Author Topic: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)  (Read 1907740 times)
0 Members and 15 Guests are viewing this topic.
Ace
  • Last login:February 05, 2024, 06:27:53 am
Made some progress though if I change ‘system board’ Service from F2 to my right button on my Aimtrack which is start ‘joyo_o’ I can cycle through the first part of the Test/service menu however once I go into the
‘Game test mode’ screen and press the right button it cycles and selects ‘input test’ (so kinds acts as both) but once there you can’t get out of it as you need to press service and test together.
Hope you may be able to help and look into this and if not I totally understand.
Thanks a lot and hope that all makes sense 👍🏻🤪
SaputraJ
  • Last login:July 06, 2023, 12:47:41 am
Argon,
as the demulshooter was updated with the game Friction I got the new version and the virtua cop3 chihiro stopped working. I'm using this command to run the rom according to what was passed in the manual:
Cxbx.exe /load c:\cxbx\vc3.xbe
The game opens but I can't start it, key 1 doesn't work.
I finally managed to reproduce the issue, after a dozen times without error.
DemulShooter ended in some kind of infinite loop while waiting for Cxbx to load the rom completely
This only happened once, and never when I ran DemulShooter way after the game has started. I think you can try (for now, untill I figure it out) to add some kind of delay to run demulshooter or even just try to run it once you're at the main menu just to seet if it's working or not
Thanks Argon, with your instruction i managed to make it work, follow my ahk maybe help others:
Run, c:\cxbx\Cxbx.exe /load c:\cxbx\vc3.xbe, c:\cxbx
Sleep 5000
send,{AltDown}{Enter}{AltUp}
Sleep 5000
Run, c:\DemulShooter\DemulShooter.exe -target=chihiro -rom=vcop3, c:\demulshooter
just don't forget to change the directories, if it's different from mine.
IT WORKED! i m using 2 aimtrak guns with Demulshooter 8.7.0 and just want to say Thank you !
argonlefou
  • Last login:Yesterday at 04:25:35 pm
Well..you just won't be able to do that with only a couple of buttons on your guns.
You'll usually need TEST, SERVICE buttons to navigate menus, and sometimes 1P_START or 2P_START and triggers to validate a few things
So you just have to use a keyboard to set up the game.
This has nothing to do with demulshooter (I'm just handling Aiming, Shoot and Reload)
yid4lyf
  • Last login:April 04, 2024, 11:58:42 pm
Hi Argon, Is there a way to have a crosshair in house of the dead 4. My young one is struggling when we play it together. If so how do I do it.
Thank You
argonlefou
Not that I know of, and only reaver and his team knows what's inside Teknoparrot....
Ace
Thanks a lot and totally understand just thought if i could navigate through hotd2 it would be the same for confidential mission especially when I can navigate and select on the first screen ok, It only goes wrong on the ‘game test screen’ so was hoping you could shed some light. Not a problem and thanks a lot.
When you go back to look at Model 2 could you let me know please and thanks again for this great add on 👍🏻🙏🏻
Update: Solved and sorted 👍🏻😊 sorry for all the questions and hope you don’t mind just new to all this but getting there.
« Last Edit: April 12, 2020, 04:26:32 pm by Ace »
SaputraJ
Has anyone with a dolphin bar + wiimote knows how to make the "middle button" works in wiimote (for 1 player)? shooting and reload working great for me, but in games like virtua cop 3 that have "middle button" it doesnt work.
Which mode are you using the bar in? Mode 4? And if so are you also using Touchmote?
Hi All, i know this out of topic when playing cxbx virtua cop 3 do you know how to fix this some sort of weird screen obscuring artefact happened towards the end of the second level.
A graphical bug that seems to have carried over from the previous version of the emulator, I think it was meant to be smoke or something that's just not displaying correctly? Thank you.
yid4lyf
Hi Argon, I recently installed the Heavy Fire games, Afghanistan is working perfectly with 2 aimtraks with demulshooter but shattered spear is only letting me use one aimtrack. demulshooter told me I have got the steam version and installed the necessary dll files for me and told me to use, DemulShooter.exe -target=windows -rom=hfa2p_s which I have but it is still only working for one gun. I am using demulshooter 8.7.0. Can you help me with this problem.
Thanks again.
covid19
  • Last login:April 16, 2020, 08:35:33 pm
Hello, please be gentle, this is my first post. I read the rules and tried searching before posting.
