cabinet for 2 seconds to go back to HyperSpin from a game in an emulator.
I have 2 PC game I'm launching through Hyperspin - Friction and SH - and I have Friction quit key set to F12.
When I hold P2 start for 2 seconds, Friction quits no problem and goes back to HyperSpin back to the wheel,.
Now with Silent Hill, when I hold P2 for 2 seconds, it goes back to HyperSpin, however the SH executable freezes up and the "game over" image screen just hangs in the view of the SH window, and this is overtop of HyperSpin at this point.
I have tried setting Silent Hill exit key to both ESCAPE and then I set it to F12 to have it match Friction, and this behavior happens no matter which key I have set for escape.
I'm just curious if anyone has any idea how this can be solved for Silent Hill in tandem with HyperSpin/RocketLauncher.
EDIT:
I tried turning fade out off, and that solves the issue but it doesn't look super clean.  I may play around with it a bit more.
« Last Edit: April 21, 2025, 06:14:03 pm by purbeast »
argonlefou
I'll pass on that one, not using any of these frontends
purbeast
I am not sure why but with Virtua Cop 2 on the m2 emulator, it is like the buttons or tracking or something gets messed up for me.
I went into the gun calibrations and I can see it tracking perfectly there.
It seems to stem when I'm playing when I go to shoot offscreen to reload sometimes, and it doesn't actually reload.  Instead the revolver clip just kinda spins around with the bullets still in there.
And it stays in this weird state until I can get a real reload or something like that, and then the tracking works perfect when I'm shooting on screen again until I am out of bullets.
I have noticed that sometimes if I do a quick double trigger pull to reload offscreen that reload works but I can still get into this weird state.
Has anyone experienced this before?  I don't have this issue on either Virtua Cop 1 or House of the Dead.
purbeast
Speaking of Virtua Cop, I got Virtua Cop 3 working on chihiro and everything is working great with demulshooter.
I was wondering though if anyone knows what the bullet time button the controller is.
My gun only has button 1 and button 2 - shoot on screen and off screen - so I don't have the 3rd mouse wheel button on my controller.  I do however have a pedal and wanted to map my pedal to whatever button controls the bullet time if it's possible.  I tried figuring it out but so far no luck.  I have my p1 start button on my cab mapping to the start button on the controller and that works fine.  My pedal is mapped to the V button via a JPAC interface if that matters.
Thanks.
argonlefou
Thanks.
I don't have all the details by memory but as DemulShooter is handling the Bullet Time command with the middle click button, chances are high that it's been disabled (orverwritten) from the native buttons procedure.
If that's the case, the easiest thing you can do is enabling Virtual Buttons in DemulShooter GUI for your Lightgun, then mapping the middle click button to [V] (your pedal keyboard key)
That way your pedal should trigger DemulShooter's middle click event (even if you don't have a 3rd button on your lightgun)
« Last Edit: April 27, 2025, 03:46:35 am by argonlefou »
purbeast
Thanks.
Awesome thanks I will give that a go later on.
And yeah you are correct that the middle mouse button is mapped to it.
When I was messing with mapping the controller to other keys, the Y button on the controller reloads, which is mapped to the right click button on the mouse.  So I thought that you could use both bindings on the controller as well as the default mouse button.
purbeast
Okay I am a bit confused as to how to set the virtual button to the keyboard but also have my joystick set for my lightgun for P1 device.
It seems like from the GUI if I pick the Keyboard device, and set virtual mouse middle button to V, then I have to save it with the keyboard set as the device.  In that case, my guns don't work since I don't have the joystick set for the P1 device.
I tested it out with the keyboard set as the device and the pedal does in fact do the bullet time as expected, but my guns aren't working since the joystick is not set to the device.
The I tried switching back to my joystick for the gun while having the virtual key set in the keyboard config, but then just the guns/tracking works fine and the pedal doesn't.
Am I missing something as to how you can mix these configs?
argonlefou
Oh....sorry this is my fault, I (wrongly) assumed that your gun was an IR-based gun
It looks like you have an analog-based mounted gun, if you have to choose a joystick like Device
Unfortunately, virtual buttons were not added for that kind of device....only for mouse-alike guns😞
purbeast
Yeah I have a pretty unique setup with my happ 45 guns running on a USB2GUN board which makes Windows see actual light guns as analog sticks.
