Author Topic: mame won't create config files ????  (Read 2582 times)
rmcelwee
  • Last login:December 12, 2017, 05:40:25 pm
« on: December 23, 2015, 11:05:16 am »
I redid my mame computer/cab and was trying to change the "inputs this game" for Tron. My changes weren't taking so I did some looking around. My mame/cfg directory only has three files in it. It used to be chocked full of changes that I made over the years. I notice that there is not a tron.cfg in there. I use a front end so I loaded mame tron in a command line and tried to change the inputs again. Still, no changes made and no cfg file created. I copied my old tron.cfg from another install (would have been the changes I wanted to make) but yet the changes still don't take effect. I don't see any problems with the attributes on the directory or files. Any ideas???
Oh yeah, I tried another game (time pilot 84) and had the same results. It will not create cfg files or save changes.
« Last Edit: December 23, 2015, 11:10:01 am by rmcelwee »
Re: mame won't create config files ????
« Reply #1 on: December 23, 2015, 11:22:03 am »
It might be a windows permissions thing.
Are you logged in or running mame as administrator?
rmcelwee
« Reply #2 on: December 23, 2015, 11:27:39 am »
I'm running mame 0.62 under win98 dos mode with arcadeos as a front end. I just did a DOS shell from inside arcadeos and changed to the mame/cfg directory. I used dos edit and created test.cfg . I think this would indicate that there are no permission or attribute problems.
Thanks for the suggestion though!
Thenasty
  • Last login:Today at 12:51:27 pm
« Reply #3 on: December 24, 2015, 08:31:55 pm »
check mame.cfg/ini file and see if it's directing the right path/folder to CFG.
Free VGA Breakout Cable
rmcelwee
« Reply #4 on: December 25, 2015, 07:51:07 am »
Will do! Thanks....
rmcelwee
« Reply #5 on: December 25, 2015, 09:36:04 pm »
Wow, I have no idea why it was like that but NO, it was not set up to the correct path. I'm not sure why it would make a difference in saving the settings since it should have just used the cfg files it was creating in the other directory. In any event, it is fixed (and I feel stupid - shouldn't have to check mame.cfg after 15 years of not looking at it).
Thanks for making me look at the simple stuff!