When I use DemulShooter in full screen I can't reach the Left and Right sides of the screen. I can reach the top and bottom but the cross-hairs stop around 20% of each side.
When the emulator window is smaller than my display screen, I can reach everywhere but as soon as I move the window past that zone, I can't reach it. It behaves as if Demulshooter read my screen as 4:3 instead of 16:9 (1920x1080).
Does anyone know how to fix this?
I'm using DemulShooter + Touchmote + DolphinBar mode 4.
Touchmote simulates XBox gamepads. Windows Controller Properties show that I can reach all corners of the Axes.
I have tried Demulshooter v8.6.0, v8.7.0, and v8.8.2 with CXBX Reloaded (VCOP3) and Teknoparrot (HOTD4 and OG).
Any guidance will be greatly appreciated!
  • Last login:Yesterday at 07:47:22 am
Change your user name.
jase2170
  • Last login:April 16, 2020, 01:23:41 pm
Does anyone have a accurate tutorial on how to set-up a wii remote with a generic sensor bar to play house of the dead 4 on teknoparrot? all is setup buttons work on wii remote and sensor works before game loads but then I can only toss grenades no shooting. maybe a software issue..im using touchmote, demulshooter, teknoparrot emulator.
yid4lyf
Is anyone else having trouble with Rambo and house of the dead 4 when playing 2 players. The targeting works perfect with one player but a soon as the second player comes in it is all over the place. The player 1 target just gets stuck on the top of the screen. If anyone else has had this problem is there a way to fix it. Also does any one know how to get a crosshair to work in HOTD4.
Thanks guys.
SaputraJ
Thanks guys.
Try to play in dark room / evening
phasermaniac
Hi!
I've been teesting Friction Arcade and for me it's a little problematic:
In my Arcade pc with amd and crtemudriver, the game crash out the box, with VSIOBOARD-v1 and VSIOBOARD-v2.
With VSIOBOARD-v1, it works with gameloader RH, but if I use it demulshooter doesn't hook.
I tested CRT-Geom MOD v3.1b and demulshooter doesn't hook neither.
Thanks for your great work Agon. It must be foolish to manage so much games, different resolutions, launchers...
argonlefou
DemulShooter v8.8.3 :
- Changed "Friction" support to target vsIOBoard.dll v3.0 (v1.0 and v2.0 won't work)
- Corrected windowed mode support for Art Is Dead
Hi!
For that I can't do anything unfortunatelly. This is the drawback of Game Loader
punkdark2000
  • Last login:June 20, 2025, 07:47:45 pm
Thanks, Argon
phasermaniac
Shame for Gameloader.
Many thanks for Art is dead! Going to test it now!
Edit: works perfect!
« Last Edit: April 16, 2020, 06:58:04 pm by phasermaniac »
Jayinem
  • Last login:December 14, 2025, 09:04:21 pm
I am having a lot of problems with Model2 when using either Troubleshooter2 or Demulshooter. I have tried TS2 with 1.0 and Demulshooter with 1.1 and everytime I go fullscreen it gets stuck on a black screen and I can't close the app I can't even alt+tab+del or f4 to close it I have to reboot my computer. It has not happened once or twice but everytime I've tried model2 which has been multiple times in the last few days.
In addition to that my EMS Top Gun 3 doesn't work anyway with Model2 using TS2 or Demulshooter.
« Last Edit: April 16, 2020, 09:38:45 pm by Jayinem »
Soul assassin
  • Last login:April 18, 2020, 05:13:50 pm
Hi, hope you can help been trying to get two guns to work with latest dolphin5 and demulshooterx64 on win 10 x64.
  Both guns work but both act as player 1, Ive followed the GitHub instructions a few times now but have had no joy getting them to work. I have demul and dolphin running in administrator mode. This is my start command, my 2nd gun appears as 2nd on the list after keyboard/mouse so ive used this to start demul   C:\demulshooter\DemulShooterX64.exe -target=dolphin5 -ddinumber=2 -v
and this is the log file after run. It appears not to be accessing memory for some reason, hope you can help dying to play overkill again.
thanks paul.