Thanks though I will see if I can find some kind of "key2mouse" type of thing to map my V key to the middle mouse button for this.
purbeast
I came across this application called NeatMouse which maps keys to mouse buttons, and I am able to map my pedal (V) to the middle click.
It works fine and dandy when I test it out in the desktop and in the browser and stuff, but for some reason when I try to use it in Virtua Cop 3 it doesn't work as intended.  It is acting as though I am not pressing the middle click button and just nothing happens.  I've tried it with not just the pedal V key but also other keys, and it is the same behavior.   And when I exit the game, NeatMouse is still running and the key acts as if the middle mouse button is being pressed on the desktop and everything.
I tried making NeatMouse open both before and after DemulShooter and it's the same behavior.
Do you think there is some sort of conflict between Demulshooter and the NeatMouse application?
purbeast
argonlefou do you know if demulshooter will hook into vcop3_t.xbe?  Or does it only hook if you load up vcop3.xbe?
The reason I am asking is because in the cxbx input config, I set all of the ABXY buttons.
A = shoot
B = reload
X = change weapon
Y = pedal
I verified this by loading up vcop3_t.xbe and going into the input test option.  I set Y = V in my config, and when I press my pedal, the pedal switch turns to "ON".
However when I try to actually play the game via vcop_t.xbe, it crashes as soon as the level starts.
So after having all of that setup, I then tried loading vcop3.xbe and seeing if the pedal would actually do what it should do - the bullet time.
However, when launching with vcop3.xbe, pressing the pedal instead is reloading for me.
When I load both of these, I am running DS prior to it.
So when I am in vcop3_t.xbe and testing the input, with Y on the controller set to V, pressing V makes the pedal switch get pressed.  But when I have Y on the controller set to V when playing the actual game with DS hooked in, pressing V reloads.
I took some videos showing this however that was before I remembered it's a completely different xbe file being loaded, so maybe DS isn't being hooked into the test menu one.
EDIT:
So I did confirm that it does in fact hook into vcop3_t.xbe because I tried it on my higher res monitor so I can see the desktop, and I see it green in the bottom right when it's running.
Below are my 2 videos showing that in vcop3_t.xbe it appears that the Y mapping in CXBR to key V actually pushes the pedal button, but as you will see in the actual vcop3.xbe in the game, the Y mapping in CXBR to the V key is reloading.
vcop3 test menu - https://www.youtube.com/shorts/Sn4DvEzG2dA
vcop3 game play - https://www.youtube.com/shorts/3Th14WfIRS0
EDIT 2:
Just to clarify, NeatMouse is not running in reference to this post.  It's not running at all when those videos were take and when I'm seeing this behavior.
« Last Edit: April 28, 2025, 10:08:06 pm by purbeast »
argonlefou
No conflict, simply expected behavior
The whole point of DemulShooter and RawInput is to read input directly from the controller (thus beeing able to separate them, which is something Windows is not doing for mice).
So using Autohotkey, or any other mouse-simulating program (NeatMouse seems to be that kind, although I don't really know it) will never trigger anything if DemulShooter has some kind of "Mouse" device selected because those simulated inputs are not comming from the real device.
The virtual keys options were made for that purpose, as 10+ years ago Lightgun options were very, very limited (mostly EMS TOP GUN, and some Aimtrak.) and some only had a trigger and no extra button.
Listening to Keyboard events (even virtual, coming from AHK or IPAC devices) helped binding necessary buttons when Lightgun only had a trigger.
But, again, as your Lightguns are detected as HID controllers (Joystick) in DemulShooter_GUI, all of this stuff do not apply because .....well it was not designed to : Joypad support was added mostly for WiiMotes/Joypads having a whole lot of buttons so adding virtual keys was not needed.
Aliens Arcade analog mounted gun are nowadays also very popular but they also have extra buttons.
So selecting a HID device in DemulShooter_GUI will make DemulShooter listen to this device and use the mapped buttons for Shoot/Reload/Action
Mouse is not used at all in that case
Going back to Cxbx-Reloaded, I had a short time to test on my computer and :
- Native button in emulator input is Triggers - LEFT (just tried with MS controller Duke) to activate Bullet Time in Vcop3
- And yes, using DemulShooter will override Trigger/Reload/Bullet Time original inputs so that it can inject custom values, so these 3 buttons will not work anymore once DemulShooter is hooked
So, unfortunatelly, you have a very specific setup which - in the current state - will not allow you to map a keyboard/pedal/virtual button to that specific action....
purbeast
Thanks for the detailed explanation.
