Author Topic: Modified Coin Mechanism: How to add a key switch for free play  (Read 4731 times)
DrZhark
  • Last login:September 12, 2021, 12:36:41 pm
« on: October 12, 2015, 12:46:51 am »
I'm about to finish my first ever build. I'll post pics of the finished cabinet once the artwork is installed.
I bought one of those brand new arcade coin door with dual coin mechanisms
And decided to mod it, so I could use the coin reject buttons as free coin buttons but only when a key switch was 'switched' on.
I wanted an LED to signal when the free play was turned on (Green) and when it was off (Red)
So I came up with this circuit:
It uses cheap parts:
-5vDC DPDT omron relay (about $2)
-PNP transistor 2N2907
-common cathode Red/Green LED
-4.7K resistor
-10K resistor
-1N34 diode
-Key Switch ($3)
The 2n2907 PNP transistor can be replaced with most PNP transistors
the red/green led can be replaced by one green and one red leds (but you have to make two holes on the coin door)
The diode doesn't need to be a germanium diode, it can be replaced with most usual diodes: 1N916, 1N4148 etc
The circuit uses a 5 volt source than can be obtained from the computer's power supply. The 5 volts are adequate to activate the relay and light the red/green led
When the key is in the off position, the red led is on and the relay is deactivated, so the 'B' switches are not connected in parallel with the normal coin switches.  When the key switch is turned on, the green light is on as well as the relay and the B switches are now connected in parallel with the normal coin switches.
I carefully added microswitches behind the coin reject push buttons, so it would remain functional but activate the free coin at the end of the push
Mounted the circuit in the back of the coin mechanism.
It works flawlessly and I'm quite happy with it.
I wanted to share the circuit and instructions so others can use it, as I've learned so much from this forum and the book and at last I'm giving back my 2 cents.
BGoulette
    • lazerjoose.com
Re: Modified Coin Mechanism: How to add a key switch for free play
« Reply #1 on: October 12, 2015, 10:51:48 am »
I'm bookmarking this mothertrucker because it elegantly addresses something I've been considering! I have a neighbor who's giving me some coin doors/mechs from a parted-out machine, and I wanted to toss it all in a cab with which I plan to bribe my son: he can earn tokens which he can use to play, etc. Great idea!
johnrt
« Reply #2 on: October 12, 2015, 10:59:34 am »
Yeah, that was a great idea and well executed!  :applaud:
Generic Eric
« Reply #3 on: October 12, 2015, 11:14:11 am »
Thanks for sharing!
  • Last login:December 03, 2025, 07:29:04 pm
« Reply #4 on: October 12, 2015, 11:17:33 am »
Going to have to disagree with my cohorts.  You could have easily accomplished this with a toggle switch inside the coin door and avoided permanently butchering it.
Thenasty
  • Last login:Yesterday at 11:40:37 am
« Reply #5 on: October 12, 2015, 12:10:27 pm »
pbj, I was thinking the same thing. I think DPDT switch should do it.
Free VGA Breakout Cable
BGoulette
    • lazerjoose.com
« Reply #6 on: October 12, 2015, 12:48:01 pm »
I wouldn't have drilled a hole in the coin door -- probably would have put it someplace less visible, but still accessible, but the general concept (and circuit) is what I find intriguing.
Thenasty
« Reply #7 on: October 12, 2015, 02:08:58 pm »
adventure is always fun.
DrZhark
« Reply #8 on: October 12, 2015, 02:21:58 pm »
Indeed a DPDT is enough, but I wanted to use a key switch with a led  ;D
« Reply #9 on: October 12, 2015, 04:15:10 pm »
Fine.  Could have accomplished your goal with a relay.  Transistors and diodes were completely unnecessary.
DrZhark
« Reply #10 on: October 12, 2015, 05:18:46 pm »
The transistor is only used to control the green / red led. Nothing else. So the circuit was necessary to accomplish what I wanted. It is nothing complex anyhow. just one transistor, 3 resistors and 1 diode
wxforecaster
  • Last login:February 28, 2019, 01:19:24 pm
« Reply #11 on: December 04, 2015, 07:04:16 pm »
Since both the LEDs and switches are 5V, couldn't this have been accomplished with a SPDT relay and not a DPDT relay?
The 5V/Gnd coming from the key lock go to the coil lugs on the relay.
The 5V from the power supply goes to the COM on the relay.
The red LED and coin door switches non-ground connector wires (COM/5V) go to the NC on the relay.
The green LED and coin reject cherry switch connector wires (COM/5V) go to the NO on the relay.
The LEDs would need their normal resistor, but that's it.
Am I missing something?