11:30:09.211043 :
11:30:09.216054 : ---------------- Program Start -- DemulShooter v8.7.0.0 ----------------
11:30:09.220038 : P1 device = \\?\HID#VID_D209&PID_1601&MI_02#9&375eebb1&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
11:30:09.223036 : P1 Device Handle = 65601
11:30:09.226035 : P2 device = \\?\HID#VID_D209&PID_1602&MI_02#9&2f312172&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
11:30:09.230035 : P2 Device Handle = 65599
11:30:09.247023 : P3 device =
11:30:09.251020 : P3 Device Handle = 0
11:30:09.254018 : P4 device =
11:30:09.257017 : P4 Device Handle = 0
11:30:09.261027 : Cmdline arg 1 : -target=dolphin5
11:30:09.264013 : Cmdline arg 2 : -ddinumber=2
11:30:09.319993 : Cmdline arg 3 : -v
11:30:09.341969 : Waiting for Dolphin  game to hook.....
11:30:16.345924 : Attached to Process Dolphin.exe, ProcessHandle = 1136
11:30:16.349922 : Dolphin.exe = 0x00400000
11:30:18.454708 : Cannot read memory at address 0x0128BC80
11:30:18.458718 : ControlsPtr address = 0x00000000
11:30:18.462703 : Cannot read memory at address 0x00000000
11:30:18.467700 : DInput Keyboard/Mouse address = 0x00000000
11:30:18.471698 : DInput Player2 device number in the list : 11
11:30:18.475708 : Cannot read memory at address 0x00000008
11:30:18.479693 : DInput Device#2 address = 0x00000000
11:30:18.484703 : Memory Hack complete !
11:30:18.489689 : -
11:30:49.777054 : RawData event for Device #1:
11:30:49.782037 : Device rawinput data (Hex) = [ 0000, FFFF ]
11:30:49.791045 : PrimaryScreen Size (Px) = [ 1280x768 ]
11:30:49.797042 : OnScreen Cursor Position (Px) = [ 0, 767 ]
11:30:49.802040 : ActLabs adaptated OnScreen Cursor Position (Px) = [ 0, 767 ]
11:30:49.808023 : OnClient Cursor Position (Px) = [ 0, 767 ]
11:30:49.815035 : Game client window resolution (Px) = [ 1280x768 ]
11:30:49.820024 : Game Position (Hex) = [ FFFFFC18, 03E5 ]
11:30:49.824013 : Game Position (Dec) = [ -1000, 997 ]
11:30:49.828012 : MouseButton (Hex) = 0x0004
11:30:49.832027 : -
11:30:49.838025 : RawData event for Device #1:
11:30:49.843016 : Device rawinput data (Hex) = [ 0000, FFFF ]
11:30:49.847018 : PrimaryScreen Size (Px) = [ 1280x768 ]
11:30:49.851011 : OnScreen Cursor Position (Px) = [ 0, 767 ]
11:30:49.855009 : ActLabs adaptated OnScreen Cursor Position (Px) = [ 0, 767 ]
11:30:49.859007 : OnClient Cursor Position (Px) = [ 0, 767 ]
11:30:49.863004 : Game client window resolution (Px) = [ 1280x768 ]
11:30:49.867990 : Game Position (Hex) = [ FFFFFC18, 03E5 ]
11:30:49.873003 : Game Position (Dec) = [ -1000, 997 ]
11:30:49.877008 : MouseButton (Hex) = 0x0000
11:30:49.881011 : -
11:30:49.885995 : RawData event for Device #1:
11:30:49.890006 : Device rawinput data (Hex) = [ 0000, FFFF ]
11:30:49.894004 : PrimaryScreen Size (Px) = [ 1280x768 ]
11:30:49.897988 : OnScreen Cursor Position (Px) = [ 0, 767 ]
11:30:49.902986 : ActLabs adaptated OnScreen Cursor Position (Px) = [ 0, 767 ]
11:30:49.907982 : OnClient Cursor Position (Px) = [ 0, 767 ]
11:30:49.912997 : Game client window resolution (Px) = [ 1280x768 ]
11:30:49.916990 : Game Position (Hex) = [ FFFFFC18, 03E5 ]
11:30:49.920988 : Game Position (Dec) = [ -1000, 997 ]
11:30:49.924985 : MouseButton (Hex) = 0x0000
11:30:49.929969 : -
argonlefou
My Dolphin5 memory is rusted (but luckily I'm about to go back into it in the next few days) so untill then, you can retry - exactly as stated in the wiki - by running DemulShooter.exe instead of DemulShooter64.exe.