Do you know why the Y button would act differently for me in vcop3 versus the vcop3_t option, with demulshooter hooked in?  As in, vcop3 the Y mapping reloads for me whereas in vcop3_t it actives the pedal?
You also mention that the 3 buttons will not work anymore, however the reload button mapping seems to be the only one of the 3 that still works for some reason.  Is THAT actually a bug and it shouldn't be happening?
You do mention using a Duke controller.  I do remember I did pick the Microsoft S controller when I was testing it.  I wouldn't think that the controller type, since they are both Xbox, would have different mappings for bullet time.
Initially I was using v10.15.1 I believe but then I also tried the most recent version and had the same behavior.
EDIT:
The thing that stinks too is it seems cxbx has native joystick controller as well with my device, however it doesn't appear there is a way I can have a mixed input config where I use my gun AND keyboard.  When I was messing with this however, it did seem like the accuracy was better with DS being hooked in rather than using the cxbx joystick support.  I don't know if it was actually different accuracy wise or if it was because I had the cursor still showing when I first did that and it was just messing with me.
« Last Edit: April 29, 2025, 07:38:48 am by purbeast »
purbeast
Well thanks to DemulShooter being open source, I took a look at the code for vcop3 and figured out where things had to be changed to de-hook the bullet time button, and my buddy who knows ASM looked at it and figured out the line of code I could change to make it not look for bullet time in DS.
So now I got a custom build of it where I can use my pedal for bullet time and it is working perfectly!
Thanks again for all the hard work.  Looking at that code I am like damn.  I am a web developer so that stuff is pretty foreign to me.
argonlefou
Glad to know you managed to work that out that way  ;)
Ginsonic
  • Last login:January 12, 2026, 06:48:01 am
  • Arcade enthusiast !
Hi Argon,
Flycast 2.5 is released. In case, you have some spare time, it would be great, if you could release a compatible DS version, thanks a lot!
argonlefou
Hi Argon,
Untill I can push a new update, unzip the joined file in /memorydata/flycast folder of your demulshooter
Ginsonic
Great, many thanks  :)
Endprodukt
  • Last login:February 23, 2026, 12:12:40 pm
Couldn't see any lightgun related updates in 2.5. Something you saw?
argonlefou
There's a line about a fix for Manic Panic Ghost in the changelog
purbeast
I'm looking for some help with Virtua Cop 2 and DS.  I've attached the DS log to this post.  I'm have a video showing this as well below that I uploaded to youtube.
When I play Virtua Cop 2 it starts off okay, but it quickly becomes an issue when reloading.  I have to double tap off screen to reload.  You can see that the first shot registers but nothing happens and then I do it again quickly and it works.  But then, sometimes it DOESN'T work and then I will end up shooting straight at the screen and it thinks I'm shooting off screen or something but it isn't actually reloading.  When it does register a shot on the screen, the tracking is dead accurate.
On top of that, I get some very odd artifacts on the screen, like X and random text characters in certain spots, and it's like no rhyme or reason as to when they show up either.
The video is below and you can see this behavior.  I am not sure if you can see the artifacts (haven't watched it yet) but I try to point them out and they just stay on the screen.
I have also confirmed that without DS hooked in this does not happen - no weird characters and I can reload no problem with the right click button on the mouse.
Anyone have any ideas?  Virtua Cop and House of the Dead both work perfect, it's just this one game giving me these issues.
EDIT:
Video added
« Last Edit: May 09, 2025, 08:13:51 pm by purbeast »
argonlefou
I think I remember seeing those cross marks when Xinput or rawinput were enabled in the emulator ini file
purbeast
I just checked that and unfortunately they are both set to 0.  I've attached my ini file, renamed to EMULATOR.txt to bypass filter.
I also turned on the crosshairs just to see where it thinks my gun is when these weird things happen and even when I am shooting on screen as shown in the video above, and it is not registering a shot, the crosshair is exactly where I am aiming.  So it looks like the gun is tracking fine even when it's not firing a shot.
purbeast
Well this is interesting because it looks like you pointed me in the right direction at least.
I tried turning on Xinput and when I did that, the game plays perfectly fine.
However the problem then is, Virtua Cop 1 doesn't work at all unless I change the ini setting back.
Is this a bug in DS or is this just something strange with my own setup?
