Author Topic: Low profile led for utrak?  (Read 2357 times)
deezdrama
  • Last login:January 25, 2024, 09:45:32 pm
    • forum.arcadecontrols.com/index.php/topic,146268.0.html
« on: October 12, 2015, 06:25:41 pm »
I have very little room under my utrak for led lighting...maybe 1/4".
I think the rgb unit might fit but this project has already burned the bottoms out of both my pockets.
For now was just wanting a cheap single color led that could fit under my utrak.
The single color blue led bulb I bought with it wont fit.(pic below)
Just wondered if anyone knew of a surface mounted flat option like an IL illumination pad but bright enough to light the utrak pearl?
  • Last login:November 22, 2025, 08:32:45 pm
Re: Low profile led for utrak?
« Reply #1 on: October 12, 2015, 07:11:36 pm »
Look up the Whammoed lite-mite.
http://forum.arcadecontrols.com/index.php?topic=51658.0
I bought one of these, I can attest to how well it works.
« Last Edit: October 12, 2015, 07:14:50 pm by yotsuya »
« Reply #2 on: October 12, 2015, 07:16:32 pm »
And if that's not flat enough for you, you really need to route out more space in your machine.
deezdrama
« Reply #3 on: October 12, 2015, 07:24:24 pm »
Thanks for the link. I will check it out.
Afraid I cant route out any more or I will be lighting my feet and other trackballs :o
deezdrama
« Reply #4 on: October 12, 2015, 07:32:35 pm »
I think it would fit without the dimmer. Wonder if he could make one without...
« Reply #5 on: October 12, 2015, 07:46:08 pm »
Email him. He's a super nice guy.
deezdrama
« Reply #6 on: October 12, 2015, 08:11:11 pm »
I contacted him through his site
  • Last login:Today at 03:04:48 pm
« Reply #7 on: October 12, 2015, 08:49:14 pm »
If it doesn't work out, you could solder 2 or 3 LEDs and resistors like the left half -- R1 and BB.
It uses 3 Button Blaster LEDs with resistors from GGG (BB and R1), 14 LED 12V buttons from Paradise(LB), and an 11 ohm current limiting resistor (R2).
------------5V------------------------>
BB  BB  BB       LB   LB  LB  LB (Total of 14)
R1  R1  R1        -------------------->
|     |    |                   R2
-----------Ground--------
The left side is the trackball circuit, the right side is the buttons.
Green lines on the attached picture represent the R1 resistors--bend leads to route around LEDs. 5V and Ground wires can be attached to different holes on their respective rails to make mounting easier, if needed. I also fastened a piece of plastic on the underside to insulate the solder connections from shorting out.
Solderable breadboard - http://www.amazon.com/gp/product/B0040Z6OK6/ref=oh_details_o01_s00_i00
ButtonBlaster LED (with resistor) - http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=83&products_id=263
deezdrama
« Reply #8 on: October 12, 2015, 08:51:40 pm »
Would a cree get too hot /burn out?
Something like this would fit perfect
deezdrama
« Reply #9 on: October 13, 2015, 06:20:57 am »
I should probably really just get the rgb led unit but would hate to have to buy a $60 controller just to light it.
Anyone just hard wire one for a single color before? Would i need a resistor?
Any other cheaper controller?
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
« Reply #10 on: October 14, 2015, 08:18:21 am »
I just ordered a USB powered LED light for just this purpose. For Reading Wrinting it says!
http://www.ebay.ca/itm/311440753324?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
deezdrama
« Reply #11 on: October 14, 2015, 10:23:50 am »
Thats a clever solution. Did you install it yet? Does it light it up well? Any pics?
Im leaning towards white leds so this would suffice for now.
eds1275
  • Rock and Roll!
« Reply #12 on: October 14, 2015, 10:38:34 am »
Just ordered from China! I'll let you know in a month!
deezdrama
« Reply #13 on: October 15, 2015, 10:51:50 pm »
Yeah... those packages always seem to come and its been so long your sitting there wondering whats inside the package lol.
Ive been lucky a couple times and got my china mail quicker than some things ive ordered here though.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #14 on: October 16, 2015, 07:38:14 am »
Our U-Trak illumination kit uses 2 x Cree ultrabright LEDs per color. It has inbuilt resistors and can be powered permanently from 5 volts, to light one or more channels, or plugs into our controllers. It only extends 3mm below the trackball unit.
It draws 120 milliamps per color so has on-board MOSFET drivers for the LEDs
« Last Edit: October 16, 2015, 07:40:10 am by AndyWarne »
eds1275
  • Rock and Roll!
« Reply #15 on: October 16, 2015, 11:31:53 am »
Yeah, that's what I'm hoping for this time around. If not, it looks great as it is!
eds1275
  • Rock and Roll!
« Reply #16 on: October 27, 2015, 07:53:42 pm »
SURPRISE it arrived today. SURPRISE I remembered this thread. The light was ok, then I pulled the diffuser off and now it's great.
Picture doesn't do the colour justice.
deezdrama
« Reply #17 on: October 27, 2015, 08:26:53 pm »
Looks good!
I bit the bullet and ordered the rgb kit and a pacdrive when I ordered my ipac4....
Your idea is a good solution i might use on my next build