Can't promise it will solve the problem but it will be better for sure if more investigations are needed
Just for information, the later one is absolutely reserved for specific 64bits games (so far, the only mention to it is on Luigi Mansion Arcade wiki page)
I know it has been said many times here but I can understrand people comming directly from Github without getting the info here. This will be settled soon as the next released won't allow DemulShooterX64 to run for non allowed targets, and wiki will be lot more explicit on it
Soul assassin
Hi Argonlefou, thanks for the quick reply. Sorry I didn't realise that the x64 bit wasn`t to be used, just presumed it was the 64 bit version. tried following the wiki agin but getting the same result. Thankyou for your help, especially at the moment, sure you have lots else on your mind.
thanks Paul
19:14:53.734755 :
19:14:53.804714 : ---------------- Program Start -- DemulShooter v8.7.0.0 ----------------
19:14:53.808712 : P1 device = \\?\HID#VID_D209&PID_1601&MI_02#9&375eebb1&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
19:14:53.812710 : P1 Device Handle = 65601
19:14:53.816708 : P2 device = \\?\HID#VID_D209&PID_1602&MI_02#9&2f312172&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
19:14:53.820705 : P2 Device Handle = 65599
19:14:53.823703 : P3 device =
19:14:53.827688 : P3 Device Handle = 0
19:14:53.831699 : P4 device =
19:14:53.835683 : P4 Device Handle = 0
19:14:53.839688 : Cmdline arg 1 : -target=dolphin5
19:14:53.843680 : Cmdline arg 2 : -ddinumber=2
19:14:53.846690 : Cmdline arg 3 : -v
19:14:53.880671 : Waiting for Dolphin  game to hook.....
19:14:56.874929 : Attached to Process Dolphin.exe, ProcessHandle = 1200
19:14:56.879944 : Dolphin.exe = 0x00400000
19:14:58.885781 : Cannot read memory at address 0x0128BC80
19:14:58.889779 : ControlsPtr address = 0x00000000
19:14:58.894765 : Cannot read memory at address 0x00000000
19:14:58.898761 : DInput Keyboard/Mouse address = 0x00000000
19:14:58.902772 : DInput Player2 device number in the list : 11
19:14:58.906756 : Cannot read memory at address 0x00000008
19:14:58.910767 : DInput Device#2 address = 0x00000000
19:14:58.914765 : Memory Hack complete !
19:14:58.919749 : -
19:15:15.725104 : RawData event for Device #1:
19:15:15.776057 : Device rawinput data (Hex) = [ 0000, FFFF ]
19:15:15.807039 : PrimaryScreen Size (Px) = [ 1280x768 ]
19:15:15.822030 : OnScreen Cursor Position (Px) = [ 0, 767 ]
19:15:15.828027 : ActLabs adaptated OnScreen Cursor Position (Px) = [ 0, 767 ]
19:15:15.862007 : OnClient Cursor Position (Px) = [ 0, 767 ]
19:15:15.880997 : Game client window resolution (Px) = [ 1280x768 ]
19:15:15.885993 : Game Position (Hex) = [ FFFFFC18, 03E5 ]
19:15:15.889991 : Game Position (Dec) = [ -1000, 997 ]
19:15:15.894989 : MouseButton (Hex) = 0x0004
19:15:15.899000 : -
argonlefou
Are you using the dolphin v5.0 (3 years old, stable build) build ? Or any recent development builds ?
Soul assassin
Hi Argonlefou I'm using the latest version from the dolphin site, should I try an older version?
_Gioacchino_
  • Last login:June 18, 2024, 03:19:46 pm
hi guys but how it works with mame emulatotion?
argonlefou
Yes, you must use 5.0 stable release
MAME can handle multiple ligthguns alone, so no need for DemulShooter
Jayinem
When I run this script with autohotkey
SetWorkingDir, C: \ Downloads \ DemulShooter_v8.8.2
run DemulShooterX64.exe -target = ttx -rom = lgi
SetWorkingDir, C: \ Downloads \ TeknoParrot_1.0.0.118
run TeknoParrotUi.exe --profile = lgi.xml
exit
It opens Teknoparrot over and over and over and I don't know why.  But when I remove the Demulshooter part and only run Teknoparrot it opens only 1 screen.
Soul assassin
Hi Argonlefou, that did it thanks very much! Overkills so great!!!