I'm going to see if there is anyway to set game specific ini files in the m2 emulator to see if I can have a specific one for vcop2.
argonlefou
I don't think there is a specific bug in DS for that....I never had any issue with vcop games and I barely changed the ini file.
But I can be wrong, It's not clear what I'm hooking to and what are the guts of Model2 control code I'm altering ....and it was on early stages of DS so I had a lot less experience than now fonding out stuff
As for using specific per-game config file with model2, you can also add a copy file command in a script (with emulator and demulshooter command) to overwrite the ini file based on your needs
purbeast
Cool man thanks.  Yah googling I found out that the suggested way was to copy specific ini files depending on the settings you need with scripts.
Since I'm using HyperSpin I just went into the module code and saw it was AHK, and I just added a special case for vcop2 romName, to copy a specific ini file over at launch, and if it's not vcop2 to copy the default one back.  I just tested it out and it looks to be working just fine.
DMB77
I've got Plant's vs zombies running but can't start the game with the trigger or any of the keys listed.  Any ideas on how to fix this.
argonlefou
You should have a look at the dk2win32 dll file and the corresponding ini file, this is the actual patch for the game to start and this is the place the keys are set for controls
That's the part not covered by the DS wiki as the custom dll setup is not my own doing
dgrace
  • Last login:February 21, 2026, 10:13:27 am
Mission Impossible works great with recoil outputs (using alien mounted guns) using mamehooker and/or hook of the reaper. However, crosshairs disappear even though i'm not using the -nocrosshair in the command line. I'm not sure if this is a bug, or if i'm doing something wrong. This is in my standalone build using demulshooter. When I play it with my teknoparrot build, the crosshairs are there.  Anyone else experiencing this?
Also, anyone else struggling to get mission select to work from the MissionImpossible_ServiceMenu.exe? No matter what I select, the other missions aren't available (like they are when you play via teknoparrot).
Thanks in advance
« Last Edit: May 17, 2025, 12:08:25 am by dgrace »
argonlefou
Thanks in advance
Crosshair is indeed a bug :
https://github.com/argonlefou/DemulShooter/issues/307
For mission select, I'll have a look
dgrace
Thanks in advance
That did it on the crosshair... Thanks a bunch Argon
dgrace
I just spent like an hour trying to get recoil outputs working on my alien guns for Railchase2 and didn't realize that game doesn't even have recoil outputs; which is weird. Oh well:) I guess you always have the mamehooker keystates (joytokey) option.
argonlefou
Thanks in advance
What I can see is, with mission select option enabled, you can choose between mission 1 & 2 at the select screen, whereas without the option enabled it automatically select the first one to play.
Mission 3 (special mission) might be unlocked after finishing both classic missions (I guess, didn't play the whole game)
And there's no saving state of already done missions, so I don't think it's normal to have everything unlocked at start
DMB77
does Demulshooter work with Night Hunter After Dark v3.02? I keep getting the insert dongle error.  It works on TP but no remove gun, crosshair, and laser sight, and I can't aim all the way to the right of the screen.
argonlefou
I have 2 different dumps of NH2:
- one marked as 2.0.6 (or 2.0.16 depending on the files) with qumo2_en.exe binary
- one marked as 3.0.2 with qumo2.exe binary
DemulShooter plugin should work with both as I'm able to run the game, add credits and start on both dumps
DMB77
Hmm strange, I got the game running and the inputs seem to work as I can use the coin and start keys, but the guns won't work.  I set the input mode to DEMULSHOOTER.  My guns work fine in other games with demulshooter.  this is my ahk script. I also tried -target=unis and I've tried renaming the exe and folder to qumo2_en but still the same results. Any ideas on what i can try?
Run, F:\DemulShooter\DemulShooterX64.exe -target=arcadepc-rom=nha
Run, F:\Emulation\Arcade Dumps\Night Hunter After Dark Chapter II (3.02 DS)\qumo2.exe
Escape::
   Process, Close, DemulShooterX64.exe
   Process, Close, qumo2.exe
   GuiClose:
   GuiEscape:
   ExitApp
Return
purbeast
Escape::
   GuiClose:
   GuiEscape:
   ExitApp
Return
If that is your actual script, it appears there is no space between the -target parameter and the "-rom" text.
Try adding a space between "arcade-pc" and "-rom".  I did see there appears to be a typo in the wiki that doesn't have a space between the text.