Thanks once again,
Paul.
_Gioacchino_
so that's the same with model 3?
yid4lyf
Hi Argon, Just wanted to say your Demulshooter has been a life saver. My kids think Im a hero because ive got all these gun games running on the arcade machine :lol. Just a couple of questions. If I run the 2Spicy game with the latest build of Demulshooter will I be able to choose the character that uses the automatic weapon. Also have you heard of the game Big Buck Hunter Arcade on windows. If so do you think you will be able to make it work with Demulshooter.
Thanks again
argonlefou
Yes, it is the same indeed
No, this issue has not yet been corrected, and I really don't know when I'll be able to look into it
Thanks again
Yes, I worked on this game a few years ago (you can still see W.I.P code for this game in DemulShooter's sources) and results were not satisfying.
So far, I'm thinking of adding it in the next big update (in DemulShooterX64 as it's a 64bits game) but with a lot of limitations : it will just allow to play as Player1 with an Aimtrak
All Buttons, and P2 axis are still beeing a problem (like a lot of real windows games, like blue estate...)
yid4lyf
Thanks again
Brilliant thanks mate
lllll44
  • Last login:August 09, 2025, 10:29:49 am
Hi argon.
i hope you good and well:)
just wanted to let you know that silent scope 1 and 2 works great in cxbx (silent scope 3 has a zoom bug), hope you could do your demulshooter magic on them soon:)
Jayinem
Hi argon.
Nice I have an original Xbox still and about the only reason is for that game. Maybe I could toss it in the closet soon. 3 doesn't work though?
CtrlAltDelete
  • Last login:May 25, 2020, 01:00:22 pm
Hi argonlefou, I tried DemulShooterX64.exe -target=seganu -rom=lma but I couldn't make it work. I tried it on x64 versions of DemulShooter v8.7.0, v8.8.2, and v8.8.3. I also tried x86/regular versions of Demulshooter just in case but no luck. Do you know if its working fine? Does it require a special version of Teknoparrot?
I couldn't find info about this online. I guess most people are using mouse as controller on Teknoparrot (which works reasonably well) but I'm trying to use Demulshooter because I want two players.
Demulshooter works OK for other machines like vcop3, od, and hotd4.
For LMA, it correctly hooks to the emulator (it closes along with the emulator) but the crosshairs just won't move.
Thanks for the help!
lllll44
Hi argon.
hi, the game itself run fine, but the zoom has visual bug that not letting you zoom hehe.
argonlefou
Hi argon.
Are you talking about the "Silent Scope Complete" compilation on Xbox ?
Well, this part of the answer will be preaty easy  ;D : if you can use a game with DemulShooter, it is because it is working fine.
I don't think any particular version of TP is required - even though it's not the safest emulator to update in general, so I may be wrong.
As usual, to have a quick check on what's going on and try to see easy mistakes, run Demulshooter with the -v option and share the resulting debug.txt file after using it
And of course, checking admin rights on execution, etc, etc...
lllll44
Hi argon.
yes.
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
If you use demulshooter64 + touchmote, It doesn't work.
It works only with demulshooter64 + dolphin bar in mode2 (mouse mode).
argonlefou
yes.
Ok, so these games are not real arcade material but console adaptation....and they are already available and fully playable (the 3 of them) with PCSX2.
And you can even tweak things a little bit to play with an Aimtrak
So, unless there are details I don't know about, there are no reason to hack these games on Xbox
Jayinem
Please help me get lightgun to work with Aliens Extermination Dehasped. I am so frustrated because I just had it working the other day and had to do a system restore for some other reason and now it won't work. I even copied all the files to a hard drive before restore and copied them back and doesn't work. I followed the same steps to get it working before and the gun is not recognized in gun calibration. Here is my AHK script which I have verified that [aliens] shows in demulshooter icon during the game. I have Demulshooter 8.8.2 files inside the location of the game.  The game itself is located in C:\PC\aliens.
run, DemulShooter.exe -target=globalvr -rom=aliens
run, aliens dehasped.exe -noavi
I get avi error without -noavi and the gun wouldn't work. Before putting -noavi fixed it. But not this time.  I only have 1 gun. Not using mouseenabler. Tried running as Administrator both the game and DemulShooter.exe and even AHK nope.
Debug
« Last Edit: April 21, 2020, 01:04:25 pm by Jayinem »
